Old Mar 13, 2007, 12:01 AM
jconwell is offline
Find More Posts by jconwell
Micro Zippy
jconwell's Avatar
Seattle
Joined Oct 2006
MicroInvent actuators working with Plantraco .9g Rx?
The title pretty much says it:
Can the MicroInvent actuators work with Plantraco .9g Rx? What do I have to do; just clip off the included plug and solder on a nano connector?
jconwell is offline Find More Posts by jconwell
Old Mar 13, 2007, 01:48 AM
mharms is offline
Find More Posts by mharms
Realtired User
mharms's Avatar
San Jose, California
That should do it. The wiring looks to be Litz wire, so when you cut them, you may end up with some frayed strands of small magnet wire. For each of the leads, just twist-together any frayed strands and tin them by running them through a droplet of solder on the end of your iron (flux helps). Careful not to accidentally mix up strands from the other lead, as this will short the actuator. Then, slide your heat shrink over the tinned leads and solder them to the nano connector.
Mark
mharms is offline Find More Posts by mharms
Old Mar 13, 2007, 12:11 PM
Plantraco is offline
Find More Posts by Plantraco
Plantraco's Avatar
Saskatoon, Canada
Joined Jan 2003
Yep,
The 0.9g 3Ch receiver can handle actuators down to 20 Ohms or so - basically any magnetic actuator will be fine.
Plantraco is offline Find More Posts by Plantraco
Site Sponsor
Old Mar 13, 2007, 02:02 PM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
If you are planning on tossing the MI connectors, I'll pay you the postage and a small token for them.
Tim Wolff is offline Find More Posts by Tim Wolff
Old Mar 17, 2007, 11:20 AM
jconwell is offline
Micro Zippy
jconwell's Avatar
Seattle
Joined Oct 2006
I havent purchased anything yet, but I'm just trying to figure out my options. I've invested in the plantraco reciever / transmitter. Now i just want to know what non-plantraco components can be used with it.
Discussion 1/72 scale P-51D with Plantraco 3ch Rx rguillot Scratchbuilt Indoor and Micro Models 93 Apr 05, 2007 04:47 PM
Discussion Attaching Plantraco .9g Rx to .5mm CF fuse? tskunka Scratchbuilt Indoor and Micro Models 1 Jan 17, 2006 01:26 PM
Got a Jeti RX working with GWS X'tals and TX saitrix GWS (Grand Wing Servo) 11 Apr 29, 2005 07:59 PM
Help! Plantraco DSP Rx not working Uttam1 Radios 8 Dec 03, 2003 01:56 AM
Can someone help me with my TX/RX? It's not working... TurboRacer Radios 5 Aug 19, 2003 07:12 AM
