Atwater,California
Joined Oct 2006
Hi Mark, I'm John, Brad's friend. I have said to Brad many times that I want to build a boat. I will follow this thread through each step and learn as much as I possibly can. I too have a love for boats and own a boat now. I will build a boat as soon as I feel confident in my building experience. I have so much to learn.
Keep up the awesome work Mark!! John |
Hi, John. Thanks for the kind thoughts. I appreciate them. This is my first attempt at a wood boat, so I am at the steep part of the learning curve at this point.
I finished up sheeting the hull yesterday. Pic 1 is of the bottom sheeting, and pic 2 is of the completed sheeting. I had some clamp marks and depressions in the balsa, so I spackled them up and sanded them down. Next time I'll put some scrap between the clamps and the sheets/planks. Lesson learned. Any thoughts on the hull thus far? The sheer lies flat on the building board, so I don't think the sheeting process caused any twists in the hull. I had a few gaps which have been filled with epoxy and spackle, and sanded down. The hull has been sanded with 100 and 220 grit, at this point, and seems pretty smooth. Next I have to glue on the second transom piece, and sand it to shape. After that, the instructions call for installing the prop shaft and rudder tubes. However, one of my goals for building this kit is to get some experience with fiberglassing. I have virtually no experience with fiberglassing. I've ordered up some fg cloth and West System epoxy, due in sometime next week. So, a question for Pat (or anyone else who would like to respond): Should I wait to install the through hull bits until after the fiberglassing has been done? It would seem to me that I would get a better fit that way at the outer hull joint. But I'm open to suggestions from the experts. Looking forward to the fiberglassing, I'm assuming that it will be done in four pieces: bottom, transom, and one each for the sides. Also, if I am reading/understanding the plans correctly, the entire deck is removable (correct, Pat?). If that's the case, I would think I could continue on with building the deck, even if the hull has not been fiberglassed/finished. Mark |
I would install the stuffing tube and get it all aligned before glassing the hull. That way you end up with a nice tight seal.
As for glassing, I cut a piece of cloth big enough to go over the entire hull with some hanging over the edge. Glass cloth will conform to the hulls surface so you can do all of the surfaces at once. You might have to do some trimming of the cloth to get around those square edges on the transom. |
| Thread Tools | |
| Pat Tritle's New Curtiss Pusher | E-Challenged | Scale Electric Planes | 12 | Apr 28, 2009 09:15 PM |
| Pat Tritle's Fairchild 24 | E-Challenged | Scale Electric Planes | 6 | May 08, 2002 09:52 AM |
| Foam Wings For Pat Tritle's F9F? | ARA | Electric Plane Talk | 0 | Apr 12, 2002 12:25 AM |
| Pat Tritle's SE-5a | knight of Ni | Scale Electric Planes | 0 | Jan 14, 2002 11:19 PM |
| Pat Tritle's B-17 | J Bergsmith | Scale Electric Planes | 4 | Sep 21, 2001 08:39 PM |
