| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#46 | |
<- Balsa flies better ->
Anyone know if it's available here yet ? //Peter
#47 | ||
The Revegetator
Hi David
I wish the aileron servos were a better fit though, but that's not a big deal. I am waiting for an esc to arrive in the mail and hope to be flying it in the next couple of weeks.Quote:
#48 | |
Chuck it and see!
Location: Godmanchester near Huntingdon near Cambridge in England
Graupner Speed Last edited by Wing-span; Mar 29, 2007 at 05:26 AM. |
#49 |
The Revegetator
This Lanyu doesn't come with a motor mount. What is the best material to use, and what is the easiest way to determine its diameter so the motor shaft sticks out of the fuse enough for the spinner to fit on nicely. I have heard that circut board is good for motor mounts. Where do you get a clean piece of it or should I go for something else?
Chris. |
#50 | |
Long before I was given 2 of them from a good friend due to a bet/ joke with my friend.... In fact it had been discussed / identified by several experience Belgium F5B competitors in several thread about NESAIL Euro made copy called WILCO or sth,.it appearrs in the website of Graunpner as SPEED.( no original design out there as it should be,according to some who had flown the TRUE copies.. called ?? EVOLUTION or sth.). Hope it helps . David OK , I am going to FIGHT with the PC/vid cam.to donw load some pics I think it would help others in assembly of this 'F5x'. Last edited by C-MIC; Mar 30, 2007 at 07:07 AM. Reason: wrong words correction |
#51 |
Upside down Miss Jane....
Chris,
Circuit board is the generally the go. You can get it from Jaycar or most Dick Smith outlets. If your pedantic (like I am) you can etch the copper off, otherwise leave it on or sand it off. You can get the etchant - ammonium persulfate - from these guys too if you want to go this route. Just don't get bread board, you want just the plain PCB For lower power options a piece of 3mm ply would work fine too Generally you want the mount to sit back from the nose of the fuse 1 or 2mm - just enough so the motor mount screw heads do not interfere with your spinner. I also usually file in some v-grooves or drill small holes on the very outer ring of the mount so that the glue has something to get a good purchase on between the fuse and the motor mount. hope this helps. ![]() cheers, Shawn |
#52 |
The Revegetator
Thanks Shawn,
That helps a lot. I'll only be using a power system capable of about 600 Watts to start off with, but I'm sure I will want to upgrade so I'll get some PCB. Chris. |
#53 |
I have tried hard to make things in details, but always have problem when I press submit, it .....
just few words about the #2: --it is a so called 'export version' but it has no difference in builds quality except NO DING AND DENT , and its cheaper too. --I intend to build it light and use what i have on hands, spend least time and money. --my goal of power= power to weight ratio= 150w/lb , that little outrunner weighs 60grs net and rated as 450w. It is a H version, and it is mated to a kontronik kpg27,5,2:1 ratio. Chris, How is your build? When to maiden.pics? David. Last edited by C-MIC; Mar 30, 2007 at 11:45 AM. |
#54 |
The Revegetator
Thanks for that David,
I really like how you strengthen the motor mount area with the carbon fibre cloth using the balloon. Do you think I can get away with not doing that? I would very much appreciate a thread on the cheap Chinese motors you have used. I'm sure the cost of high quality motors puts a lot of people off getting into hotliners. Some of the cheap stuff will do the job for sports flyers that want to try out these models. Today I will be buying some Shoe Goo; I found a place that sells it yesterday. I will also buy some cheap callipers, a drafting compass and some PCB to make my motor mount. I'll take some pics soon when I glue in the servos. Maiden will be when I get the esc. Chris. |
#55 |
earth belowus drifting falling
Be carefull with the goop. If you use to much you'll get warped surfaces. Ask me how I know. Even the fumes of that stuff does damage so please use only as much as you need.
Ron. |
#56 | |
I dont think it will have any problems without any reforcement at lower power, say 1kw. Got several other hotliners are built as stock. I did that for : -- I need to make firewall anyway, adding bit of extra works is nothing. -- that way I could check out if the UK ad of it about 300-3kw is right with more peace of mind I may put an oversized motor into it without worry or excuse when it failed.( hopefully not).I will try the NEW way of mounting servos in this light bird, the servo itself is also new to me too, Futaba's digi-3154. Anyone tried them and comments pls? David |
#57 | |
The Revegetator
I'll try to use as little as possible. I've never used it before so I hope my idea of as little as possible is enough. We'll see
#58 |
Chris if your concerned about shoe goo another method is to wrap your servos in heat shrink, roughen up the shrink and epoxy them in.
If you ever need to get them out its just a matter of slicing the heat shrink. Once the servos out you can then carefully peel off the shrink and your left with a perfect bed for refitting a servo in the exact position. cheers, Shawn |
#59 |
The Revegetator
Hi Shawn,
If I wrap the servos with heat shrink I will have added the depth of servo case I have already ground off and the servos will no longer fit. They just fit now. I am tempted to get the HS125MG's and do the shrink-wrap, but after butchering these ones I feel I should use them. I'll see how I feel about it in a day or two; I've got other stuff on my mind at the moment. I did get the PCB and I made the motor mount today. |
#60 |
f5b-uk
I have always just roughened the servos and then epoxied them in because (1) I am concerned that a heatshrink wrap will add some additional flex/movement into the system and (2) we don't have goop over here. The downside of just using epoxy is (1) if you ever need to get the servo out it is not easy (but you've have difficulty with goop anyway) and (2) they can sometimes pop out if the glue joint cracks. The irony is that the servo you want to get out 'never' has a weak joint - I had to dremmel out a HS125 last year, picking out the gears, motor and circuit board bit-by-bit
| Thread Tools | |
| F5B / hotliner wing incidence | Jonas Leander | Electric Sailplanes | 7 | Apr 22, 2002 02:49 PM |
| Aveox F12 and.......??? for F5b/hotliner | Alan W | Electric Sailplanes | 2 | Feb 06, 2002 05:54 PM |
| WTB F5B/hotliner stuff wanted. | Superbike | Aircraft - Electric - Airplanes (FS/W) | 1 | Feb 05, 2002 02:30 AM |
| FS: Smart F5B hotliner travel bags | ghanson | Aircraft - Electric - Airplanes (FS/W) | 0 | Nov 20, 2001 07:11 PM |
| first F5B/Hotliner | Frank S | Electric Sailplanes | 22 | Sep 10, 2001 06:30 AM |
