Old Mar 10, 2007, 05:41 AM
radio freak is offline
Find More Posts by radio freak
United States, NJ
Joined Dec 2006
Question
can any one help me identify this part
Can any tell me what this part is. It reads (55J and has the murata logo on it.It has three pins and is approx. 2mm thick.Below are some pics of the part.
radio freak is offline Find More Posts by radio freak
Old Mar 10, 2007, 06:31 AM
Acetronics is offline
Find More Posts by Acetronics
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
455 Khz Ceramic Filter ???
J grade ( = bandwidth )
Alain
Acetronics is offline Find More Posts by Acetronics
Old Mar 10, 2007, 06:35 AM
nick_75au is offline
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
Ceramic resonator?
It may be a ceramic resonator, similar to a crystal used for timing microcontrollers etc, bit of a guess but see how you go.
just looked at the murata website quickly 55j doesnt come up in serches but it does look like a ceramic resonator.
Regards
Nick
nick_75au is offline Find More Posts by nick_75au
Old Mar 10, 2007, 07:20 AM
United States, NJ
Joined Dec 2006
Alain
Can this be used as a ceramic filter in an rc receiver??
Old Mar 10, 2007, 08:43 AM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Of course !!!
Alain
Old Mar 10, 2007, 09:13 AM
United States, NJ
Joined Dec 2006
Of course !!!
Alain
Can you please help me out with the pin identification
Old Mar 11, 2007, 10:37 AM
United States, NJ
Joined Dec 2006
Is there no one who can help me identify the pins on this ceramic filter??
Old Mar 11, 2007, 11:28 AM
Eric_N57105 is offline
Find More Posts by Eric_N57105
RC Bum
Eric_N57105's Avatar
Riverside, CA
Joined Apr 2006
From the orientation in your photo, the pins are USUALLY Input, Ground, Output. However, it doesn't always matter as they are symmetrical designs.
My guess is also that it is a 455khz ceramic filter. If you have a kilobuck spectrum analyzer sitting in a dusty corner of your garage, it is a simple matter to test it and check its response. If not there are some relatively easy test methods based on using a software audio spectrum analyzer like Spectrogram.
Here's a link to get you started. It is a procedure for adjusting filters in an Elecraft amateur radio transceiver. Most of the details will be meaningless, but it should give you an idea of the technique which you can easily adapt to testing ceramic or crystal filters.
http://www.elecraft.com/Apps/new_fil...ilter_apps.htm
Google Spectrogram as well and you will find a lot of similar articles. It's a great tool for receiver design. Cool Edit is another one that works well for me.
Eric
Eric_N57105 is offline Find More Posts by Eric_N57105
Old Mar 11, 2007, 01:23 PM
United States, NJ
Joined Dec 2006
Hello and thanks to everyone who tried to help me out. I found the part and I am attaching a PDF link for future reference for everyone.
P.S.The murata manual says filters for AM use, does this mean they cannot be used on an FM receiver??
Old Mar 13, 2007, 07:16 PM
RC Bum
Riverside, CA
Joined Apr 2006
No. Generally, AM radios use a 455khz IF and have bandwidths of around 6 khz. FM radios normally use a 10.7 mhz IF and have wider bandwidths. Even narrow band FM is more than twice as wide as AM. You can see that in their specs.
So, generally, the AM ceramic filter is going to be more selective, i.e. better at rejecting adjacent channel interference which is a good thing for an RC receiver.
Eric
Old Mar 13, 2007, 08:48 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Narrow band FM such as we use uses 455KHz filters just like AM. The bandwidth is similar. Well actually in the USA the channels spacing is 10KHz whereas AM radio is 9KHz.
UK spacing is IIRC 20Khz.
10.7 MHz filters are used in broadcast FM (400 KHZ bandwidth) and the the first IF of dual conversion receivers.
Old Mar 14, 2007, 06:00 AM
United States, NJ
Joined Dec 2006
thanks for the info people
Help! Help me identify this part tomskk DIY Electronics 6 Apr 10, 2006 01:49 PM
Can some one help me with this choper woodsy Micro Helis 22 Nov 16, 2004 04:10 AM
Cool Is it a P-40? Can you help me identify this aircraft temp_oct Parkflyers 1 Jan 04, 2004 11:46 PM
