Old Feb 25, 2007, 07:30 PM
tribologist is offline
Find More Posts by tribologist
South Windsor
Joined May 2005
Micro Helis drop in alu hub for Blade CP, any good?
I found this at Microheli.com
Drop in rotor head hub for blade CP.
http://www.microheli.com/mhshop/prod...roducts_id=385
I also found that they sell metal blade grips with bell-hiller for the CP Pro.
http://www.microheli.com/mhshop/prod...roducts_id=361
Anyone with experience of these products?
Ulf
tribologist is offline Find More Posts by tribologist
Old Feb 25, 2007, 08:44 PM
osterizer is offline
Find More Posts by osterizer
Psurvival = 1/ThArrival
osterizer's Avatar
Maryland, USA
Joined Jan 2007
Funny you should mention it-- I ordered the hub not more than an hour ago! I don't know if it will be as good as my other MH parts, but I'll find out Thu or Fri. I expect the grips will do wonders for the head, but not going there just yet.
osterizer is offline Find More Posts by osterizer
Old Feb 25, 2007, 10:22 PM
PLATINUM is offline
Find More Posts by PLATINUM
Idle up!
PLATINUM's Avatar
USA, VT
Joined Nov 2004
I have the complete head (for cp2/blade cp).. The hub for blade pro is a bit different, but I can assure you uH product is top notch! The only thing I noticed is their set screw on my hub was not tight.. So I just used the jesus pin. No biggy.
I am converting my cp2 to a Compy300 upgrade frame. It is kinda combo of a CP2/Blade CP and T-rex.. I have a uH t-rex tail assembly coming for my conversion.
http://www.helidirect.com/product_in...roducts_id=563
PLATINUM is offline Find More Posts by PLATINUM
Old Feb 25, 2007, 10:30 PM
South Windsor
Joined May 2005
Looks like we got the last ones. I ordered one to from Helidirect but now they show out of stock. I snapped a blade grip today but I have one laying around but next time I am getting the MH ones unless there is some problems with them.
Old Feb 25, 2007, 10:57 PM
South Windsor
Joined May 2005
There seems to be more parts coming for the head.
Look at these that I saw when looking at the button.
I like this. I was hoping E-flite would release aluminum components but it looks like microheli is winning the race.
Ulf
Old Feb 26, 2007, 01:35 AM
HeliDirect is offline
Find More Posts by HeliDirect
HeliDirect's Avatar
Joined Nov 2005
Yes they are top notch cnc parts. They have the flybar coming soon and another version of main frame for blade cp pro. This version is only 69.99usd using stock landing gear. So it's a big improvement in price compared to the 120 buck previous version airframe. Will release in a few days. But the belt drive will be 287.99usd
HeliDirect is offline Find More Posts by HeliDirect
Site Sponsor
Old Feb 26, 2007, 06:53 AM
South Windsor
Joined May 2005
That is great news. It is very nice to have al parts that are compatible with the stock parts so that it is possible to get replacements in the LHS.
Does HeliDirect have the Bell-Hiller blade grips in stock?
Ulf
Old Feb 26, 2007, 07:15 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
2 downsides. uH costomer support is a bad joke.
Some people have had problems with uH stuff using a softer aluminum on the larger heli parts and having bending problems. May not be a big deal on micros.
AFAIK E-flite was just going to sell the uH head, which will help solve the customer support issues.
Pinecone is offline Find More Posts by Pinecone
Old Feb 27, 2007, 12:32 PM
osterizer's Avatar
Maryland, USA
Joined Jan 2007
It's in the hands of fedex now. We'll see how it works when it arrives.
Old Feb 27, 2007, 12:39 PM
Cityflyer is offline
Find More Posts by Cityflyer
Sidewalkers stand clear!
Cityflyer's Avatar
Sweden
Joined Jan 2007
I got the blade grips with bell-hiller and they work great.
I Also got the hub incoming any day now.
Cityflyer is offline Find More Posts by Cityflyer
Old Feb 27, 2007, 01:03 PM
PLATINUM is offline
Idle up!
PLATINUM's Avatar
USA, VT
Joined Nov 2004
I recieved my uH T-rex tail assembly for my cp2/blade conversion to Compy 300 belt upgrade frame. Very nice piece! See attached link
http://www.rcgroups.com/forums/attac...mentid=1198806
Old Feb 28, 2007, 12:13 AM
jmc67 is offline
Find More Posts by jmc67
United States, NY, Dutchess County
Joined May 2005
I have the blade grips (bell-hiller) and had to remove them. Unfortunately I was getting a very bad vibration. To make sure it wasn't the grips, I installed all new components including a new set of blades but still had the same problem. The vibration is so bad that the battery just came loose. Since then I have put them away figuring out what to do next. I was and still am a bit dissapointed these grips did not work for me. Maybe I did something wrong?
jmc67 is offline Find More Posts by jmc67
Old Feb 28, 2007, 06:52 AM
South Windsor
Joined May 2005
Did the vibrations go away when you went back to the standard grips? How did the blades track? If the blades track the only other thing that will cause vibration that I can think of is if the hub is not centered. (or the blade grips beeing different length., check the space between the hub and the blade grip)
The things I can think of is either that you got the feathering shaft assembly together wrong (missed a shim or a spacer, possibly got the spacer under the nut stuck on the end of the shaft. Are the grips moving free under axial load?
Ulf
Old Feb 28, 2007, 08:23 AM
jmc67 is offline
Joined May 2005
Yes, the vibrations disappeared after putting back the plastic grips. Yes, the blades tracked fine with the cnc grips. I also changed the hub, o-rings, spindle, shaft and still had the vibration. Everything was put back in the correct way and yes the grips moved freely under load. I was at this for several hours with no luck.
Old Feb 28, 2007, 08:31 AM
PLATINUM is offline
Idle up!
PLATINUM's Avatar
USA, VT
Joined Nov 2004
Sounds like you need another dampening washer inbetween the grip and the hub.
Mine is like this on the complete cnc head
grip bolt/washer >> grip >> slip washer(grove fits bearing) >> rubber dampening ring, aluminum ring(inside hub)
Discussion Is there any reason not to go to carbon fiber blade for the blade cp? SteveCH Micro Helis 26 Aug 17, 2007 07:01 AM
For Sale E-flite 4 in 1 controller for Blade CP $50.00 shipped NIP nakman8 Aircraft - Electric - Helis (FS/W) 4 Mar 18, 2007 09:15 PM
Alu Swash for Blade CP? kenmalecki Micro Helis 0 Oct 16, 2005 04:32 PM
