Old Mar 13, 2007, 12:40 PM
AndreasMergner is offline
Find More Posts by AndreasMergner
fun is the goal
AndreasMergner's Avatar
USA, NY, Albany
Joined Dec 2003
Build Log
SSDC 100" Pitcheron, vacuum bagged solid hardwood
I'm starting the SSDC early because I plan to have this done for the Tri-Slope Six-Pack and the PSS Fest. I'm not sure I want to land this thing at my home slope.
Here's the idea:
100" span pitcheron
Aspect ratio ~17
AUW 90-100 ozs -- plus 100+ with ballast (200+ AUW)
loading: 25oz/sqft -- 50 with ballast
Because of the high AR, the loading is a bit misleading. It shouldn't need more than light to moderate lift when unballasted. It should stay up with a 35 oz 60" plane.
I'll be using a ~.45" steel joiner as a pivot. The wing will be FG/Kevlar over Poplar. The Kevlar really stiffens the wood from my test bagging and eliminates any tendency to split. I'll be using a 2.5" wide fuse, which will be substantially stronger than the 1.5" wide fuses I have been using. The fuse will be about 4" tall at its max. You can imagine how strong a piece of wood this size is! It will be hollowed out a little for the 100+ozs of lead to fit (approximately 15.6 cubic ins).
I know it is going to land fast, but it should be very strong and easy to repair. I haven't come up with any new and elegant ways to slow it down, so I'll try it without any landing aids first. If I find that it is getting beat up too much, I can always add flaps or an air brake later on.
I will be making the fuse in two pieces (similar to the 66" version I made for the last SSDC), where all the gear, linkages and wing joiner are housed in the "hatch". The hatch will be nylon bolted to the major part of the fuse containing the ballast. This way the pitcheron linkages are somewhat protected by shearing of the bolts.
I have ordered a couple of Hitec digital robot servos, HSR-5995TG (333oz-in of torque (433 holding torque), 417 if I use 7.2V (541 holding), Titanium gears). They look really good for this application -- I just hope they don't have any [initial] slop. I think Joe is using these for his 160" DS plane.
I won't be starting until this weekend since I have some projects to complete first. I am just very excited about the project and am looking forward to it.
Andreas
AndreasMergner is offline Find More Posts by AndreasMergner
Old Mar 13, 2007, 01:56 PM
sno is offline
sno
Find More Posts by sno
sno
sno's Avatar
United States, OR, Deschutes County
Joined Mar 2005
Sickness!!!! Cant wait to see it fly!
sno is offline Find More Posts by sno
Old Mar 13, 2007, 03:02 PM
Hutch is offline
Find More Posts by Hutch
Slopeaholic
Hutch's Avatar
Roseville, California, United States
Joined Mar 2001
sign me up!
Hutch is offline Find More Posts by Hutch
Old Mar 13, 2007, 03:26 PM
ShredAir is offline
Find More Posts by ShredAir
slope'n somewhere in the Andes
ShredAir's Avatar
Chile, Región de Coquimbo, Elqui
Joined Mar 2001
Bring it to the 6-Pack! We'll have Brian launch it... : )
Dieter Mahlein, ShredAir
ShredAir is offline Find More Posts by ShredAir
Old Mar 13, 2007, 03:31 PM
fun is the goal
USA, NY, Albany
Joined Dec 2003
Dieter, it will be in my new Sportube!
It's almost done.....(in my head).
Old Mar 13, 2007, 04:34 PM
fun is the goal
USA, NY, Albany
Joined Dec 2003
Ok, here's a pic of the wing planform. Thin wing goes slicey-dicey!
Old Mar 14, 2007, 09:31 PM
sloperut is online now
Find More Posts by sloperut
Member: GSPL
sloperut's Avatar
Utah
Joined Jul 2003
Pointy wings.....PWF.
Jeff
sloperut is online now Find More Posts by sloperut
Old Mar 14, 2007, 10:04 PM
ajroahkni is offline
Find More Posts by ajroahkni
PWP!
ajroahkni's Avatar
USA, HI, Makawao
Joined Oct 2002
Damn sexy...
ajroahkni is offline Find More Posts by ajroahkni
Old Mar 14, 2007, 11:14 PM
infopimp is offline
Find More Posts by infopimp
PNF
infopimp's Avatar
Los Gatos, CA
Joined May 2005
S.i.c.k.!!!
infopimp is offline Find More Posts by infopimp
Old Mar 15, 2007, 08:37 AM
fun is the goal
USA, NY, Albany
Joined Dec 2003
The pic is not a top view, so it makes the wings thinner that they actually are...still, they are higher AR than usual.
I was thinking Brian would be a good choice to launch too after seeing his thread. I'll also need a twisty wing expert to look at my throws before maiden. I'll be programming in a few flight modes along with dual rates on my Evo so I can have a variety of rates. I don't want to end up like last time with super twitchy rolls and no elevator! That was NO fun.
I'll have a pic of the fuse design in the next couple of days.
I was thinking of making an airfoiled V-tail for this one. Any suggestions for how to do a removable tail on it? I was thinking of two bent music wire joiners permanently attached to the fuse. I would rather have some sort of nylon bolt method of attachment, but can't think of a super easy way to do it. (I'm lazy.)
Old Mar 15, 2007, 10:15 AM
ShredAir is offline
ShredAir's Avatar
Joined Mar 2001
Y V? -- Particularly if you're lazy... isn't a nice conventional X-tail easy to bolt on and be straight?
Old Mar 15, 2007, 11:03 AM
fun is the goal
USA, NY, Albany
Joined Dec 2003
With a V, I can make just one airfoiled part (and cut into two). With a vert and a horiz, I have to cut two (different) parts. If I'm going with slabs, it's not as big a deal. Also, a removable V will pack slightly smaller. Since they won't move on a pitcheron I won't have to worry about all of the V tail linkage stuff.
Vs stay off the ground on landing too, and I like the look of a V tail.
I hear you though -- a V tail that is not straight is bad news.
Old Mar 17, 2007, 05:49 PM
fun is the goal
USA, NY, Albany
Joined Dec 2003
Just so you get the idea. The tail is just TLAR right now. The fuse might change slightly too. I think it looks pretty sweet.
Old Sep 23, 2007, 09:18 PM
fun is the goal
USA, NY, Albany
Joined Dec 2003
It's been a while on this project, but I still want to start/finish it.
I cut the main fuse today. It came out poorly due to some errors in programming, so I'll be using some bondo and paint on it. You won't be able to tell the difference.
24oz for the fuse. It is big and beefy! I have room for about 120ozs of ballast.
Old Sep 23, 2007, 09:43 PM
Cody WIlson is offline
Find More Posts by Cody WIlson
plane obsessed
Cody WIlson's Avatar
Denver, CO.
Joined Nov 2003
This is going to be sick! Do eeet!
Cody WIlson is offline Find More Posts by Cody WIlson
Why no 100" Carbon bagged plank/wing? Z06kal Dynamic Soaring 20 May 07, 2005 02:14 PM
Vacuum Bagged All-Carbon 48" Wing Question mars Composites Fabrication 12 Jul 14, 2004 11:56 AM
Aileron Hinges on a Vacuum Bagged Wing dcairns Slope 4 Mar 10, 2004 02:13 PM
