Gotta join the bits now. First put the center section onto the fuse and sand it to match the fuse. You want it to flush against the fuse on each side. Next sand the dihedral angle into the panels and prep for joining.
Block up the panels and join then with epoxy. Make sure to put in the right amount of dihedral. 1.75" per side! Once that dries sand the seams to smooth them out and then put on some fiberglass over the joint. I used a layer of 6oz carbon and then a couple of layers of 1.5oz over that to smooth it out. Next I routed a groove in the bottom and installed the torque rods for the flaps. Then I hinged the flaps to the wing. I've got the flaps set so that I get about 60 degrees of down (hope that's enough).
| Thread Tools | |
| Build Log F-16 Build Thread | Thomas Nelson | Foamy EDFs | 577 | Dec 23, 2012 02:06 PM |
| GAD Northrop F-5a build thread | roccobro | Pusher Prop Jet Models | 172 | Dec 27, 2008 09:59 PM |
| Wattage F-86 build. help! 8^) | Art Newland | Electric Ducted Fan Jet Talk | 143 | Sep 06, 2006 11:41 AM |
| P/F-80 Build Thread....the beginning... | Kirkgh | Slope | 53 | Nov 19, 2004 12:37 PM |
| Jet Hanger Hobbies F-14 build thread? | speleopower | Electric Ducted Fan Jet Talk | 14 | Jul 23, 2004 03:48 AM |
