Old Mar 01, 2007, 01:39 PM
kdahlhaus is online now
Find More Posts by kdahlhaus
kdahlhaus's Avatar
United States, OH, Westlake
Joined Mar 2002
Tutorials / Info on creating skins for printed profile planes?
Being a huge fan of printed profile planes, I'd like to take some profile plans or 3-views and create skins for them similar to what TOG, EWO, and Mydigitalparadise have done.
The image layering, masking, and painting, isn't too hard to grasp. The problem is that I haven't figured out how to add highlights and shading to give a rounded look to the fuselages and wings.
I realize this may be more of a question related to the specific program used to edit the skins (the gimp in this case), but are there any tutorials/hints/links on creating skins for profile planes?
kdahlhaus is online now Find More Posts by kdahlhaus
Old Mar 03, 2007, 01:07 PM
kdahlhaus's Avatar
Joined Mar 2002
Well, I found the answer using information from this page:
http://www.novell.com/coolsolutions/feature/17391.html
Basically, you create an all-white image of the plane, blur it, then use that as a bump map to create shading. The exact steps that worked for me are:
1. Open plan image in the Gimp
2. Select the 'select contiguous regions' tool
3. click on the background of the picture
4. select 'Select->Invert
5. copy
6. create a new layer with transparent background call it 'white blur' in the Layers Dialog
7. paste into this layer. you should have just the plane
8. turn off view of other layers and select the 'white blur' layer in the Layers Dialog
8. erase (use 'edit->clear') non plane things, like title, landing gear wire pattern, etc
9. make background color white
10 Edit->fill with bg color
11. now should have solid white pattern of plane with transparent background
12. Filters->Blur->Gaussian Blur. Try 30-50 blur height/width.
13. now should have white 'plan' with blurred edges
13. select print layer, right click on layer, and click 'Alpha to Selection' in Layers Dialog
14. Main window ->Filters->Map->Bump Map. Try various 'depths' using the preview, and may need to change the Azimuth to 90 to light shines from top of plan
15. delete or turn of the 'white blur' layer in the Layers Dialog
Old Mar 03, 2007, 03:09 PM
ewo is offline
ewo
Find More Posts by ewo
ewo
ewo's Avatar
Spencer In.USA
Joined Oct 2003
Man that seams like a lot of work !
anyways im glad you got it worked out.
I just used the smear or smudge tool with my program.
different programs, different tricks to learn i guess.
ewo
ewo is offline Find More Posts by ewo
Old Mar 03, 2007, 05:15 PM
kdahlhaus's Avatar
Joined Mar 2002
It sounds a lot worse than it is, but you're right, there are a lot of tricks to learn when using these programs.
Old Mar 04, 2007, 01:52 PM
kram242 is offline
Find More Posts by kram242
-+- PhlatBoyz -+-
kram242's Avatar
New Jersey
Joined Sep 2003
In Photoshop you just use the bevel filter, and its done.
How do you add the graphics to the plane?
Mark
kram242 is offline Find More Posts by kram242
Old Mar 04, 2007, 03:14 PM
kdahlhaus's Avatar
Joined Mar 2002
3M 77 spray glue. There's a build thread at http://www.rcgroups.com/forums/showt...highlight=p40+
Old Nov 12, 2009, 02:27 PM
wartoy is offline
Find More Posts by wartoy
wartoy's Avatar
United States, AR, Jacksonville
Joined Dec 2005
Where is the original build thread for this bird dog?
wartoy is offline Find More Posts by wartoy
Advice on digital camera for photographing model planes Gordon Electric Plane Talk 43 Nov 22, 2002 08:00 AM
Info on Focus Radio for Zagi??? captainjulio Foamies (Kits) 9 Oct 15, 2001 07:51 PM
