Hah! not only intended to scale up, but actually did. Only a bit, mind you, to 1/12 scale.
http://www.rcgroups.com/forums/showthread.php?t=309087 But it's "resting" now, still part-covered, as I learned from it what I needed to before I flew it - basically to get my craft skills back in order after a 10+ year layoff. One day I might go back and get it going, it only needs the gear installing and the fuselage covering. Anyway, I'll watch this one with interest. LPS? |
Looks nice, and I'm sure it'll look lovely once it's done.
For future reference, did you try Sams in your search for a kit? They list it though I've no idea if they'd actually have one in stock: http://samsmodels.com/acatalog/Flair_Mini_Classics.html Matthew |
A bit more progress tonight, been slightly distracted by another project (large glider, look in 'scale sailplanes' if you're interested in these things).
Second fuselage side built over the first and amazingly I have two identical sides (this does not always happen!). Lightly sanded and glue blobs removed (hope this isn't too much detail for you guys) and had a quick look at the instructions (been caught out before). There are three abrubt cross section changes in plan view on a Tiger which are achieved by cracking the 1/8th stringers at various points. The instructions suggest doing this later which is fraught with danger and usually ends up in a handful of matchwood in my case, much, much better to score and crack the sides before they are assembled which I did (very carefully). I noticed that the fuselage frame matches the full size tubing almost exactly as you can see in the photo. I also like the separate framework plan which would help beginners a lot by avoiding the confusion when building over the often 'busy' fuselage side view. So far all the printwood components match the plan views and fit very well, have built a few that do not. I almost joined the sides and then realised that I had not sanded the insides of the tailpost for a nice fit, have left a note on the board to remind me. Some photos. Cheers Gary
| Thread Tools | |
| Brushless for GWS large Tiger Moth? The 400C one. | yukondog | Power Systems | 13 | Feb 14, 2006 03:42 AM |
| Flair Tiger Moth conversion | sportflyer | Glow to Electric Conversions | 7 | Nov 02, 2005 02:51 PM |
| Electrifying a 26" Flair Tiger Moth | Viper2000 | Scale Electric Planes | 2 | Feb 28, 2004 07:42 PM |
| WTB Tiger Moth(little one)Slope Glider | P-51 fan | Aircraft - Electric - Airplanes (FS/W) | 0 | Feb 08, 2004 11:14 AM |
| FS :Flair Tiger Moth kit(s) | MTT | Aircraft - Fuel - Airplanes (FS/W) | 0 | Jan 16, 2004 08:18 AM |
