Old Feb 22, 2007, 12:42 PM
sun.flyer is offline
Find More Posts by sun.flyer
Test your skills....fly IMAC!!
sun.flyer's Avatar
Swanton, Ohio
Joined Feb 2005
3D Hobby Shop 47" Extra 300 SHP
After much anticipation and wondering by many as to what 3D Hobby Shop would be offering next in there new line of high quality balsa arf's the wait is finally over. 3D Hobby Shop is pleased to announce there all new 47" Extra 300 SHP (Super High Performance) 3D airplane. This Extra is a 3D Hobby Shop original design that was developed by Scott Stoops (sukhoi26mx) in cooperation with 3D Hobby Shop and their partner factory in China. The sole purpose of the Extra 300 SHP is rock solid 3D flight to the MAX!!
47" Extra 300 SHP Specs:
Wingspan: 47.25"
Wing Area: 464 sq. in.
Length: 44"
AUW: 37-41 oz.
Wing loading: 11.4oz./sq.ft.-12.7oz./sq.ft.
Recommended Equipment:
Motor: Torque 2818T/900
ESC: Torque Airboss 45A Elite
Prop: APC 13 x 6.5E
Battery: 3DHS 3S 2200 20C or lightweight 25C
Servos: (4) HS-65HB
The Extra 300 SHP will come with all the same high quality hardware that the current 3DHS Yak-54 and 3DHS Katana models utilize. However in addition to that the Extra 300 SHP will also come with convienent changes.
- Hinges come pre-installed in all the surfaces.
- Hinge slot in the rear of the fuse now comes pre-cut.
- All Extra 300 SHP's will come with 52mm heavy duty wheels (very solid).
- Scale looking Extra 300 CF landing gear (no straight CF legs on this plane).
- Pull strings in each wing half for aileron wiring.
- Firewall hole is now a perfect match for the Torque 2818T/900 motor.
- 3mm motor mounting harware included.
All 3D Hobby Shop airplanes are made of light weight laser-cut balsa and light plywood. The Extra will come with a pre-cut fiberglass cowl and wheel pants, uniquely effective canopy hatch attachment, and a two piece removeable wing which rests on a carbon fiber wing tube.
3D Hobby Shop will be taking pre-orders on there new Extra 300 SHP within 24hrs. These planes will be available in March and will be offered at a price of $149.99 for the Extra 300 SHP ARF. There will also be a power-combo being offered which will include the airplane, Torque 2818T/900 and the Airboss Elite 45A speed controller for $269.99. Ben has also included a Complete Combo offer that will include pretty much everthing you will need to finish your Extra SHP minus radio and rx.
Update 2/13/08:
Due to the enormous popularity of this airplane and the large number of posts (currently over 8,000) I have decided to post some helpful links that will allow those new to the thread an easier way to seek out some useful information on this terrific airplane. I would also encourage those that have time to read through the entire thread as there is a lot of great additional information that has been posted and definately worth the time to read.
I will continue to udate this post and future posts to come with additional helpful links. I hope everyone finds this as a useful and informative addition to this already immensely popular airplane.
Actual picture of a full-scale SHP:
Mike Guolian's Castrol Aviator SHP
Flight report and RCG's Review:
Scott Stoops' overview of the 47" SHP
RCG's Review
Alternate Motor Setups:
Cobri Gearbox install pictures
47" Extra 300 SHP Video's:
Scott Stoops video w/ 47" SHP
Scott Stoops flies the Yellow 47" SHP.
Collin Bullock (Cobull) flies the SHP in Australia.
Blucor Basher flies the Yellow 47" SHP.
Video w/ Torque 2814-820/ 3S lipoly/ 14x7 APCe
Josh Young's (BoneDoc) blog with lots of SHP action
Flight SIM Stuff:
SHP for Reflex XTR from W3 group.
Modifications by users:
Pull-pull elevator w/ larger servo by W3 group.
Add-on canpoy latch for SHP V1 owners.
Color-matching spinner for yellow SHP by JE
Cool Stuff:
Cockpit insert file to print out
Earle Andrews' very highly detailed SHP.
.pdf of a Homer Simpson pilot figure - print and cut out for the SHP.
Photo of SHP 47" ARFs on the production line.
Scale cockpit for 47" SHP.
Manual:
.pdf of Instruction manual for V1 Extra SHP 47"
(V2 comes with printed addendum in box).[/QUOTE]
I will continue to update this post with additional useful and helpful links so as to continue to make this the best and most useful thread on the Groups.
Tim
sun.flyer is offline Find More Posts by sun.flyer
Old Feb 22, 2007, 12:45 PM
sun.flyer's Avatar
Swanton, Ohio
Joined Feb 2005
The Extra 300 SHP is designed for all out 3D flight. The Extra 300 was developed around a wing that has a thinner airfoil with very accurate, sharp LE that makes for a great stall breakaway and very precise flying airplane. To better understand this concept there has been an excellent thread started here that talks to this topic. The posts in this thread clearly illustrate the benefits to 3D flight that a thinner airfoil wing can have on a 3D airplane. What this all comes down to is a 3D plane that will be rock solid in high alpha flight modes, can be flown at slower speed with out the fear of a tip stall and a plane that someone can build confidence in very quickly.
