Old Mar 05, 2007, 06:30 PM
Fishmasterdan is offline
Find More Posts by Fishmasterdan
Stanwood WA
Joined Jul 2003
Discussion Big prop or small prop.
Ok I have been toying back and forth with what is better for 3d flying.
Would you rather fly a prop at 12,000 rpms with a 14x8 prop or at 6,000 rpms with a 17X10 props??
My dilema is go with a 6s 1000 watts or 5s 1000 watts.
I have 5s batteries but can easily upgrade to 6s. However I think I want the bigger prop for 3d fun. 1000 watts on 5s is a bit higher amps but is also lighter in overall weight.
Please respond with your opinion and what you liked better.
Fishmasterdan is offline Find More Posts by Fishmasterdan
Old Mar 05, 2007, 06:43 PM
Jeffery is offline
Find More Posts by Jeffery
And You're Not
Timbuktu, Mali (Happy?)
Joined Oct 2002
I don't know that the 14X8 is gonna turn twice the RPM as the 17X10 on the same watts.
Jeffery is offline Find More Posts by Jeffery
Old Mar 05, 2007, 07:36 PM
Daniel Z is offline
Find More Posts by Daniel Z
Daniel Z's Avatar
Joined Dec 2004
for 3d it is always desirable to use large props, 2 main reasons :
a) A more powerfull gyroscopic efect makes high alpha (sub stall) flight easier because the hole plane acts more stable and predictable
b) The big disc of air makes your moving surfaces more effective at 3d
I think the difference is quite big
Daniel Z is offline Find More Posts by Daniel Z
Old Mar 05, 2007, 07:44 PM
zaksdad is offline
Find More Posts by zaksdad
zaksdad
USA, TX, DeSoto
Joined Apr 2006
This is pretty much the same question I asked recently as far as the props are concerned, and what I wanted to know is which size range better take's advantage of an electric motors instant torque,sorry don't meen to hijack thread i just thank we're asking the same question.
zaksdad is offline Find More Posts by zaksdad
Old Mar 05, 2007, 07:51 PM
Jeffery is offline
And You're Not
Joined Oct 2002
I don't agree about the gyroscopic effect. If you want your plane to change attitudes very quickly, moving a huge prop disc is a hindrance.
Old Mar 05, 2007, 07:52 PM
Challenger 413 is offline
Find More Posts by Challenger 413
Challenger 413's Avatar
Dickinson, Tx.
Joined Sep 2004
What plane is this going into?
Challenger413
Challenger 413 is offline Find More Posts by Challenger 413
Old Mar 05, 2007, 08:12 PM
Daniel Z is offline
Daniel Z's Avatar
Joined Dec 2004
jeffery, to achieve some extreme maneuvers is where the CG, control surfaces and angles acts primary, so the big prop helps you to do some 3d with presition, without unwanted behaves from the plane
As a fact, 40 old sized planes were flown at more speed on 10´props, today we use 13 and 14´for 3d planes (if we think about nitro), and 8´on pylon racers
Old Mar 05, 2007, 08:23 PM
Jeffery is offline
And You're Not
Joined Oct 2002
Right. So when you slap a 17" prop on a 40 sized plane the gyroscopic effect starts to make the plane harder to depart from it's heading into 3D. The control surfaces on most 40 sized planes aren't large enough to overcome the effect of the 17" prop, but can manage a 14" prop. What would you do, put a 20" prop on a 40 sized plane? It works against you.
And I will add that I have 40 sized electric 3D planes and have tried the larger and the smaller props.
Old Mar 05, 2007, 08:32 PM
Jeffery is offline
And You're Not
Joined Oct 2002
Try Here
And Here
Old Mar 05, 2007, 09:39 PM
NumbSkull is offline
Find More Posts by NumbSkull
I used to be all thumbs...
NumbSkull's Avatar
United States, KS, Pittsburg
Joined Mar 2005
But what if we were talking about a 60 size plane, not a 40? A 14 inch prop isn't to small, and a 17 isn't to big for a 60 size 3D plane. So of the two, what would be best..
In my opinion, it's all comes down to your "style" of 3D. Jeffery, your explanations are correct that the 14" prop will let you change heading with less resistance, and strain on the airframe, but you might notice the loss of airflow over your control surfaces in hover and beyond stall situations. The 17" prop will help those situations. It will help a hover due to more gyroscopic effects as well as harrier and other high alpha flight, but it will slow down those "twitchy" fast transitions. It will hinder some of the other none twitchy stuff as well.
I had a Groove V2 (not really a 3D, but stay with me) that loved to do flat spins, knife edge spin, blenders and such, until I upped the motor to something with more power, and added 2 inches to the prop diameter... It lost that spin characteristic VERY fast. Yes, it now will harrier at a higher angle, and is rock solid while doing it, it's not a hovering plane, but with the 12 inch prop, it will easily stay in a hover, but for me.. that's not what the plane is about, needless to say, I'm in process of reverting to the smaller prop.
It all comes down to preference, If you like fast transitions, and like to use your space while flying, then a smaller prop is for you, if you just want to hang on the prop, and spend all your time in high alpha doing a few waterfalls and knife edges and harrier rolls, then take the larger prop, it will help to stabilize the plane.
When I first started reading up on foamies, everyone was flying 8 inch props on 30 inch planes (give or take) I always thought a larger prop would do better, until I tried it, took full throws to turn it, but it would "hang" with the best of them.
Disclaimer: I'm in no way saying that in a 60 size 3D ship with a 14 inch prop you will not be able to hover, or with a 17 inch prop, you wont be able to make the plane pop and snap, but the tendencies will change the way the bird "feels" with the different props.
NumbSkull is offline Find More Posts by NumbSkull
Old Mar 05, 2007, 10:06 PM
ss2p is offline
Find More Posts by ss2p
Paul Teesalu
ss2p's Avatar
Goleta, CA
Joined Aug 2006
Small props for fast flying; large for slower *3D* type of flying.
ss2p is offline Find More Posts by ss2p
Old Mar 05, 2007, 10:25 PM
Stanwood WA
Joined Jul 2003
This is going on a Yak 52 from nitro planes. http://www.nitroplanes.com/yak523d5056n.html
I am more of a hover high alpha guy but like to do tumbles on occasions.
I have the 17X10 on there now and it spins up ot 6000 rpms now. I was told by a person with the same motor that it spins a 14X8 at 12000 (not confirmed but I have no reason not to believe them).
Old Mar 05, 2007, 11:00 PM
Daniel Z is offline
Daniel Z's Avatar
Joined Dec 2004
Jeffery, I have read your links, and I agree with you in not to use a 20`prop on a 40 size plane that would be overkill, but I just wanted to post a "rule of thumb" opinion not thinking about plane size
Anyway, the europeans love their diablotins (1500 wingspan) on 17 or 18`props, jason shulman has one also
Fishmasterdan, that plane is is not a super light wing loading plane so, whatever you do just keep it light, setups rocketing out of hover are heavy and are very difficult to control when 1 click can be too much or too little for controled 3d; just my opinion
Big or small prop? himszy Submarines 6 Aug 04, 2005 10:22 PM
Wind-milling Prop or Stopped Prop? Slow Riser Power Systems 47 Jan 12, 2004 07:56 PM
IPS motor breakin= Prop or no Prop? jayboy Parkflyers 13 Mar 25, 2002 10:56 AM
Big prop-low rpm or small prop-high rpm Ninjak2k Power Systems 10 Feb 13, 2002 04:28 PM
Big sailplane, or Small HLG for first sailplane Paul Susbauer Electric Sailplanes 3 May 02, 2001 07:34 AM
