Old Mar 13, 2007, 03:48 PM
doberman is offline
Find More Posts by doberman
Atlanta area
Joined Nov 2001
Spektrum Dx7 Charger
The included charger with the DX7 is a 50 ma charger - not big enough to charge the 1500 mah trans pack and/or the 1100 mah flight pack overnight - for a NORMAL C/10 overnight charge rate the charger should have, like a 150 ma and 110 ma dual outputs. The VERY SIMILAR JR XP7202 radio system comes with a dual output 110 ma charger. Has anyone bought a DX7 and gotten a 110 ma or LARGER dual output charger in the package??
doberman is offline Find More Posts by doberman
Old Mar 13, 2007, 05:28 PM
hew565 is offline
Find More Posts by hew565
USA, LA, Mandeville
Joined Feb 2005
Mine came with the same 50 mah charger. I made up some leads with the proper plug on the end, to use my Multiplex LN-5014 charger on the TX as well as the RX packs. I can't do them at the same time, but I can set whatever charge rate I want and know that it will shut down when the pack peaks. I usually charge my 1500 NiMH packs at about 200 mah. There are some chargers that can charge two different packs at the same time, but I can't justify one yet
I can still use the factory charger to get the TX and one RX pack going, then switch each to the faster charger as it tops off each pack.
Make sure you get the polarity right for the charging plugs!
hew565 is offline Find More Posts by hew565
Old Mar 13, 2007, 07:22 PM
doberman is offline
Atlanta area
Joined Nov 2001
Thanks for the reply - but when you spend $350.00 on a radio system you figure you should get the corret charger......no??? I would think they realize they have a problem and correct it - my radio system was shipped from the factory last week!!
Old Mar 13, 2007, 07:26 PM
rkozola is offline
Find More Posts by rkozola
Chicago, IL
Joined Feb 2007
Even Spektrum knows the charger they provided is bs. Check their post from 2-21 under updates on their site.
http://www.spektrumrc.com/Articles/HobbyWire.aspx
rkozola is offline Find More Posts by rkozola
Old Mar 13, 2007, 11:54 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
It is not all that a big deal, since so few actually use the wall chargers any more...I leave mine on for a 24 hour period and top it off with a fast charger once in a while, at about .5C.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Mar 14, 2007, 01:33 AM
alan0899 is offline
Find More Posts by alan0899
Australia, NSW, Attunga
Joined Dec 2006
G'day Mate,
No big deal, charge it with the wall charger, for 30 hours, then you won't need to charge it agin for a long time, you can expect about 15 hours flight time from the 1500Mah HiMh pack.
I charged mine with the wall charger, then cycled it, twice, & I have not charged it for a month, & I fly every weekend, & it is still at 10.1 volts.
The DX7 only uses about 100 Ma, during use, around 40% less than a conventional TX.
alan0899 is offline Find More Posts by alan0899
Old May 20, 2008, 12:43 PM
BrentP is offline
Find More Posts by BrentP
Closed Account
Joined Apr 2008
Bought a DX7 April 2008. It came with a 110 mah charger. (transmitter and reciever). They said on there web site they were gonna change the charger and they obviously did. Thanks Horizon.
BrentP is offline Find More Posts by BrentP
Old May 20, 2008, 02:59 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
The change was made a long time ago -- soon after the Feb 2007 Horizon note that's mentioned above. I bought one last September and it had the dual 110mA charger.
There's nothing wrong with the 110 mA wall charger for most people. Just put it on charge when you get back from flying and leave it overnight. The 1500 mAh battery has enough capacity for at least a couple of flying sessions with loads left over.
Daedalus66 is offline Find More Posts by Daedalus66
Old May 20, 2008, 03:05 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Sounds like an error to me. Have you contacted Horizon?
Old May 20, 2008, 07:25 PM
BrentP is offline
Closed Account
Joined Apr 2008
It's funny that no one on this thread mentioned the change was actually made if it was that long ago.
Old May 20, 2008, 10:13 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Yes. It's over a year. All the old DX7s with low rate chargers should have worked their way through the system a long time ago. But doberman says he got his "from the factory last week." How do you buy a DX7 from the factory anyway?
Old May 21, 2008, 07:15 AM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
I prefer the original charger-- you plug in the TX and leave it -till you want to go fly-
The guys with short battery life on their tx --I would bet - tried their quick chargers for first charge - and screwed up the cells . NiMh like a nice long soak for initial charge and for future charge - the walwart is still the best. The newer charger is fine - anything under 1/10 of batt capacity
richard hanson is online now Find More Posts by richard hanson
Old Jan 08, 2010, 11:42 AM
James321 is offline
Find More Posts by James321
James321's Avatar
UK
Joined Nov 2009
Your lucky you get a charger ! In the UK (the land of paying tax on everything) we don't get a charger with the DX7, if you want your TX to work you have to buy your own charger. So thats a $450 DX7 full kit with 4 servos but it won't actually work !
Thanks Horizon
James321 is offline Find More Posts by James321
New Product Spektrum DX7 Futurase Radios 975 Feb 26, 2012 08:10 PM
Sold SPEKTRUM DX7 TX only with charger and battery 200 shipped to USA powerlines Aircraft - General - Radio Equipment (FS/W) 14 Mar 03, 2007 08:20 PM
Sold NIB SPEKTRUM DX7 TX only with charger and battery $200 SHIPPED kookboy Aircraft - General - Radio Equipment (FS/W) 6 Feb 17, 2007 10:32 PM
For Sale Spektrum DX7 radio and charger! $200 shipped powerlines Aircraft - General - Radio Equipment (FS/W) 14 Jan 10, 2007 07:51 PM
Sold Spektrum DX7 Transmitter and charger bruff Aircraft - General - Radio Equipment (FS/W) 1 Dec 09, 2006 01:53 PM
