Old Mar 03, 2007, 02:56 AM
reefboy is offline
Find More Posts by reefboy
Luke 12:7
reefboy's Avatar
USA, CA, Sunnyvale
Joined Nov 2006
What is your favorite manuever with your wing?
I know there is a lot of Zagi bashing in the wings forum... Even so, it is a wing and it is quite fun to fly. I don't know that I can go to any of the slower flying planes now.
I love doing big graceful manuevers with my Zagi-60. Big inside and outside loops. Fly the plane toward myself WOT and then pull up and go vertical for a ways and continue away from myself inverted. I also like pulling up to about 45 degrees rolling inverted and then doing the last half of a loop so that I am now coming toward myself.
I don't see much discussion of manuevers with wings. What is your favorite maneuver?
reefboy is offline Find More Posts by reefboy
Old Mar 03, 2007, 08:05 AM
Johnnie Paul is offline
Find More Posts by Johnnie Paul
Back behind The Controls
Johnnie Paul's Avatar
Toney, AL
Joined Dec 2005
level flight
...seriously, and I don't know the names, but here are two that I like:
1) get up some speed, go into a slight dive to gain more speed, and then go verticle & full throttle with a few victory rolls...
2) again with speed, slight dive, then go into half a loop, at the top of the loop while inverted, I roll the wing over and fly 180 degrees from where I started...
...and inverted flight to, but I'm not very good at it.
I fly an XE2 from Combat Wings.
Johnnie
Johnnie Paul is offline Find More Posts by Johnnie Paul
Old Mar 03, 2007, 08:22 AM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
Originally Posted by Johnnie Paul
level flight
Johnnie
Same here
bildo baggins is offline Find More Posts by bildo baggins
Old Mar 03, 2007, 08:52 AM
KillerAir is offline
Find More Posts by KillerAir
Plane dodger
KillerAir's Avatar
Stratford Sikorsky, Connecticut, United States
Joined Dec 2001
1. Vertical rolls
2. Imellman
Killer
KillerAir is offline Find More Posts by KillerAir
Old Mar 03, 2007, 09:16 AM
Charger is offline
Find More Posts by Charger
I B Chargin'
Charger's Avatar
Arizona
Joined Aug 2003
Originally Posted by KillerAir
2. Imellman
Killer
Ah..........what's an imellman????????
Here's a couple of manuvers you can do fast or slow and I can't get enough of.....Rolling circles and flying on a winglet. Also, flying fast, close to the ground trying not to crash
video example of all with my CK built TL 50 on 4s2p
http://www.rcgroups.com/forums/showthread.php?t=565387
Charger is offline Find More Posts by Charger
Old Mar 03, 2007, 09:30 AM
lmopar69 is offline
Find More Posts by lmopar69
Team Cobra!!! Ssssssss!
lmopar69's Avatar
United States, NE, Doniphan
Joined Feb 2005
I enjoy very tight, very fast, figure-8's as low as I dare. Toss in a few dives with a high speed fly-bye at the end into vertical rolls. And when Im feeling lucky I like to see how low I can stay while inverted at full speed. Then theres the fun of seeing if I can drag a wing tip through the taller grass without pounding it into the ground.
Laine
lmopar69 is offline Find More Posts by lmopar69
Latest blog entry: Desktop Tool Organizer
Old Mar 03, 2007, 10:12 AM
jarvis2542 is offline
Find More Posts by jarvis2542
Niles, MI
Joined Jan 2005
Low pass-inverted or not at about 170mph 5ft off the deck...that will make your knuckles white
Jared
jarvis2542 is offline Find More Posts by jarvis2542
Old Mar 03, 2007, 12:23 PM
wingman2004 is offline
Find More Posts by wingman2004
Wingman2004
wingman2004's Avatar
South Carolina
Charger,
An immelman is when you pull up into a half loop, and at the top you level off and roll 180 degrees to upright. this is just a method of reversing direction. go to http://www.furball.warbirdsiii.com/k...-immelman.html to see one.
wingman2004 is offline Find More Posts by wingman2004
Old Mar 03, 2007, 12:57 PM
Charger is offline
I B Chargin'
Charger's Avatar
Arizona
Joined Aug 2003
wingman2004...........excellent illistration..........Those are fun at high speed!! Now I know what they're called.......Thanks!~
Old Mar 03, 2007, 01:45 PM
crashsiegel is offline
Find More Posts by crashsiegel
Tree? That's a Tx weed!
crashsiegel's Avatar
Central Texas
Joined Apr 2003
Climb to spec height.
