Old Oct 04, 2002, 03:53 PM
whirlyspud is offline
Find More Posts by whirlyspud
whirlyspud's Avatar
Chicago
Joined Sep 2002
connectors for Shulze speed control
Hello, I am hoping someone here can help me with some information. I just received a shulze speed control that is missing some parts. I know it was supposed to come with connectors to hook it up to the brushless motor. They were missing. I am trying to find someplace where i can buy a comparable connector, or maybe even the same as should have been with it. I know that many times these connectors come already inserted in the speed control, but that is not the case here:-( The female connector is all that is there. I have emailed the supplier, and also Shulze, but I have yet to hear back from either.
whirlyspud is offline Find More Posts by whirlyspud
Old Oct 04, 2002, 05:09 PM
gregg f is offline
Find More Posts by gregg f
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
Re: connectors for Shulze speed control
mike: are you sure. the connectors are female. the controller has male connectors built in. iirc
gregg f is offline Find More Posts by gregg f
Old Oct 04, 2002, 05:11 PM
whirlyspud's Avatar
Chicago
Joined Sep 2002
Yes, I am sure. On this controller, the female ends are soldered directly to the board. The male ends go on the motor. They are shown in the instruction sheet. If they were there, they would protrude out from the edge of the board about 1/4 of an inch.
They are 100% not there.
Old Oct 06, 2002, 06:58 AM
Gary Retterbush is offline
Find More Posts by Gary Retterbush
I "plant" trees (balsa)
Gary Retterbush's Avatar
Eisenschmitt, Germany
Joined Jan 2002
Normally they are shipped with the male inserted into the female. Take a pair of needle nose and I'll bet you will find the missing part!
You really need to pull and they are small. But, look again and I'm 99% sure they are there.
Gary Retterbush is offline Find More Posts by Gary Retterbush
Old Oct 08, 2002, 02:39 PM
Joined Jan 2002
Did the missing parts ever show up??
Old Oct 08, 2002, 06:57 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
JETI uses the same connectors - the 3.5mm bullets. If you need to buy some it's a Hobby Lobby stocked item. I'm sure there are other sources as well.
BEC is offline Find More Posts by BEC
Old Oct 08, 2002, 08:45 PM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Here's a pic showing the pp35 plugs in question..
Haldor is offline Find More Posts by Haldor
Old Oct 10, 2002, 07:14 PM
whirlyspud's Avatar
Chicago
Joined Sep 2002
Gary, you may be 99% sure that they are there, but you would still be 100% wrong. I'm 100% sure they are not there. After emailing the dealer back and forth a few times, I told them not to even worry about it. I got the impression they could have cared less anyway. They just gave me the stock answer that they are already plugged in. I have had similar controllers where that was how they came, but not this time. I have read other people's comments on this particular vendor, and most all seemed to have had decent service from them when things were not right Better than the case was with me, but I'm not going to bad mouth them over one problem. AS long as they didnt pull them out, it's really shulze's fault to begin with. I'm of the opinion that someone at schulze never pluged them in as should have been done. I never did get a reply from Schulze. The connectors only cost $3.50 from Hobby Lobby, so it's not a big a deal. Someone from here emailed me the link to them. The ones from Hobby Lobby will be here in a couple days. Thanks to all that did reply.
Old Oct 11, 2002, 01:51 AM
Joined Jan 2002
Mike,
Well, that is the first time this year that I've been wrong!
Sorry to hear that they really are not there. If you still need them, I'll call Schulze and get a pair for you and send them to you. Let me know. If you do need them, direct email your address.
Gary
(edited)
Mike, we have screwed around long enough so I just ordered a pair of the males and should have them tomorrow. Fire me your address ASAP.
Old Oct 11, 2002, 07:14 AM
whirlyspud's Avatar
Chicago
Joined Sep 2002
Gary, Thanks for the offer, but I should be all set up after my order from Hobby Lobby shows up. In Schulze's defense, I received this in the email this morning.< See Below> I can't hold it against them for not giving me a reply, if they never even got my email, and that looks to be the case. Thanks again for the offer Gary. Very nice of you to do so.
Mike Dukes
"Hi. This is the qmail-send program at majestix.domke.net.
I'm afraid I wasn't able to deliver your message to the following addresses.
This is a permanent error; I've given up. Sorry it didn't work out.
<mselektro@aol.com>:
Connected to 64.12.136.57 but greeting failed.
Remote host said: 550-The information presently available to AOL indicates that your server
550-is being used to transmit unsolicited bulk e-mail to AOL. Based on AOL's
550-Unsolicited Bulk E-mail policy at http://www.aol.com/info/bulkemail.html
550-AOL cannot accept further e-mail transactions from your server or your
550-domain. Please have your ISP/ASP contact AOL to resolve the issue at
550 703.265.4670.
