Old Mar 09, 2007, 06:42 AM
Obviously I'm a "Minus Member"
buzzltyr's Avatar
USA, MA, Longmeadow
Joined Jun 2003
"On advice of counsel...." I decided to go ahead and install the tubes. Pic attached. 1/8" brass tubes. The prop shaft and rudder shaft are cut from 3/32" music wire. The wire is a snug fit in the brass tubes, but turns freely (after dressing the ends I cut).
I'm still waiting for my FG cloth and resin (drums fingers impatiently on workbench), so today I think I will start the deck and cabin structure. As the entire deck is removable and therefore represents a seperate assembly, I don't see why I can't start on that. There are maybe 12-15 parts total to the deck and cabin, so it shouldn't take too long to get it built. While the instructions say you can glass the deck after building, I don't see how, with all of the cabin structure. I think it would be difficult to cut the cloth neatly around the cabin. So I will probably just paint it. I suppose the bottom of the deck could be resin coated to make it more waterproof. After all, this is the part of the boat that is supposed to stay above water, so I don't think there would be a huge issue with paint and perhaps a coat or two of varnish.
Any thoughts on using WBPU as a final clear coat over acrylic paints?
Mark
buzzltyr is offline Find More Posts by buzzltyr
Old Mar 09, 2007, 01:28 PM
Monterey Bay California
Joined Feb 2004
Looking good Mark!
Re: sealing, if you epoxy the interior, you may as well do the underside of the deck too- water gets onto the strangest places sometimes! depending on the epoxy you use, you should have plenty left in the batch you mix for the interior- Fiberglassing the deckis the quickest way to a smooth finish on a balsa boat if you use something light like .75 cloth, it will be easy to lay out and any rough edges can be easilly trimmed/sanded out- give it a try! WBPU over acrylic... I have no experience there but in doubt, it is is probably best to stick with a single brand/system to avoid potential bad chemical reactions
Keep up the good work!
Aerominded is offline Find More Posts by Aerominded
Old Mar 09, 2007, 03:09 PM
buzzltyr's Avatar
USA, MA, Longmeadow
Joined Jun 2003
Thanks, Aerominded! It is a pretty simple, straightforward build (except for getting the sheeting in the bow to do what it is supposed to do).
I hadn't thought about epoxying the bottom of the deck. Makes sense. That shouldn't be a problem. When I get the cabin/flybridge built and installed, I'll post a pic. Perhaps at that point you could make any suggestions about fiberglassing it. If the epoxy were thin enough, could I just "paint" it on the deck, sand it down a bit, and get a smooth(er) surface that way?
Again, thanks for the advice and support. Its appreciated!
Mark
Old Mar 09, 2007, 03:23 PM
Joined Feb 2004
Sounds good! re: sealing the top of the deck with epoxy, no glass is an option too-
West System epoxy flows well off of a brush and would do a good job filling the grain of the balsa- and can be thinned with acetone or denatured alchohol- spot putty here and there would have you set for a smooth finish! Some epoxys do sand better than others- I really like West and I think some folks here also like K&B- other epoxys like Great Planes, Devcon 30 minute, etc, while great for bonding are a little harder to finish in my opinion.
Old Mar 09, 2007, 04:24 PM
buzzltyr's Avatar
USA, MA, Longmeadow
Joined Jun 2003
Aerominded, actually I've ordered up some West System and fiberglass cloth from Aircraft Spruce. Awaiting delivery (might even be tomorrow). I also have some denatured alcohol on hand, so I think I've got what I need to "git 'er done" properly. To be honest, I'm not looking for a "10" for the finish. My first effort at fiberglassing, other than center wing section reinforcing and some reinforcing of foam DLG wings. I figure I will have to hit the auto supply store at some point and pick up some Bondo to take care of any dings, nicks and other assorted "oops" I'm bound to inflict on the model.
