Old Feb 27, 2007, 06:59 PM
Rod is offline
Rod
Find More Posts by Rod
Rod
Canada, BC, Kelowna
Joined Nov 1999
Li-Po charging chart
A few days ago someone post a chart that showed the voltages of Li-Po batteries above which these cells should not be charged. Can someone point me to that chart?
Rod is offline Find More Posts by Rod
Old Feb 27, 2007, 10:47 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
You mean something like this:
1 Cell 4.2V (4.18-4.22)
2 Cell 8.4V (8.36-8.44)
3 Cell 12.6V (12.48-12.66)
4 Cell 16.8V (16.68-16.88)
5 Cell 21.0V (20.90-21.10)
Maybe that helps..
Jeff
www.CommonSenseRC.com
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Feb 28, 2007, 08:43 AM
Rod is offline
Rod
Rod
Canada, BC, Kelowna
Joined Nov 1999
Thanks for your reply Jeff, however the chart I am looking for was a chart that indicatedthe voltage of LiPo cells that should not be toped off. That is if a cell (or multiples) is at X volts, do not put it on a charger to tpo off.
Old Feb 28, 2007, 09:03 AM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
LiPoly chargre to voltage / do not top off if above
That would depend on the charger and the user.
Astro Flight 109 and other chargers can jump to the wrong cell count (higher) if you charge a mostly fully(?) charged LiPoly battery.
There is no logical reason to charge(top off) a LiPoly if the cells are at or above approx. 4.15V ea.
Note: A LiPoly cell at 4.15 is considered 95% charged. Many charger result in a full(?) charge of 4.1 - 4.17 volts per cell. There some chargers which charge to 4.2 per cell at the termination point ,however if you chaeck the voltage 20 min. later it will most likely be in the 4.15-4.17 range.
If you battery provides a 10 min. (600 sec.) flight when charged to 4.2 the 4.15 (95%) will provide approx. 9.5 min. ( 570 seconds) of flight.
AF chart
http://www.rcgroups.com/forums/attac...hmentid=470206
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old Feb 28, 2007, 12:25 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Sounds like a chart of voltages that would prevent an autocount charger from making the wrong decision as to cell count. ie 4 cell @ 16V could be misread as a discharged 5s pack.
hoppy is offline Find More Posts by hoppy
Li-Po charging question zbrubaker Batteries and Chargers 3 Apr 24, 2004 09:37 PM
Nomex Fire Retardant Sox for Li-Po Charging Synthetic Batteries and Chargers 4 Feb 03, 2004 07:43 AM
Li-Po charging question bztguy Batteries and Chargers 0 Jan 01, 2004 07:58 PM
Li-Po charging talonxracer Batteries and Chargers 3 Sep 26, 2003 07:18 AM
Slightly Confused: Triton and Li-Po Charging J R Purcell Batteries and Chargers 1 Mar 30, 2003 02:30 PM
