Old Mar 06, 2007, 12:01 AM
idealera is offline
Find More Posts by idealera
idealera's Avatar
Joined Aug 2006
Cool
Attention! Here comes the wonder of DLG world
All Balsa DLG
Wing Span 1230mm
Fuselage Length 935mm
Wing Area 14.64dm2
Flying Weight 220g
Your comment is welcome!
idealera is offline Find More Posts by idealera
Old Mar 06, 2007, 12:03 AM
idealera is offline
idealera's Avatar
Joined Aug 2006
Control surface:
Aileron
Elevator
Rudder
Old Mar 06, 2007, 12:26 AM
Endless Sloper is offline
Find More Posts by Endless Sloper
Rick Rogahn
Endless Sloper's Avatar
Seattle, WA
Joined Jun 2005
Dihedral?
Endless Sloper is offline Find More Posts by Endless Sloper
Old Mar 06, 2007, 12:42 AM
idealera is offline
idealera's Avatar
Joined Aug 2006
Originally Posted by Endless Sloper
Dihedral?
2 degrees
In fact while it flys in the sky the dihedral would be around 3 degrees
Blasa's elasticity matters
Old Mar 06, 2007, 01:51 AM
Rick Rogahn
Seattle, WA
Joined Jun 2005
That for increased launch height? What kind of boom did you use? Looks aluminium...
Old Mar 06, 2007, 02:11 AM
idealera is offline
idealera's Avatar
Joined Aug 2006
Bingo
aluminium tube
Old Mar 06, 2007, 05:53 AM
bobthenuke is offline
Find More Posts by bobthenuke
70 is the new 50
bobthenuke's Avatar
United States, AZ, Peoria
Joined Feb 2005
Looks great...nice and clean. So, how does it fly?
...bob
bobthenuke is offline Find More Posts by bobthenuke
Old Mar 06, 2007, 12:30 PM
Jim Walker is offline
Find More Posts by Jim Walker
Fixed Wing Fanatic
Jim Walker's Avatar
United States, TX, McKinney
Joined Jul 2001
Very nice looking plane, construction looks flawless. The total weight and the wing loading are definitely on the heavy side though.
Jim Walker is offline Find More Posts by Jim Walker
Old Mar 06, 2007, 02:31 PM
kimhey is offline
Find More Posts by kimhey
kimhey's Avatar
nøtterøy, NORWAY
Joined Mar 2006
Looks like the BlueArrows ANGEL´s Bigbrother. COOL...
Is it only rudder, or aileron as well? Reason for asking is that I have a wing with 3 degrees dihedral, and wonder if I will be able to control the glider with only rudder.
( have not bothered to finish the DLG yet, because of this, so curious how your glider performes).
Kim
EDIT: Ops just read that you have aileron... Ever tried rudder-only turns?
kimhey is offline Find More Posts by kimhey
Old Mar 06, 2007, 11:49 PM
idealera is offline
idealera's Avatar
Joined Aug 2006
For your information
Old Mar 07, 2007, 03:01 AM
Bretty is offline
Find More Posts by Bretty
Follow my drift?...
Rutland, England
Joined Jul 2006
Nice looking model. What, if anything, did you use to reinforce the wing spars in order to take the cf loads? And what sort of launch heights are you getting?
Andy
Bretty is offline Find More Posts by Bretty
Old Mar 07, 2007, 06:49 AM
Alex Hoekstra is offline
Find More Posts by Alex Hoekstra
Alex Hoekstra's Avatar
Hurdegaryp Netherlands
Joined Feb 2007
Kim
For rudder only your dehedral should be at least 10 to 12 degrees both sides.
For aileron i would suggest 5 to 7 degrees to have maximum control in thermals.
With only 3 degrees you will probably loose more hight every turn you make then the loss you would have(if there realey is loss) with more degrees dehedral wings during launch. 3 degrees wings won't let you control the plane by rudder only.
Alex Hoekstra is offline Find More Posts by Alex Hoekstra
Old Mar 07, 2007, 07:05 AM
dougmontgomery is offline
Find More Posts by dougmontgomery
dougmontgomery's Avatar
Glendale,Az.
nice looking, doug
dougmontgomery is offline Find More Posts by dougmontgomery
Old Mar 07, 2007, 10:52 AM
Rick Rogahn
Seattle, WA
Joined Jun 2005
Looks very clean for sure. Could stand to loose some weight I think as well. Looking @ the picture of your rudder and vertical stab, you might be able to sand them down a bit.
Old Mar 07, 2007, 11:09 AM
kimhey is offline
kimhey's Avatar
nøtterøy, NORWAY
Joined Mar 2006
Ooch.... Just what I feared. And that why the wing has not got a fuselage yet...
Thanks for the reply Alex,
Kim.
Cool Here comes new Kokam JJ HONG Batteries and Chargers 197 Feb 07, 2003 11:02 AM
Here comes the Hunn! Zeroaltitude Foamies (Kits) 0 Dec 04, 2002 12:20 PM
Logo10 in Airwolf(here comes the Video!!) Hsin Liu Electric Heli Talk 7 Sep 19, 2002 04:26 AM
Plz direct your attention here =) Arisaka Electric Heli Talk 0 Jul 05, 2002 01:41 AM
Watch out Wedgie, here comes the Zipper!! slowflyer Foamies (Kits) 6 Dec 15, 2001 09:26 PM
