Old Mar 07, 2007, 08:37 AM
RegionRC is offline
Find More Posts by RegionRC
Joined Feb 2007
Depron Cessna 172 Skyhawk "trainer"
Hi Guys,
I'm new to this forum, but i wanted to share my new build. A Cessna 172 Skyhawk 34". A good trainer model made from 6 and 3 mm depron. Plans will follow shortly. But first a sneak preview.
RegionRC is offline Find More Posts by RegionRC
Old Mar 07, 2007, 11:37 AM
JelleB is offline
Find More Posts by JelleB
Time for another motto!
Utrecht, The Netherlands
Joined Jul 2006
I'm interested how this one will work out. Are you making a full fuse?
Jelle
BTW: put a wetsone on your table to sharpen your depron-cutting knife regularly. You won't get tears if you use a very sharp knnife.
JelleB is offline Find More Posts by JelleB
Old Mar 07, 2007, 01:36 PM
RegionRC is offline
Joined Feb 2007
Hey JelleB,
Thanks for the tip, i designed it to be a scale / semi-scale model. It will get a full fuse. I use a laminate design. The fuse consists of 13 laminate pieces. To give form to the fuse i designed molds for sanding. Thats why it looks roughcutted as well. It's about 3 mm thicker than scale.
I've got to finish the build first before i can finish the plans. I'll post my progress.
SpleenRippa is offline
Find More Posts by SpleenRippa
Yes, right there.
SpleenRippa's Avatar
Comox, BC, CAN
Joined Jul 2003
Oi, those cuts are making -me- hurt! Poor Depron!
Nice outline, though :-)
SpleenRippa is offline Find More Posts by SpleenRippa
Old Mar 07, 2007, 01:47 PM
RegionRC is offline
Joined Feb 2007
Here's an update, put 5 pieces together
Old Mar 07, 2007, 02:43 PM
JelleB is offline
Joined Jul 2006
I can see what you are trying to create, but are you sure that the method you chose is the best one. Looking at the fuse sections it looks mostly sqare with rounded corners, only the cowling is a complex curve. http://richard.ferriere.free.fr/3vues/cessna182_3v.jpg (ok that is a 182, not a 172)
Old Mar 08, 2007, 06:23 AM
RegionRC is offline
Joined Feb 2007
i don't know if the method i'm using is the best one, thats something i have to find out for this model. I made other models using this method en they where great. I alwas start with a square shape and then round it of by sanding with help from a mold. This method i'm using, i'm using it only for the fuse.
SpleenRippa : I don't mind spoiling some depron in the proces because i get it cheap
Old Mar 09, 2007, 04:39 AM
RegionRC is offline
Joined Feb 2007
Hey Guys here's an update,
I now have 9 pieces laminated and it's starting to look more a plane then slices of depron.
And a comparison to my other build the Shumate F/A 18
Old Mar 09, 2007, 04:48 AM
RegionRC is offline
Joined Feb 2007
Here are the first plans for the model. This is still a rough design so if you have tips let me know...
The first is the centrepiece the main former. Print out and cut and tape together.
The print outs are A4 format.
Old Mar 09, 2007, 04:49 AM
RegionRC is offline
Joined Feb 2007
These are layers 2 and 3 for each side of the center
Old Mar 09, 2007, 04:51 AM
RegionRC is offline
Joined Feb 2007
The next layers are number 4 and 5. Again glue one to each side
Old Mar 09, 2007, 04:54 AM
RegionRC is offline
Joined Feb 2007
The next layers are number 6 trough to 9. Again glue two to each side
Old Mar 09, 2007, 04:56 AM
RegionRC is offline
Joined Feb 2007
The next layers are number 10 and 11. Again glue one to each side. Thats all for now. two more layers coming and then the horizontal stab and rudder. Followd by the main wing. Good luck on building
Old Mar 09, 2007, 10:19 AM
RegionRC is offline
Joined Feb 2007
Here is another buildupdate. Progress is going well. I've got the shap in the fuse. Nextup is smoothsanding and then wingbuilding.
Old Mar 09, 2007, 11:01 AM
punkrockd is offline
Find More Posts by punkrockd
Purples a fruit
punkrockd's Avatar
United States, CA, Walnut Creek
Joined Aug 2006
very nice, i really like this type of build.
punkrockd is offline Find More Posts by punkrockd
Build Log Guillows Cessna 172 Skyhawk my first RC kit ruffnite Beginner Training Area (Aircraft-Electric) 20 Feb 07, 2009 08:05 PM
GUILLOW'S CESSNA 172 SKYHAWK conversion to electric. reznikvova Parkflyers 25 May 03, 2008 12:56 AM
Cessna 172 Skyhawk 3-views? Gordon Scale Kit/Scratch Built 10 Nov 17, 2003 11:24 PM
Cessna Skyhawk/Trainer Seraph Foamies (Kits) 6 Jul 15, 2003 06:59 PM
Cessna 172 Skyhawk Grave Digger Scale Kit/Scratch Built 0 May 08, 2003 06:38 AM