One of the things I notice with new planes when they get announced is there is never any video to see how the plane actually flys. Not to be the case however with the new 3D Hobby Shop Extra 300 SHP. Here is a little "teaser" video for you.
Extra 300 SHP video
Old Feb 22, 2007, 12:56 PM
diylive is offline
Find More Posts by diylive
Mobile, AL
Joined Nov 2006
So many good planes coming out. Which one to choose? This has a beautiful color scheme to it, probably one of the best I have seen on the new balsa ARFs.
Question, Does it require the 45A ESC, or will the older Airboss 35A work on this motor-plane combo?
Greg Lipscomb
www.diylive.net
diylive is offline Find More Posts by diylive
Old Feb 22, 2007, 12:59 PM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
AB 35's work fine. The development planes all flew on Airboss 35 ESCs for months. no problems.
blucor basher is offline Find More Posts by blucor basher
Old Feb 22, 2007, 01:01 PM
diylive is offline
Mobile, AL
Joined Nov 2006
So how does this plane compare flying-wise to the Extreme Flight edge, or Extra? I am looking into upgrading from foamies into a plane in this size range, and all of these planes look very similar in my eyes, and I have read most all of the threads for these planes, but can't decide.
Greg
Old Feb 22, 2007, 01:12 PM
Joined Jun 2003
EXtra 300 SHP ARF
Extra SHP with Torque/Airboss Power Set.
Again, we're using nothing but the best - Torque and AirBoss components - in our new Extra SHP. These motors are consistently the most durable we use and have the perfect specs for this size airplane. Also, customer service on Torque and AirBoss parts is second to none.
Other motor choices we've used are E-Flite power 10 and 15, Hyperion 3013 and 3019, and Torque 2814-820. The 2818T-900 remains my favorite.
The ESCs we're supplying in all of our airplane combos now are the new AirBoss Elite 45Amp ESC. You can use up to 5S with no external BEC required.
Old Feb 22, 2007, 01:17 PM
rmgmag is offline
Find More Posts by rmgmag
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
Nice looking plane and nice video too.
Are you going to have a combo including the power set, servos, and battery?
rmgmag is offline Find More Posts by rmgmag
Old Feb 22, 2007, 01:18 PM
Joined Jun 2003
We proudly offer our own aircraft and also the aircraft from Extreme Flight at our store. Please call us and we'll be glad to discuss the details of the various aircraft with you. 1-830-990-6978.
Old Feb 22, 2007, 01:19 PM
Joined Jun 2003
Are you going to have a combo including the power set, serNievos, and battery?
Yes, a few more details to work out on that one, but it will definitely be available with servos, pack, extensions, etc.
Old Feb 22, 2007, 02:21 PM
poring is offline
Find More Posts by poring
poring's Avatar
Joined Jun 2006
Just when I thought there were too many good planes to choose from... -.-
poring is offline Find More Posts by poring
Old Feb 22, 2007, 02:25 PM
2lo is offline
2lo
Find More Posts by 2lo
2lo
San Angelo, Texas
Joined Jan 2007
color
I love the fact that it uses the same components as your other two planes.
Will there be a color choice?
2lo is offline Find More Posts by 2lo
Old Feb 22, 2007, 02:35 PM
Neil Morse is offline
Find More Posts by Neil Morse
Registered Snoozer
Neil Morse's Avatar
San Francisco, CA, USA
Joined Jul 1999
Congratulations on the roll-out, Ben and Scott! Looks like a winner for sure.
Neil
Neil Morse is offline Find More Posts by Neil Morse
Old Feb 22, 2007, 02:44 PM
800mZero is offline
Find More Posts by 800mZero
3DHS Junkie
800mZero's Avatar
Rhode Island
Joined Jun 2005
Well just got off the phone with ben--one backordered, with one of the new hyperion spinners, and the necessary servo extensions.
Only trouble is going to have to wait on the EF edge now--the money I saved for the edge--just went to the SHP
Going to go with a 2814-820, 14X7 on a 3s setup.
Now the wait begins!
800mZero is offline Find More Posts by 800mZero
Old Feb 22, 2007, 02:51 PM
sun.flyer's Avatar
Swanton, Ohio
Joined Feb 2005
Only trouble is going to have to wait on the EF edge now--the money I saved the edge--just went to the SHP
Going to go with a 2814-820, 14X4 on a 3s setup.
Won't be long... and it will be well worth the wait.
Tim
Old Feb 22, 2007, 02:52 PM
Joined Jun 2003
For the time being, it's in one color.
Discussion 3D Hobby Shop 47'' Yak 54 Get Real 3D Flying 1869 Aug 11, 2011 08:39 PM
Article 3D Hobby Shop 47'' Yak 54 ARF Review Get Real 3D Flying 21 May 29, 2011 11:00 PM
Discussion 3D Hobby Shop 47" Katana sukhoi26mx 3D Flying 1279 Jul 31, 2010 08:41 PM
Discussion 3D Hobby Shop Extra 300 SHP Elect to Glow conv Ben-Rod 3D Flying 41 May 02, 2008 02:41 PM
Video 3D Hobby Shop 47" Extra SHP sukhoi26mx Electric Plane Talk 4 Mar 12, 2007 09:19 PM
