Old Mar 13, 2007, 04:08 PM
JochenK is offline
Find More Posts by JochenK
JochenK's Avatar
Joined Jan 2005
Video
Pusher Prop Wash Compensation
Behaviour of a pusher gyro without and with prop wash compensation.
Jochen
JochenK is offline Find More Posts by JochenK
Old Jun 21, 2013, 05:27 AM
britinoz is offline
Find More Posts by britinoz
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
Prop wash test
britinoz is offline Find More Posts by britinoz
Old Jun 22, 2013, 12:40 AM
MaydayMayday is offline
Find More Posts by MaydayMayday
MaydayMayday's Avatar
United States, CA, Fremont
Joined Jul 2011
Is this an issue with wash over the tail?
MaydayMayday is offline Find More Posts by MaydayMayday
Old Jun 22, 2013, 01:21 AM
Lou is offline
Lou
Find More Posts by Lou
Lou
Closed Account
Joined Dec 2005
Hmmm ... well my interest is piqued. After looking at the vid several times I am missing what you did to correct 'prop wash' .... but then I am about half drunk.
Nice looking model though.
Lou is offline Find More Posts by Lou
Old Jun 22, 2013, 02:56 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
The rotation is caused by the spiral slip stream corkscrewing off the prop and hitting the vertical stabiliser at an angle causing it to generate 'sideways lift'..
Two ways you can fix it either offset the vertical stab or add thrust offset, thrust offset is best because it varies with motor power, so it doesn't upset low power/glide trim as offsetting the vertical stab would do.
If it were be I'd have offset the motor thrust line so that (looking from the rear) the motor was angled to the right slightly (right thrust). Looks like the OP decided to move the entire motor over to the right, this is another way of doing it which should work just as well, but it looks a bit odd.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Jun 22, 2013, 06:20 AM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
A little left rudder would stop it too. If it's for a gyrocopter it will need a lot of rudder at any rate.
Gord
flypaper 2 is online now Find More Posts by flypaper 2
Old Jun 22, 2013, 07:45 AM
Aberdeen
Joined Mar 2006
Only problem with using rudder (exact same thing as offsetting the vertical stab) is that it will only be 'right' at one power setting. One option with computer Tx's is to program in a throttle to rudder mix, that would work well.
Old Jun 22, 2013, 08:34 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Yeah, I don't see a moveable rudder on it. Maybe weight shifting like a hanglider. Used to fly those things. You move the bar and wait for something to happen. It was great fun just the same. Lucky I didn't kill myself.
Gord.
Old Jun 22, 2013, 08:49 AM
Lou is offline
Lou
Lou
Closed Account
Joined Dec 2005
Ahhh .. thank you. I see now. I looked again at the vid and I do see where he offset the motor. I was 'seeing' the back of the black mount as a shadow.
Old Apr 12, 2016, 05:49 PM
Phil Shipman is offline
Find More Posts by Phil Shipman
Joined Apr 2016
Autogyro scratch build
Hi and thanks to everyone who has contributed to this thread on autogyro.
I'm going to scratch build an autogyro and have been mulling over the concept of using a cyclic pitch head from a 450 helli. I have a 2 blade flybar head and a 3 blade fbl head to choose from and will use aerobalsa blades for this build.
The post about gyros by M. Nowell, and the head used there is really good but its a fixed pitch head and I'm not sure how to transform that theory into a cyclic pitch head version.
Has anyone tried a cyclic pitch head?
Has anyone got any ideas or theory they can share?
All and any help will be much appreciated and combined with the info that has already been posted in this thread I hope this build will fly successfully.
Phil Shipman is offline Find More Posts by Phil Shipman
Discussion Pusher Prop Wash Compensation JochenK Auto Gyros 9 Mar 14, 2007 11:37 AM
Retime S600 for pusher prop? MtnGoat Power Systems 2 Oct 20, 2001 03:19 AM
4.5x3 pusher prop source opualuan Parkflyers 6 Oct 17, 2001 08:46 AM
pusher prop as a tractor prop ? Al P Power Systems 2 Jun 16, 2001 12:09 AM
Using pusher prop glovesave39 Beginner Training Area (Aircraft-Electric) 3 May 03, 2001 03:05 PM
