Old Feb 23, 2007, 01:07 PM
Panorama City, CA
Joined Sep 2004
HS 81 Servo on 6 Volt dangerous?
TO: Hitec people
What is your comment on the following posting?
"I do know for sure from personal experience that running HS-81 servos (which are also rated only at 4.8 volts ) on a 6 volt pack will kill them. I lost 3 HS-81 servos in my first Nemesis with a 6 volt pack intalled before I figured out what was happening."
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old Feb 23, 2007, 01:25 PM
S.A.D. member
ivanc's Avatar
Chicagoland, IL
Joined Dec 2004
... HS-81 servos (which are also rated only at 4.8 volts )...
http://hitecrcd.com/Servos/hs81.htm
HS-81 specs are listed at both 4.8V and 6.0V.
Ivan
ivanc is offline Find More Posts by ivanc
Old Feb 23, 2007, 01:33 PM
Panorama City, CA
Joined Sep 2004
Ivan,
Thanks for reassurance. I am using 5-cell with HS81 and became alarmed after reading the above post.
Old Feb 23, 2007, 01:35 PM
Hitec/Multiplex Service
San Diego, CA
Joined Apr 2001
Hi John,
We recommend 4.8v-6.0 volt on all Hitec servos. If your killing them you might want to change to another servo?
http://hitecrcd.com/Servos/Servomanual.pdf
STEVO is offline Find More Posts by STEVO
WTB: Hitec HS-81 Servo's gromitvt10 Aircraft - Fuel - Airplanes (FS/W) 1 Aug 22, 2002 05:10 PM
HS-81 servo centering tqpham Electric Plane Talk 3 Jul 02, 2002 08:52 PM
Glitchy Hs-81 servo Al P Electric Plane Talk 3 May 30, 2002 07:21 PM
HS-81's on the Terry FullaFoam Beginner Training Area (Aircraft-Electric) 9 Jun 14, 2001 08:31 AM
9 cells on 6 volt speed 400? fourstarforty Electric Plane Talk 5 May 15, 2001 12:35 AM
