Old May 09, 2011, 01:19 PM
Thekid3418 is offline
Find More Posts by Thekid3418
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
My Escape is finally ready to go for the 2011 season. I installed my new MEGA 16/40/2 motor, which went in without a hitch, and actually seems to help balancing, as I no longer need to shove the battery as far forward as possible.
Since this motor has a 4mm shaft, it no longer was going to work with the spinner I had. So this left me with three options: try to mill out the collet that I had (inaccurate), invest in a new spinner from tru-turn (~$30), or use a standard collet adapter (draggy!).
What I settled on you can see in the picture. I didn't want to invest in a new spinner just to have this be a failed experiment. So I put a block of balsa on the nose and sanded it down to shape. The result is much nicer in person then it is in the photos but it is a nice and slick transition.
With the 6.5x10 I am at ~500W on 3s, ~900W on 4s (and 18k RPM), and 5s is yet to be seen. This should make a nice growl when in the air compared to my Sunracer which will now get the 1112-2D and scream around the sky. Hopefully this plane will be faster still though!
Thekid3418 is offline Find More Posts by Thekid3418
Old May 11, 2011, 11:19 AM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
I got to remaiden my Escape today. Flying it back to back with my Sunracer was quite fun as it gave the 4-stroke vs. 2-stroke feel. I could only guess that top speed is 170+ on 4s, hopefully i'll hear its even higher! But whats most important is the sound is AWESOME, and everything comes down cool, so its still an option to use a full 7x10 prop, or move up to 5s with a slightly smaller prop.
Escape Pylon: Mega Motor (0 min 52 sec)
Kid
EDIT: The doppler turned up with speeds around 180mph, with the fastest coming in at 188mph down wind (5 mph)! Now I just need to find a battery thats not old and crudy and this thing should be absolutely ballistic!
Old May 11, 2011, 03:34 PM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
awsome kid.....
How are the launches, does it torque much with that propp ?
sebbe is offline Find More Posts by sebbe
Old May 11, 2011, 04:28 PM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Launch is done at ~1/3 throttle and there was not a hint of torque roll. This is something that surprised me slightly, as I expected there to be some torque involved. Fortunately my dad is a very skilled launcher and handled it without a hitch!
Kid
Old May 11, 2011, 07:33 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Very cool setup kid. 5S is gonna be nuts!
How many rpm is it pulling?
jackosmeister is online now Find More Posts by jackosmeister
Old May 11, 2011, 08:39 PM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
I'd be interested to know as much as you! I could only guess its around 18k once unloaded in flight. I'm also am going to guess I can get another 1000RPM or so out of a newer, stronger battery (I have my eye on some 2000mah 45C). Unfortunately, my wonderful Leader Dog in Training choose to have his one of his brightest moments and ate my castle link last night, so I can't download the logged data at this point.
I'll be sure to post here once I do get a new castle link.
Kid
Old May 11, 2011, 08:44 PM
Auckland NZ
Joined Aug 2007
HAHA! Awesome.
Old May 11, 2011, 09:11 PM
KRProton is online now
Find More Posts by KRProton
Tim Lampe; Hobbico R&D
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Kid, you need to get a cat...
KRProton is online now Find More Posts by KRProton
Old May 12, 2011, 01:44 AM
Flyextreme is offline
Find More Posts by Flyextreme
Sure it'll work
Flyextreme's Avatar
United States, CA, Redondo Beach
Joined Nov 2005
My dog chews on nothing...both of my cats chew on everything...yuh never know.....
Flyextreme is offline Find More Posts by Flyextreme
Old May 12, 2011, 06:04 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Kid, thats sounds good, how about landing with these larger stiffer propps ? isnt there a risk for tearing the motormount off if the propp garbs on some grass or hole on landing..
Old May 12, 2011, 10:35 AM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Landing with these planes always comes with its own set of challanges. The first landing with this new setup was pretty bad, as it was pretty nose heavy and I couldn't bleed as much speed as I wanted. But so far so good!
I just do my best to get the prop level with the ground and then hope for the best from there!
Kid
Old May 14, 2011, 07:59 PM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
My Escape died a rather disappointing death today, in that it didn't slam into the ground at a billion MPH. I lost motor response and in the process of setting up for landing, lost all control and it slowly rolled into the weeds on the far side of the runway from about 100 ft!
Fortunately, it rained pretty heavily all last night, meaning the ground was slightly softer then usual. The fuselage isn't in too bad of shape, and is basically done being repaired (just need to trim some glass and paint!). The wing is torn up pretty badly, especially in the center section due to the mounting bolt. I've starting repairing it, but it is going to be no easy process. At best this will now be a sport plane. But it'll be fun to work on my repair skills!
The problem is yet undetermined. The ESC refuses to arm, but that could be because it was mashed between the motor and battery, which both survived. Either the ESC overloaded and shut down (unlikely, as I wasn't consuming that much power!), or what I suspect is the flight pack just came unplugged from the ESC.
She lived a good life! I got at least 100 flights out of my Escape over the last two summers, and got to test all kinds of fun setups. Hopefully, this isn't the last time i'll get to fly her. But either way, its on to bigger and brighter things!
Kid
Old May 14, 2011, 08:20 PM
Auckland NZ
Joined Aug 2007
Dude, that sucks.
Wonder if a stilleto wing will bolt on?
Old May 15, 2011, 08:43 AM
Goinav8n is offline
Find More Posts by Goinav8n
Jeff Carr
Ft. Mill SC / Charlotte NC
Joined Mar 2001
Kid
I know your pain. LOL I really enjoyed my Escape and wish I could get another as it was fun to fly. I wish someone would report on the Stilleto as I havent seen anyone who has a flight report yet. Its still 100.00 bucks more but maybe an alternitive
Jeff
Goinav8n is offline Find More Posts by Goinav8n
Old May 15, 2011, 10:05 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
sorry man, been there with my escape to, ( esc shut down after 2-3 seconds= krasch), But I also did repair her, and she flyes better then before...
Fix her, and up in the air again..
New Product New Pylon Racer- VOODOO Vince123 High Performance 2343 Today 08:37 AM
Discussion New pylon racer.. whatcha think? threcixty High Performance 7 Jul 30, 2006 11:10 PM
Spirit 400, my new pylon racer! Thomas Manson Parkflyers 2 Aug 31, 2003 08:07 PM
New pylon racer launch system sneu High Performance 5 Feb 13, 2003 04:22 AM
T-Strike, a new pylon racer! Harm Botman High Performance 15 Jan 25, 2002 06:26 PM
