Pusher Prop Wash Compensation
I've mentioned several times that I like to compensate the effects of the prop wash to get my gyros flying straight. Today I tested a new setup, and while I was at it, I made a short video to demonstrate my point.
http://www.rcgroups.com/forums/showt...93#post7087583 The gyro is suspended by a string tied to the top of the rotor shaft. Another string tied to the tail boom at the bottom of the rotor mast keeps the gyro in position. The first part of the video shows you what happens if you mount the motor normally, in line with the tail boom. In the second part of the video the motor is offset to the right of the gyro by about 8 mm (1/3") and is compensating the prop wash effects. Jochen |
Looks very good! Waiting for results from flight testing.
![]() Dan |
Latest blog entry: Quick Stick
Good work Jochen!
Now, if you can also cancel the torque of the propeller???? I have been contemplating turning vanes behind the propeller to cancel torque but I haven't tried it. Dan
Kansas city MO
Joined Jan 2004
http://www.mindspring.com/~cramskill/propefct.htm
Here is a good explaination of prop effects. But there is no solution only compensation. Wyldman |
Jochen,
It could be an illusion but in the video clip it looks like the prop is on backwards??? In the link about propeller effect, the author speaks about correcting with right rudder, yet you have offset the thrust to give you left yaw???? Dan |
Wyldman,
thanks for the info. Stephan, MPX 3030 and MPX 4000. This is no great problem, when the motor is running everything is sufficiently synchronized. It's just the delay of the restarting motor you have to look out for. Dan, it's really an illusion. When you put the prop on backwards, you get a totally different sound, more swishing instead of humming. But you're right, in the video it looks like the prop is the wrong way round. The prop wash works a bit different for the Micromum, because the whole rudder is below the motor's thrustline. Seen from behind, you've got a cw rotating wash leaving the prop. Now think of a circle (the prop wash) with a line drawn down from its center, a bit longer than the radius (the rudder). Then use your (mental) finger to trace the perimeter of the circle in a clockwise direction and see which side of the rudder it hits - the right side, pushing the tail of the Micromum to the left. To counteract this I need left rudder (which I haven't got) or an offset of the motor to the right. Was able to get a few flights in today, and even if it was too windy to say anything definite. the new system seems to work as it should. During the less windy moments I was able to take the hands off the controls for several seconds a time. Jochen |
| Thread Tools | |
| Video Pusher Prop Wash Compensation | JochenK | Electric Plane Talk | 0 | Mar 13, 2007 04:08 PM |
| Retime S600 for pusher prop? | MtnGoat | Power Systems | 2 | Oct 20, 2001 03:19 AM |
| 4.5x3 pusher prop source | opualuan | Parkflyers | 6 | Oct 17, 2001 08:46 AM |
| pusher prop as a tractor prop ? | Al P | Power Systems | 2 | Jun 16, 2001 12:09 AM |
| Using pusher prop | glovesave39 | Beginner Training Area (Aircraft-Electric) | 3 | May 03, 2001 03:05 PM |
