Old Mar 12, 2007, 09:19 PM
kallend is offline
Find More Posts by kallend
Flying R/C since 1964
kallend's Avatar
United States, IL, Chicago
Joined Sep 2004
Rudder shape
On my (semi) scratch built 32" boat I chose an elliptical shape for the rudder, not unlike a Spitfire wing planform. Looking at pics of lots of other boats, I see a variety of chapes but nothing elliptical.
What factors affect the optimum shape for a rudder?
kallend is offline Find More Posts by kallend
Latest blog entry: Using a DX9 to "strobe" LED...
Old Mar 12, 2007, 09:54 PM
nigelpheron is offline
Find More Posts by nigelpheron
nigelpheron's Avatar
Canada
Joined Jan 2007
my guess is that no body knows...the reason? there are so many different shapes and designs.
when people do know what works best, those shapes seem very similar to each other.
with that, i recamend shaping it to what ever YOU think is right, test it, and go from there.
you may even discover the best shape that sets the standard for all.
nigelpheron is offline Find More Posts by nigelpheron
Old Mar 12, 2007, 10:38 PM
keven64 is offline
Find More Posts by keven64
Model Designer
keven64's Avatar
United Kingdom, England, Burnley
Joined Apr 2001
and if it works... don't fix it !
Keven.
keven64 is offline Find More Posts by keven64
Old Mar 12, 2007, 11:45 PM
Angus R is offline
Find More Posts by Angus R
UK Footy Class Secretary
Joined Aug 2006
I think there are two reasonably good resons for deviating from the theoretically 'ideal' eliptical planform.
First, with many hull designs, there is a tendency for the stern to lift out as the angle of heel increses. A tapering planform increaes the ruddder loading per unit area with all the undesirable effects that entails.
Second (and mainly full-size) forward sweepback (in terms of area) makes it easier to achieve an acceptable compromise between easy manufacture of a metal stock and acceptable rudder (not helm) balance of a balanced spade rudder. This should be a dinosaur problem by now and is in any case only relevant if there is tactile feedback from the foil to the control device.
A.
Angus R is offline Find More Posts by Angus R
Old Mar 12, 2007, 11:57 PM
420sailor is offline
Find More Posts by 420sailor
Joined Jan 2007
another thing might be that is is easier to cut out a square than an ellipse. also, while that has more wetted surface=drag, it also has more surface area, more turning power at lower speeds... i have always liked the elliptical rudder, but in some cases, wouldn't a swept back, rudder be better? [i am thinking of high speed aircraft here, and the fact that the elliptical wings of WWII caused so much drag at high speeds that they fell off?]
420sailor is offline Find More Posts by 420sailor
Old Mar 13, 2007, 12:37 AM
LtDoc is offline
Find More Posts by LtDoc
McAlester
Joined Nov 2004
Completely beside the point. I don't doubt that elliptical wings did have problems, but the shape didn't cause any of them to fall off. Has more to do with exceeding the design speed of the wing than it's shape.
One advantage of a 'swept-back' rudder is that if the wind fails while the boat is in the middle of the pond, you can wiggle the rudder and 'scull' the boat back to shore. I'm sure they have other advantages/disadvantages, but that's the one that I'm most familiar with.
- 'Doc
LtDoc is offline Find More Posts by LtDoc
Old Mar 14, 2007, 11:50 AM
nopryde is offline
Find More Posts by nopryde
Plymouth, Minnesota
Joined Mar 2006
Rudder Shape
Last night I ask my friend who owns Computer Keels at http://www.computerkeels.com/, a company that for years has designed rudders and keels for racing sailboats about rudder shape. He said that the shape of the rudder is determined by the structural needs and that the elliptical shape distributes the load better. He also said that other than turning the boat there is no other purpose for a rudder and that you should not concern yourself with shape.
nopryde is offline Find More Posts by nopryde
Old Mar 15, 2007, 02:52 AM
Angus R is offline
Joined Aug 2006
It is purely a piece of self-justification, but ..
I agree that with a transom hung rudder, an eliptical planform distributes the load well. However, with a balanced spade mounted on a stock this is often not he case - or maybe my geometry just got screwed up or my engineering assumptions are too stiff. I find that there is odten difficulty in getting enough 'meat' in the rudder to allow a sufficiently large diameter stock at the lower bearing without recourse to exotic materials or, alternatively, to avoid an undesirably high level of rudder balance..