I'm not going to try again; this message has been in the queue too long.
--- Below this line is a copy of the message.
Return-Path: <m.dukes@attbi.com>
Received: (qmail 22660 invoked by uid 508); 4 Oct 2002 02:59:22 -0000
Delivered-To: schulze-elektronik.com-mail@schulze-elektronik.com
Received: (qmail 22652 invoked from network); 4 Oct 2002 02:59:21 -0000
Received: from sccrmhc01.attbi.com (204.127.202.61)
by 81.2.176.41 with SMTP; 4 Oct 2002 02:59:21 -0000
Received: from mike ([12.248.42.52]) by sccrmhc01.attbi.com
(InterMail vM.4.01.03.27 201-229-121-127-20010626) with SMTP
id <20021004025853.MYCK6431.sccrmhc01.attbi.com@mik e>
for <mail@schulze-elektronik.com>; Fri, 4 Oct 2002 02:58:53 +0000
Message-ID: <002701c26b52$28c6c240$342af80c@attbi.com>
To: <mail@schulze-elektronik.com>
Subject: fut-18.46k missing connectors
Date: Thu, 3 Oct 2002 22:00:13 -0500
MIME-Version: 1.0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: 7bit
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 6.00.2800.1106
X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2800.1106
Hello,
Earlier I wrote you an email stating that the connectors going from my speed
control to the motor were missing from the package. After reading over the
instructions some more tonight, I have come to the conclusion that there
must be a package of connectors missing from my speed control. The
instructions imply that there also should be included a battery connector.
Is this right?
Please let me know how I can resolve this problem. I can come up with my
own connectors for the battery, but the ones for the motor are of a type
that I am not familiar with, and have not seen available in hobby stores
around here. If you could point me to somewhere here in The USA where I can
purchase them it would be of a great help to me. I have waited for weeks
to get this controller, and now still can not fly my helicopter because of
the connectors :-(
Also, I dont know if the items were not packed from you, or they fell out at
the shop I ordered it from, But it might not be a bad idea to change the
packaging to a box that does not have holes cut in it.
Thank You,
Mike Dukes
7544 Emerson St.
Morton Grove Il, 60053
USA
Old Oct 11, 2002, 07:21 AM
Joined Jan 2002
Mike, they are already on the way and I will have them tomorrow and will mail them to you on Monday which is the earliest time the APO will be open. That means you should have them for next weekend. Enjoy!
Gary
BTW, the address for Schulze is: mail@schulze-elektronik.com
Old Oct 11, 2002, 08:34 AM
whirlyspud's Avatar
Chicago
Joined Sep 2002
Gary, Like I said, I already ordered a set from Hobby Lobby, so I really should not need them. I hate for you to waste the postage to send them to me. I do greatly appreciate the trouble you went thru to help me with this though. It was very nice of you to do that. I'm not sure why my email to Schulze was returned. I clicked the contact us link on their webpage to send it to them. I am going to forward the mailer damon reply I received to attbi.com, my isp, and I will tell them that if my emails are going to be blocked because of them allowing bulk mailings, they need to do something about it. I hate junk mail myself, and if they allow it, I'll take my account someplace else.
Thanks again for your help,
Mike Dukes
Old Oct 11, 2002, 09:33 AM
Joined Jan 2002
Okay, I'll just keep them.
Old Oct 11, 2002, 11:07 AM
whirlyspud's Avatar
Chicago
Joined Sep 2002
Gary, If there is ever anything you need help with from this side of the world, let me know. I'd be more than willing to help if I can.
Thanks again
Mike dukes
Old Oct 12, 2002, 08:57 AM
Joined Jan 2002
Mike, just to let you know that I did in fact receive the 2 connectors that I ordered at around 10:00 AM this morning. Hope your delivery is as fast. That was 24 hours from bottle to throttle! Gary
Looking for brushless speed control info' olmod DIY Electronics 6 Apr 19, 2005 02:56 AM
For Sale/Speed Control Morris Boats (FS/W) 5 Jun 12, 2004 05:39 PM
im looking for a lrp speed control oznation Cars - Cars and Parts (FS/W) 0 Jan 06, 2004 07:15 PM
Source for Kontronik speed control in US or suggestion for replacement? soareyes Electric Heli Talk 6 Apr 21, 2003 11:02 PM
Connectors, speed control, batteries for GWS P51 austinflyer Foamies (Kits) 0 Jan 05, 2003 10:44 AM
