Old Mar 04, 2007, 06:38 PM
UAVProducts is offline
Find More Posts by UAVProducts
United States, MI, Goodrich
Joined Mar 2004
Bad a123 cell: Best way to test with 1010C
I have a bad cell in one of my 10s1p packs. It was reading 1.70v vs the other 2.81v the rest of the 9 cells read. Note: My DVM is not calibrated correctly so it shows lower voltage then charger but it works for base comparison numbers )
I separated the cell from the 10s pack and was able to charge it a 1A and it took 2280mah after 2hrs. I then discharged it on the Tp 1010C (v2.1) and it discharged 1540mah. I currently have it charging again.
How can I test this cell with the Tp1010C? Should I try it in a 10s pack?
Anybody have an extra a123 cell ?
UAVProducts is offline Find More Posts by UAVProducts
Discussion Best way to test radio distance? BowerR64 Mini Helis 4 Aug 14, 2007 08:24 AM
The best way to test the current on brushless SuperHornet Pusher Prop Jet Models 2 Jun 12, 2005 06:41 AM
What is the best way to test a plane when alone. TeamTEOR Electric Plane Talk 9 Aug 08, 2004 09:05 AM
best way to deal with antenna? chemsurfer Hitec/Multiplex USA 1 Jul 08, 2003 04:15 PM
Best way to test battery charge? mism42 Electric Plane Talk 5 Dec 22, 2001 05:24 PM
