Old Sep 26, 2010, 05:38 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Im impressed you have a 5.25x6.25 that balances! I have 3 of them, and they are all so outta whack that id have to clip half the blade on one side to get them to balance
Yup, need video
jackosmeister is online now Find More Posts by jackosmeister
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Originally Posted by biskit View Post
Nice and windy today so I got in a couple flights. Since switching to the 12x12 graupner I am launching without worry now, dead level every time. I think the 5x5 apc is just bad at low speed and makes too much torqueand not enough thrust for me. I want to try the 13x13 but it pulls too much current for my esc and battery.
Thinking about a slicker plane, even at 500w my escape is starting to seem slow. It's my first composite plane, from reading on here I get the impression it is draggier than other comparable planes? Any suggestions for something that's a step up in performance?
Hello, well I dont see or feel any differance between APC or Graupner in my Escape, its random, sometimes it goes well, sometimes I have to change my pants ....
The Problem is the Escape, when launching my Turn Left, it does NOT have this problems at all....
So you say your escape is slow ? hehe, maybee you have been used to that speed now... My Escape is faster then My Turn Left with the same power..
If you want something faster, try a F5D ship like the Viper or Demon , now this baby can take 2000 watts , no problems, if you think that is to slow , well then you have to start doing rockets or something like that, ..
Sebbe..
sebbe is offline Find More Posts by sebbe
Old Oct 03, 2010, 02:22 AM
Thekid3418 is offline
Find More Posts by Thekid3418
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Yup, need video
It needed to be balanced a little. But with the right amount of WBPU it turns perfectly true. I have yet to find a prop that I could not balance with this method and a simple finger tip balancer (placed on a set of parallel, vertically aligned razor blades).
I have flown this setup ~5 times and I even got to fly it back to back with my Graupner 5.5x5.5 (which draws about the same static current). The 5.25x6.25 averages about 800W unloaded in flight, while the Graupner draws ~725 unloaded. The speeds are so hard to tell when they are this high. But the 5.25x6.25 is noticeably faster, especially out of a dive. But it drops a lot of speed in the turns, or so it appears.
My guess would be 185mph, perhaps 190+ out of a good dive. I'll have to attempt to get a video sooner or later...though it likely won't come until next summer!
Kid
Thekid3418 is offline Find More Posts by Thekid3418
Old Oct 03, 2010, 06:53 AM
skyzking is offline
Find More Posts by skyzking
smokin electrons...
skyzking's Avatar
Brisbane, Australia
Joined Jan 2007
Does this plane have any issues with flutter after certain speeds?
I have a 1506/3D which needs a home on 4S, will it be suitable for this plane?
Anyone have any pics of Escapes with 15xx motors?
skyzking is offline Find More Posts by skyzking
Old Oct 03, 2010, 10:19 AM
G.P. is online now
Find More Posts by G.P.
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
I have not read a single report of flutter. The airframe is discontinued though.
G.P. is online now Find More Posts by G.P.
Old Oct 03, 2010, 11:51 AM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
Personally I have gone to speeds of 185mph or more and never experienced any issues whatsoever. Even when doing pylon turns at full speed the wing doesn't show any indication of bending.
That being said, I think you will REALLY struggle to get the airframe to work with the 1506. You'll have to trim the nose shorter to make it fit, which means you'll rapidly run out of room. On top of that, the plane tends to be tail-heavy. With that fairly light motor (about the same as a 1115 if memory serves) being closer to the CG your balance issues will only be higher.
To top it all off, as G.P. said, the Escape is no longer being made! I have had dreams that Jiri will make a second one. Something with a slightly longer nose (but only just), and thinner h-stab airfoil, and a slightly thinner wing. I love the square fuse of the Escape! Much more pain free then the Sunracer!
Old Oct 03, 2010, 10:17 PM
Auckland NZ
Joined Aug 2007
I concur.
Old Oct 04, 2010, 12:21 AM
skyzking is offline
smokin electrons...
skyzking's Avatar
Brisbane, Australia
Joined Jan 2007
So they are not available anywhere anymore?
Old Oct 04, 2010, 12:45 AM
Auckland NZ
Joined Aug 2007
Bingo.
Old Oct 08, 2010, 03:25 PM
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
I got a nice new package in the mail
It'll spin a 6.5x10 at ~19k rpm on 4s.
Or a 6x9 at ~25k rpm on 5s.
Should haul some serious butt. And make a cool sound to boot!
Kid
Old Oct 08, 2010, 03:45 PM
Auckland NZ
Joined Aug 2007
Cool beans, I wonder what sorta rpm itll spin an aeronaut 8x9.4 (8x7+5degree) folder?
I have that prop on my wasp, with a 16-25-2.5SC4 (1840kV) and it &*^ks off, but the 40 should be able to handle much more boogey, if the prop will hold together
Old Oct 18, 2010, 05:37 PM
TheBlood+ is offline
Find More Posts by TheBlood+
Heavy thinker..I mean tinkerer
TheBlood+'s Avatar
Canada, ON, Aylmer
Joined Apr 2009
Been looking thru this thread for a while now just havn't had anything to add yet...and wow lots of good info, I've been flying my Escape for the whole summer and absulutely love this plane!
I started out flying it with a E-Flite six series 2700kv motor, and a turnigy plush 60, and it was fun, but now I'm flying it with a NEU 1110/1Y and a 4.1x4.1 apc prop with a 2200mah 3s 40C pack and wow what a raging psycho of a plane now, love it.
I had one mishap with it when I was landing and caught the stab on a hydro wire a tore half of it off but landed it ok. Goinav8n (Jeff) helped me out with one of his stabs from some of his carnage, back up and runnin again.
I realize that they aren't made anymore and thats too bad, but I did just manage to score another one as of late, with a couple of very minor scrapes for a spare, which I'm very happy about.
Keep th thread going guys.
Cheers
TheBlood+ is offline Find More Posts by TheBlood+
Old Oct 18, 2010, 06:00 PM
TheBlood+'s Avatar
Canada, ON, Aylmer
Joined Apr 2009
I also have an 1105/1.5Y, what would it be like compared to the 1110/1Y that I'm running right now?
Old Oct 18, 2010, 10:05 PM
LifeisGood is offline
Find More Posts by LifeisGood
Joined Apr 2006
1110-1Y out runs 1105. Actually, if any, go with 1115-1.5D 4S 4.1X4.1 with a cc125
LifeisGood is offline Find More Posts by LifeisGood
Old Jan 02, 2011, 01:24 AM
Dan the man is offline
Find More Posts by Dan the man
Sydney Kingsford, Australia
Joined Feb 2004
Hey Guys,
I've had my eye on the Escape for a while. I'm currently flying a Top Model Stinger, 3S Lipo, Mega 16/15/4 and 5.2 x 4.8 prop. I love flying this plane to death but I am looking for the next step up in speed.
Do you reckon the Escape could be a good candidate?
All the Best
Danny
Dan the man is offline Find More Posts by Dan the man
New Product New Pylon Racer- VOODOO Vince123 High Performance 2397 Sep 17, 2016 03:47 PM
Discussion New pylon racer.. whatcha think? threcixty High Performance 7 Jul 30, 2006 11:10 PM
Spirit 400, my new pylon racer! Thomas Manson Parkflyers 2 Aug 31, 2003 08:07 PM
New pylon racer launch system sneu High Performance 5 Feb 13, 2003 04:22 AM
T-Strike, a new pylon racer! Harm Botman High Performance 15 Jan 25, 2002 06:26 PM