Chop throttle and drop nose straight down.
Gentle roll heading for terra-firma.
WOT shortly before impact.
Straighten and pull vertical just before impact - just BEFORE...
Rapid roll as climb vertical.
Throw in a hard inside/outside loop or two.
Level off and catch up with breathing as the manically laughter echos fade.
DO IT AGAIN!
And listen to the guys say thins like "Man, did you see that wing flex?!" "Yah, anymore and the wing tips would be touching."
I fly a BOP. Took me 3 1/2 years to kill the first one. Second kit on hand, in the build queue. Going to stiffen the outboard wing sections on this one. And maybe jack the poer up some more...
Crash
crashsiegel is offline Find More Posts by crashsiegel
Old Mar 03, 2007, 02:09 PM
Skycruiser is offline
Find More Posts by Skycruiser
I eat only vegetarian beef
Skycruiser's Avatar
Fairlie, New Zealand
Joined Nov 2006
Low 4 point rolls. Yes you can do them if you start slightly climbing and have a fast enough roll rate. Low slow control line type circles around my head till I get dizzy. Most fun is getting in front of people who've never seen electrics fly, launching at 1/2 throttle and cruising round like that for a while so they think that's flat out, then open the throttle for a fast low pass and listen to the exclamations.
Skycruiser is offline Find More Posts by Skycruiser
Old Mar 03, 2007, 02:12 PM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
I figured out the rolling circle and can do it, not as neat as charger or Rich, but with some more practice I'll get better.
I just can't figure out the proper stick movemets for the salmon
I try and try but it won't happen
Atom1025 is offline Find More Posts by Atom1025
Old Mar 03, 2007, 02:35 PM
_OZ_ is offline
Find More Posts by _OZ_
It's gone...
_OZ_'s Avatar
Germany, NRW, Heinsberg
Joined Aug 2004
Floating it straight down, upside down.
_OZ_ is offline Find More Posts by _OZ_
Old Mar 03, 2007, 10:21 PM
CrazyHerb is offline
Find More Posts by CrazyHerb
CrazyHerb's Avatar
United States, WA, Ilwaco
Joined Nov 2003
Full throttle (at least all that a non-throttled norvel .061 will give me) stall turn, hand catch, and release.
Don't try this at home...
http://www.flybyphotography.com/Craz...elta/catch.wmv
Oh ya...and trimming weeds:
http://www.flybyphotography.com/Craz...elta/weeds.wmv
Steve
CrazyHerb is offline Find More Posts by CrazyHerb
Old Mar 03, 2007, 10:49 PM
punkrockd is offline
Find More Posts by punkrockd
Purples a fruit
punkrockd's Avatar
United States, CA, Walnut Creek
Joined Aug 2006
with the fun jet i like buzzing myself at full speed in a slight dive.
super flea and fly i like the flat spin. get some good altitude and then WOT and pick a corner.
depron wing me and atom1025 used to have, we liked combating them ( they dont last long) and i really like flying slow and low and trying to keep the wing tip as close to the grass while continually going from inverted to upright.
the wicked wing is just so small, and my rates are higher then needed. it rolls soooo fast its beyond blurry. not much of a move but its cool none the less.
my twinstar2 (rest in pieces) was really fun to skid and go.
punkrockd is offline Find More Posts by punkrockd
Question What's your favorite 3-view? High-wing, for a beginner... bykrdan Foamies (Kits) 12 Aug 12, 2005 09:14 AM
what do you do with your planes in the winter? t.nollett Electric Plane Talk 20 Nov 12, 2003 09:13 AM
What are you powering with your Mega?? Flying Low Foamies (Kits) 2 Sep 17, 2002 07:49 PM
Foam Conversions: What did you do with your $4? watersharer Electric Ducted Fan Jet Talk 22 Aug 06, 2001 06:39 PM
sooo....what'cha gonna get with your refund? logan5 Life, The Universe, and Politics 65 Jun 22, 2001 05:09 PM
