Old Mar 11, 2007, 07:34 PM
Look outside the Square
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
CONTEST: Thunderstruck EDF50 /J250
Well fella's here's my entry for the contest. THUNDERSTRUCK
I went conventional, and tried to keep it simple. Have tried 2 powerplants on the Airframe, GWS EDF50 and the J250. Maidened both this morning and both worked well. Blow'n its Head off here at the moment.
PLANS IN POST 6
[B]VIDEO http://www.rcgroups.com/forums/showthread.php?t=656034
for EDF50 and J250 or can be found in Post 6
The EDF50 Specs - 17 inch Span / 18 long
Weight 4 ozs W/O Batt
2 x 5 gram servos
GWS EDF50 /feigao 1208425L Motor
Foam - Cellfoam88 ( 3mm ) / Polystyrene for Fuse
Thunderstruck 22 inch span ( Scaled up Leebospeeds PDF )
W/Span 22 inch
Weight 6 ozs W/O Batt
Motor 1300kv BW/7X6 APC Prop
Wing 5mm Cellfoam 88/Fuse 10mm EPP Doubled up
2 X 9 gram sevo's
12 amp esc
Even being a little bigger and by using the now famous Blue Wonder motor its a perfect match
I was happy with the way it flew with the gusty winds we have at the moment. Rolls like a drill and loops.
Well I scrubed the full fuse version and built a profile version. Putting the motor nearer the tail end has cured the problem of looping. It works fine.
J250 Specs - 17 inch Span
18inch in length
J250 / 4025 Prop
2x 9gram servo ( all I got left )
Weight 4 1/2 ozs W/O Batt
Please Note: the CG is 7" from the front of the wing ( NOT THE NOSE ).
The fusalarge when fitted ( Nose ) is 2 1/4" infront of the Wing.
Rolls like a Drill, Loops well and I'm happy with its flight capabilities. I'm waiting on a few Little Gems from Don, at StrongRC motors to power the bugger ( ELE C20 ), that's why I'm using the Old J250. ( Great little Motor )
Hopefully will have some Video in the next few days of both. Just gotta decide which I'll put up front even though their both the same airframe.
On lighter Note : Any idea's, any comment on the aircraft or idea's would be gratefully appreaciated. Also the other fella's and their aircraft are Fantastic. The contest has brought out many idea's and building techniques, a full Spectrum of the Envelope. I have learned a Great Deal from you all, can't put a price on it, THANKS. Also Thanks to Logical Psycho and the fella's who organised the Contest and the Sponsors.
I have put up my Final Pic of the EDF50
THANKS TO YOU ALL!!!!!!!!!!
Regards Boxhead
Here's a video of the 22 inch and the 17 inch Thunderstruck
Model Plane (2 min 11 sec)
Thunderstruck J250 (1 min 54 sec)
Boxhead is online now Find More Posts by Boxhead
Old Mar 11, 2007, 08:02 PM
Permanently Banned
Larry3215's Avatar
Gig Harbor, Washington, United States
Joined Sep 2003
Great looking plane!
Looking forward to the video
Larry
Larry3215 is offline Find More Posts by Larry3215
Old Mar 11, 2007, 08:43 PM
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Thanks Larry .
I'll try and have the Video up when the wind dies down. Couple more Pics of the Build. Once the Video's done I'll post up some plans if anybody's interested in them.
Box
Old Mar 12, 2007, 07:16 AM
gpw
“There’s no place like Foam”
gpw's Avatar
Joined Jul 2002
Box ... Wow!!! The MT Plate evolves... This looks really good !!! oughta' be a sweet flier...Good luck !!!
gpw is offline Find More Posts by gpw
Old Mar 12, 2007, 02:25 PM
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Thanks GPW . Your right, the MT Plate Theme evolves. Have learnt a great deal doing this one also.
Box
Old Mar 12, 2007, 07:28 PM
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Here's the Video of Thunderstruck - J250 and the EDF50. Both are exactly the same but different power plants on the same airframe. Plans for Thunderstruck are below. Please Note : Lebbospeed has kindly done a Full PDF of Thunderstruck also so now it can be scaled up or down. A Big Thankyou to lebbospeed for his great work.
Please Note: Add at least 1/4'' Reflex to the Elevons.
Cutout for prop is for Reference only.
Adjust slot to suit motor/prop combo you have.