Mark
Old Mar 09, 2007, 04:36 PM
Joined Feb 2004
Excellent! I think you will enjoy working with West System! You will get the hang of fiberglassing very quickly, have no fear! Have you seen Pat Tritle's thread on how to fiberglass mahogany runabouts? useful reading! I'm pretty sure it is in the 'sticky' section of Dock Talk...
Old Mar 09, 2007, 07:15 PM
buzzltyr's Avatar
USA, MA, Longmeadow
Joined Jun 2003
Yup, I've read the fiberglassing thread a bunch of times. In fact, I went through it today and excerpted out the basics to print out for reference. This is a learning experience for me, and so far I think it's going pretty well. Time will tell........
Mark
Old Mar 10, 2007, 12:35 PM
buzzltyr's Avatar
USA, MA, Longmeadow
Joined Jun 2003
Busy night and morning!
The first pic shows the two deck halves joined, along with the first level of the cabin. I deviated a bit from the instructions here, as they call to glaze the windows at the end, on the outside. I chose to put them in now, so they would be on the inside. There really is no access to the interior of the cabin once the roof goes on. The second pic shows the flybridge in place. That pretty much completes the deck assembly, with the exception of a bow sprit, battery hatch, and battery box.
And what is a build thread without an "in the bones" shot, so here are a couple of pics of the deck sitting on the hull. Starting to look like a boat!
The fiberglass stuff arrived this morning (thanks, FedEx), so that will be the next thing I tackle. I expect my first efforts to be instructive, if not entertaining....(at least to those watching this thread ).
Mark
Old Mar 10, 2007, 02:44 PM
Madison, MS
She's looking right boaty now. Good work.
jeepers1940 is offline Find More Posts by jeepers1940
Old Mar 10, 2007, 02:46 PM
USA'd ex Brit
toesup's Avatar
Back.. In California
Joined Aug 2006
I really like the look of your build Buzz, she is looking splendid now she has some superstructure on the hull.
Kind of reminds me of the Aerokits (GB) Sea Nymph that i have a plan for.. It's in the 'production' line, but about 4 or 5 builds away yet..
Keep up the good work, looking forwards to some sea trials pics..
toesup is offline Find More Posts by toesup
Old Mar 10, 2007, 03:25 PM
Joined Jan 2007
wow buzz, shes looking great.....nice build
larryg is offline Find More Posts by larryg
Old Mar 10, 2007, 03:27 PM
buzzltyr's Avatar
USA, MA, Longmeadow
Joined Jun 2003
Thanks, Jeepers, Toesup and Larry. It has been a lot of fun so far. I've just mixed up the first batch of resin and put the cloth on the bottom. By tomorrow morning, I should know how it looks.
Mark
Old Mar 10, 2007, 03:52 PM
Joined Jan 2006
Isn't laser cutting great? Everything goes together so well.
Don
Tug Guy is offline Find More Posts by Tug Guy
Old Mar 10, 2007, 07:32 PM
buzzltyr's Avatar
USA, MA, Longmeadow
Joined Jun 2003
I agree, Don. Laser cutting is just fantastic. Nice clean edges, etc. I suspect that if Pat were to redesign these boats, he would be able to utilize the laser cutter's accuracy to an even greater extent, and simplify the build even more. Maybe someday the urge will strike, and Pat will redo the design at 28-32", perhaps with twin screws. That would be fun!
Mark
Old Mar 10, 2007, 09:44 PM
Joined Feb 2004
Nice work Mark! you'll be ready for the summer boating season in no time!
Pat Tritle's New Curtiss Pusher E-Challenged Scale Electric Planes 12 Apr 28, 2009 09:15 PM
Pat Tritle's Fairchild 24 E-Challenged Scale Electric Planes 6 May 08, 2002 09:52 AM
Foam Wings For Pat Tritle's F9F? ARA Electric Plane Talk 0 Apr 12, 2002 12:25 AM
Pat Tritle's SE-5a knight of Ni Scale Electric Planes 0 Jan 14, 2002 11:19 PM
Pat Tritle's B-17 J Bergsmith Scale Electric Planes 4 Sep 21, 2001 08:39 PM
