| Thread Tools |
| This thread is privately moderated by UBILDIT, who may elect to delete unwanted replies. |
Use a Mask or Else!
Just a quick note. I was unaware that when sanding things that contain epoxy.. like a FFF laminated canopy, or when cutting Carbon Fiber Rods or spars, you should at least use one of those little paper masks over your nose and mouth. It's been reccommended to me that I perform these operations outside and with a mask or at least have a vaccuum hose nearby to catch the particles. As a result of my ignorance, I recently suffered through (what I thought was pneumonia) a small part of my lower left lung collapsed and became infected. It was no fun..
Further investigation revealed that the Carbon Fiber dust can be highly carcenogenic.. Crap!... So, I had to remove everything from the room I build in and totally vacuum, dust and mop everything top to bottom. Motor and prop tests tend to stir up whatever dust is in the room... so.. lots of work and no place to build. However, I have been able to reorganize the build room into an assembly area, a soldering area and a sanding / finishing area. So it all turned out for the best.. But just a warning to anyone out there who was like me and did'nt know... Use a mask because you need your lungs... Bo
| Thread Tools | |
| Is it safe to use glasfiber or carbon rod for wing connection | PropelLars | Electric Sailplanes | 15 | Jan 09, 2009 01:07 PM |
| Alert Use a Mask or Else.. | UBILDIT | Foamies (Scratchbuilt) | 95 | Apr 27, 2007 12:55 PM |
| Angle of Attack > Use Ideal or Best L/D? | green66 | Power Systems | 14 | Jun 18, 2002 06:59 PM |
| Is it safe to use glasfiber or carbon rod for wing connection? | PropelLars | Power Systems | 5 | May 22, 2002 06:57 AM |
| Anyone use 9 or 10 cells in a stock Twin Jet ?? | speedo | Foamies (Kits) | 14 | Jul 06, 2001 06:54 AM |