Please Note: The CG is 7" from the FRONT of the WING on 17inch W/Span, Not the NOSE. The fusalarge when fitted
( Nose is 2 1/4" in front of the wing.) I apoligise for any misunderstanding.
Regards Box
Video of the EDF50 and J250
Old Mar 12, 2007, 08:20 PM
Permanently Banned
Larry3215's Avatar
Joined Sep 2003
It flys great! Well done!
Larry
Old Mar 13, 2007, 06:49 AM
gpw
gpw's Avatar
Joined Jul 2002
Yeah !!! It's a Good one all right .... all that on a 250, eh ... COOL !!!
Old Mar 13, 2007, 02:43 PM
registered foam addict
chara's Avatar
Munich, Bavaria
Joined Dec 2004
Box that's a cool little plane! I love tha camo!
good luck for the contest
chara is offline Find More Posts by chara
Old Mar 13, 2007, 03:04 PM
feel no remorse
youth must fly's Avatar
underground
Joined Jun 2004
very nice box, little zoomer
youth must fly is offline Find More Posts by youth must fly
Old Mar 13, 2007, 03:23 PM
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Thanks GPW . Recieved a couple of those Small B/L motors from Don at StrongRC yesterday. So I'm going to throw one of those in and see how she goes.
Thanks Chara . Mate, for me the camo paint work is easy to see and easy to do plus its not a bad look either, glad you like it. I've really enjoyed the Contest. I'm already a winner with all that I have learnt from these guys and the rest of you fella's, yourself, GPW, Gene Bond etc: to many to mention, on RC Groups. The thought, workmanship and ideas that the fella's have displayed not only in the Contest but also on Threads here is Fantastic .
Thanks Youth Must Fly , I drop in on your thread everyday and I'm amazed at your workmanship and style on your Bipe. Thanks for letting us come along for the ride with the Bipe.
There's something different everyday to see and to think about.
Regards Box
Old Mar 16, 2007, 08:10 AM
Memphis, IN, USA
Joined Jan 2001
Box, are you running that j250 on 2s or 3s, and what size lipo? Guessing 2s 700-ish range? Looks like another great easy build! and it so happens I have some j250s sitting around
glovesave39 is offline Find More Posts by glovesave39
Old Mar 16, 2007, 03:52 PM
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Glovesave39, I have been running it on 3 cell 450 mah pack ( 4025 prop )with throttle control. Geeez that self imposed throttle control is hard to do . Havn't blown a motor yet, so, so far so good . 2 cells would be fine. I have just built a third T/Struck using StrongRC B/L motor the ELE C20 (2900kv ). Uses a 4025 prop same as a J250 but pulling around 6amps and it weighs about 20 gr. This little motor maybe the Brushless equivent of the J250. I will probably maiden it Monday and see how this little motor goes. The pic below is ELE C20 and some stats from StrongRC on it.
2500 Kv motor, GWS 4x4 prop, 10.5 V, 5.2 A (good setup)
2500 Kv motor, GWS 4x4 prop, 8 V, 3.6 A (Weak)
2900 Kv motor, GWS 4x4 prop, 7.5 V, 6 A (good setup)
2900 Kv motor, GWS 4x2.5 prop, 10.5 V, 6.3 A (good setup)
2900 Kv motor, SL stock prop, 10.5 V, 5.5 A (good setup)
Regards Box
Old Mar 16, 2007, 04:22 PM
Victoria Super Mortem
UBILDIT's Avatar
BIRMINGHAM ALABAMA
Joined Jan 2006
Box
Wow,
That's good video. I like the melon cam video as well.. LOL... The plane flys great and looks great too. Once again, one that I've got to build. Im partial to the EDF version myself. Nice job.
Bo
UBILDIT is offline Find More Posts by UBILDIT
Old Mar 16, 2007, 04:31 PM
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Thanks UB, I hope to have the EDF Thunderstruck video up next week. So stay tuned !!! Yeh Melon Cam. Got a head like a Robbers Dog . But it still works. Got your PM. Thanks.
Regards Box
Video Thunderstruck J250 and EDF50 Boxhead Electric Plane Talk 3 Jun 26, 2007 01:04 AM
Video M-Tee Plate EDF50 / J250 Boxhead Electric Plane Talk 0 Jan 25, 2007 05:54 AM
