Old Jul 15, 2009, 04:04 PM
jkarpy is offline
Find More Posts by jkarpy
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Originally Posted by peteolcott
The engineering diagram shows that tabs that I cut off.
I replaced the diagram with a better one.
jkarpy is offline Find More Posts by jkarpy
Old Jul 15, 2009, 04:10 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Trailing edge side view
Trailing edge Side view
Old Jul 15, 2009, 04:36 PM
peteolcott is offline
Find More Posts by peteolcott
Joined Jul 2009
Trailing Edge
Yes that picture did seem to clear up the issue. I could not see exactly how the crutch was supposed to attach. Now I can see that.
peteolcott is offline Find More Posts by peteolcott
Old Jul 15, 2009, 06:40 PM
Joined Jul 2009
This post was removed because it was not relevant or constructive to the thread.
Old Jul 16, 2009, 10:21 AM
Joined Jul 2009
I apologize for my last post
I still think the Slow Stick X is an excellent plane.
Old Jul 17, 2009, 07:33 AM
saito56 is offline
Find More Posts by saito56
saito56's Avatar
Joined Apr 2008
Just received my SSX wing kit yesterday, Looked over the balsa and laser cutting, and all I can say is every manufacturer should use this as an example of how to put a kit on the market. Reading through the instructions, watching the construction video's, and am highly impressed.
Photos when I can find time to get started!
saito56 is offline Find More Posts by saito56
Old Jul 30, 2009, 04:18 PM
dakota2112 is offline
Find More Posts by dakota2112
Joined Jul 2009
motors
Hello all, new user here with a beautiful new SSX ARF on the workbench.
I've sifted through most of the SSX build thread, there are TONS of great info on this incredible airplane!
But my head is spinning with respect to motors. The instructions recommend the BP A2212-13, but I've seen numerous others mentioned in here such as the Hacker A20-22L, the axi 2217/16, and the E-flite Park 450. Based on the specs, it looks like the A2212-13 is a little lower powered than the others, but I've flown the RealFlight model w/ the A2212-13 and it seems to perform just fine.
I'm getting some other E-flite items so I'm leaning towards the Park 450 while I'm at it. Is this a good choice? I don't want to set any speed records, but I want to be able to climb when necessary.
dakota2112 is offline Find More Posts by dakota2112
Old Jul 30, 2009, 05:54 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
If I had a choice, I would use the BP 2212-13. It is cheaper and I get longer flights than with the park 450 with plenty of vertical power. Plus the E-flite motor is more than twice the price.
Old Jul 31, 2009, 05:08 AM
saito56 is offline
saito56's Avatar
Joined Apr 2008
I am using the 2830-09 from Heads Up RC, it is a 400 class 850kv and for $18.95 it is hard to beat! It comes with a prop adapter and X mount to boot! Here is the link,
http://www.headsuprc.com/servlet/the...lectric/Detail
Old Jul 31, 2009, 07:25 AM
Joined Jul 2009
Terrific, another candidate motor. You're not helping!
I've got options paralysis like I've never had it before. I think I'm going to go with Mr. Karpy's OEM recommendation at least initially. I plan to use the Castle Creations 36A controller to allow for future upgrades though.
Old Aug 02, 2009, 05:28 PM
RMac is offline
Find More Posts by RMac
Seattle
Joined Feb 2004
Go with a MicroDan motor.
RMac is offline Find More Posts by RMac
Old Aug 02, 2009, 05:52 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
+1 dude i got a micro dan motor on a hot rod nikitis foamie that is heavier than the ssx..sick power.Dans motors are bad to the bone.
Manta1 is offline Find More Posts by Manta1
Old Aug 02, 2009, 06:12 PM
minirips2 is offline
Find More Posts by minirips2
Chicago Northwest subs
Joined Jan 2007
+2. I don't have one on my SSX, but I put one on my EPP SR-71, and it makes incredible thrust for the amps it draws.
minirips2 is offline Find More Posts by minirips2
Old Aug 05, 2009, 11:11 PM
cactus is offline
Find More Posts by cactus
cactus's Avatar
United States, CO, Durango
Joined Sep 2001
Does anyone know if this motor will work with the Millennium Outrunner motor mount?
cactus is offline Find More Posts by cactus
Old Aug 05, 2009, 11:31 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Yes, it will definitely fit.
James
Build Log Quick build Slow Stick mattyfly4fun Foamies (Scratchbuilt) 14 Feb 17, 2013 11:12 PM
Discussion Will this Slow Stick build "work"? chapped Beginner Training Area (Aircraft-Electric) 36 Mar 08, 2010 06:29 PM
Discussion Help me with a brushless Slow Stick build chapped Beginner Training Area (Aircraft-Electric) 10 Jan 13, 2010 11:27 AM
Sold Millenium X-gear Carbon Fiber Landing gear for Slow Stick Scirocco14 Aircraft - General - Miscellaneous (FS/W) 2 Jan 11, 2010 10:38 PM
