Old Mar 14, 2007, 09:19 AM
RC59 is offline
Find More Posts by RC59
RC59's Avatar
Joined Mar 2007
sig kadet senior main landing gear
Any suggestions for getting a main landing gear for my
Kadet Senior Kit,which I converted to a tail dragger
RC59 is offline Find More Posts by RC59
Old Mar 14, 2007, 11:45 AM
hogflyer is offline
Find More Posts by hogflyer
Master of the Figure "9"
hogflyer's Avatar
Wichita, Kansas
Joined Dec 2005
Get some music wire the same diameter as what is supplied in the kit and bend a new set. If you're worried it won't be stiff enough, then run a second wire similar to a Sig J-3 (older 72" version) soldering it near the axle, and strap it to the bottom of the fuselage - this would make a very rugged and lightweight gear for the Sr. Also make sure you maintain prop clearance when it's up on the main gear. when you make your new gear.
Hogflyer
hogflyer is offline Find More Posts by hogflyer
Old Mar 14, 2007, 12:21 PM
RC59 is offline
RC59's Avatar
Joined Mar 2007
landing gear
I suppose I could do that,But I don't think I could do a good job of making one.So is there a place like Tower that would have something that would fit the sig. Ready made...I have been looking at several online stores and they don't have measurements on some of there landing gears.I would most likely buy one and it be the wrong size.Thats my problem...
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
I use the large composite gear from the LHS on my tail dragger Kadets.
And when I add floats..
Sparky Paul is offline Find More Posts by Sparky Paul
Old Mar 14, 2007, 12:30 PM
RC59 is offline
RC59's Avatar
Joined Mar 2007
sig
NICE SIG....
Eventually I will add floats also,is the landing gear at a web store somewhere?
Old Mar 14, 2007, 01:37 PM
gwinhh is offline
Find More Posts by gwinhh
Beaumont tx
A sig 4 star 40 landing gear works very well. Use the 4 star 60 if you're using longer props.....
howell
gwinhh is offline Find More Posts by gwinhh
Old Mar 17, 2007, 05:59 PM
chashint is offline
Find More Posts by chashint
Dallas, Texas area
Joined Sep 2003
I like the first one best, but the other one is good too.
http://www2.towerhobbies.com/cgi-bin...?&I=LXNM65&P=0
http://www2.towerhobbies.com/cgi-bin...?&I=LXJ924&P=0
chashint is offline Find More Posts by chashint
Old Mar 17, 2007, 09:09 PM
redh is offline
Find More Posts by redh
Fla.
Joined Apr 2005
Check out www.dubro.com. They make a composite gear that I use all the time on planes up to 60 size. My book shows the measurements and I think the web site does also. ENJOY !!! RED
redh is offline Find More Posts by redh
Old Mar 17, 2007, 10:16 PM
RC59 is offline
RC59's Avatar
Joined Mar 2007
Landing Gear
After looking at the original wire gear that came with the kit.
I was looking at the installation wrong.Which gave me a 22"
wheel base.So here I'm looking for a 22" wheel base,when
I should be looking for a 14" wheel base.I didn't have the wire
running side by side under the fuse.
Thankyou everyone for helping me,now I have a lot to choose from.
Sig Kadet Senior and Seniorita Matt Chester Electric Plane Talk 28 Nov 14, 2007 08:33 AM
FS Sig Kadet Senior + xtras Steve_A_Reno Aircraft - Fuel - Airplanes (FS/W) 3 Jul 11, 2003 05:33 PM
FS: Sig Kadet Senior and CG Anniversary Edition Cub BrianZ Aircraft - Fuel - Airplanes (FS/W) 0 Nov 01, 2002 01:54 PM
