Old Oct 05, 2002, 07:34 AM
Lutin is offline
Find More Posts by Lutin
Montreal St. Hilaire, Canada
Joined Feb 2002
Herr Fokker D-VII (24" Span) to r/c
I'm looking at the Fokker D-VII (24" Span) FreeFlight Rubber Kit to convert to electric R/C did somebody do this or do you think it would be possible to do. Any imput is welcome
thank you
Lutin is offline Find More Posts by Lutin
Old Oct 05, 2002, 08:35 AM
Robert Hoffman is offline
Find More Posts by Robert Hoffman
Over Engineered
Robert Hoffman's Avatar
Michigan
Joined Jul 2002
I tried to convert a Guillows Kit once. I was not successfull. I learned alot from it though. It can and has been done. I am not sure about the Herr designs. I do know that the Dare designs are simular and they have a 30" DVII already designed for Speed 400. Check out the link below.
http://www.darehobby.com/Laser-Cut%20Kits%20-%202.htm
They have quite a selection of electric aircraft at this site.
Hope this helps.
Robert Hoffman is offline Find More Posts by Robert Hoffman
Old Oct 06, 2002, 03:05 AM
Sgt Rock is offline
Find More Posts by Sgt Rock
Southern Okanagan, British Columbia.
Joined Aug 2002
Yeah, you should have no problem converting this. I have just finished a Nieuport 11 from Guillows, 24" w/s. This plane had to come in under 9 oz due to the smaller lift area of the narrow low wing.
The Fokker D- VII has 2 good sized wings, so as long as your auw remains around 10 oz, you should have a great plane.
Sgt Rock.
Sgt Rock is offline Find More Posts by Sgt Rock
Old Oct 06, 2002, 01:50 PM
AerodromeRC is offline
Find More Posts by AerodromeRC
Designing on the edge
AerodromeRC's Avatar
United States, OR, Portland
Joined Mar 2001
Lutin,
I have built this model for display. I also have done several Rubber to Electric conversions. See my personal web site for details. I would rate this design as very favorable, I would go for a S280 with Horst 4:1 gearbox and 9x7 prop. 8x370mah nimhs. I would replace the wheels with better ones. The built up balsa ones in the kit probably will not take the stress of repeated landings. http://www.aerodromeRC.com has 1.75" wheels that will work.
I recall that someone has actually converted this kit and had a fantastic lozenge covering on it.http://www.rcgroups.com/forums/showt...ht=Herr+Fokker
Kurt
AerodromeRC is offline Find More Posts by AerodromeRC
Rubber FF to E-RC Herr Fokker D.VII Zeroaltitude Scale Kit/Scratch Built 20 Dec 12, 2005 04:32 AM
Herr Fokker D-VII FF to RC conversion Zeroaltitude Scratchbuilt Indoor and Micro Models 1 Dec 05, 2005 08:31 PM
Herr Fokker D.VII for the winter/indoor season, help with paintschemes please! Zeroaltitude Scale Kit/Scratch Built 5 Sep 13, 2005 06:57 AM
Herr Fokker D-VII 4 ch indoor Davomatic Scratchbuilt Indoor and Micro Models 20 Aug 11, 2004 01:54 PM
Herr Fokker D VII JFGrn Scale Kit/Scratch Built 12 Mar 29, 2002 08:08 PM
