I should have been a little more clear. We were camparing straight line speed running the blutto and the Spiro from one end of our large slope to the other. The Blutto was faster. The Spiro is pretty light and was not balasted. My Bluto is pretty heavy for a foamie and was carring a few extra ounces in the ballast tube. Also, I am a bad @ss pilot and my friend is not.
Note that the Bluto is faster than a lot of crunchies in a lot of conditions. The reason is that the consequences of loading a 24-35oz 60" sloper with 8-16oz of ballast and then finding out that it's too much weight, are generally bad. I broke my lightly ballasted Nemesis in half the other day after I'd flown an hour in 35-50mph winds (including 2 or 3 successful landings).. because at the end of the day, the wind just switched off like a light switch.. *click*.. and it was caught 10 feet off the ground, 50 feet down the slope with zero lift.. I made a mistake (flying too slow leading to tip stall) when I was only 1/2 mistake high, and crack.. that was it.
You make a mistake like that with the Bluto and you pick it back up, dust it off, take some lead out, and throw it again, or wait until the wind comes back up. So for typical conditions the Bluto is more likely to be heavy and fast, while the crunchie is going to be lighter and slower, flying with a safety margin. Also in a man on man race, the Bluto pilot is consistently going to be able to fly it a lot closer to the slope and make more aggressive moves in general because 1. the risk is obviously less, and 2. it's more stable than most 60" slopers because it carries more weight outboard in the wings. I've outrun some local guys flying fast crunchies with the Bluto and they'be been fairly impressed. I've heard "I don't like foamies, but I might consider that one." from several people. All that said, a well built Bluto *is* very fast, and is flat out faster than many older crunchies. Not going to run down a mouldie in *ideal* conditions, but how often is that? Lastly as for the slope racers needing to turn hard rather than go fast.. the Bluto doesn't really snap off the turns (compared to a lot of other gliders) unless the wind is enormous, but it's still kicking major butt in the MoM foamie slope racing in CA in most conditions. It is just *that* much faster. People keep saying.. "I'm *sure* we can design a faster conventional design EPP slope racer, but so far no one's come up with anything to come close to the Moth, Bluto and Gulp.. all planks. As for a moulded Bluto. How the hell would you slow it down to land? I've heard the moulded Passage flying wing from f3x.com is very fast, but easy to beat to death on the landing. It's like a low wing glider.. Landing is all about major abuse to the leading edge. I would *love* to see a moulded Bluto fly. I just cringe thinking about what it'd look like when it plowed into the ground. ian |
Latest blog entry: My 2012 FPV year in Review
| Thread Tools | |
| Discussion Why aren`t most foam planes made with EPP or equivalent. | Scarey | Foamy EDFs | 1 | Jul 24, 2007 10:20 PM |
| Discussion why aren't there more scale helis? | CzechSix | Micro Helis | 63 | May 30, 2007 11:05 AM |
| F5B-7, I tried it and like it, why aren't there more flyers? | eye_rc_soar | High Performance | 59 | Jun 07, 2005 02:40 PM |
| Why aren't there more 70+inch span flying wings? | fly1milehi | Slope | 99 | Apr 12, 2005 07:13 AM |
| Why aren't there quieter IC engines? | chlee | Fuel Plane Talk | 15 | Nov 26, 2001 10:39 PM |
