Old Apr 01, 2009, 09:38 PM
jkarpy is offline
Find More Posts by jkarpy
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Wheel pants on X-Gear
When I designed X-Gear, I made provision for wheel pants. How did it work? More pictures please.
James
jkarpy is offline Find More Posts by jkarpy
Old Apr 07, 2009, 05:06 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
James-
I thought that's what that was for.. You did an AWESOME job..
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Apr 07, 2009, 05:55 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Originally Posted by Tram
James-
That looks great! I hope it makes it to SEFF.
Where did you get the wheel pants?
James
Old Apr 07, 2009, 07:04 PM
Ducati Mechanic is offline
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
Very Nice! where did you get those sweet Pants?
Ducati Mechanic is offline Find More Posts by Ducati Mechanic
Old Apr 07, 2009, 07:12 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
I made them from sheet balsa..
Old Apr 07, 2009, 07:26 PM
Joined Oct 2008
nice!
Old Apr 07, 2009, 07:31 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Yeh, they're pretty simple to make..
Draw the outline..
Stack balsa sheet to desired thickness..
Cut out in shape of outline..
Leave "inside" and "outside" layers whole..
Trim inside layers to allow for wheel..
Laminate 1/8th ply on the "inside" of the pant for mounting..
Done..
Old Apr 07, 2009, 09:05 PM
_OZ_ is online now
Find More Posts by _OZ_
It's gone...
_OZ_'s Avatar
Germany, NRW, Heinsberg
Joined Aug 2004
Nice pants!
I love the covering job!
_OZ_ is online now Find More Posts by _OZ_
Old Apr 07, 2009, 09:08 PM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Thanks..
Old Apr 08, 2009, 12:05 PM
Huck is offline
Find More Posts by Huck
Huck's Avatar
Albany, GA
Joined Mar 2008
Tram, thanks for all the info and pictures. That's really cool.
Huck
Huck is offline Find More Posts by Huck
Old Apr 11, 2009, 12:04 PM
Joined Oct 2008
I'm in the process of joining a new Club. They want me to demo my skills before they take my money .
I was looking at all my planes last night, trying to figure out what one I should use for the demo. 47"Extra?, 40"Edge?, 40"pitts biplane? sea fury?, and then it dawned on me. Why not my X stick. It will take all the pressure off. I love my stix, and I can fly it in my sleep. Its as big as any of my other planes so why not?
Thanks for a great plane J.
Old Apr 11, 2009, 12:45 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Make sure you do a slow inverted flyby 6" off the deck for them.
James
Old Apr 11, 2009, 01:22 PM
Joined Oct 2008
no problem! then I'll flip it for the landing !
Old Apr 12, 2009, 01:39 PM
jollyroger is offline
Find More Posts by jollyroger
Central Lake, Michigan
Joined Dec 2002
I just subscribed to this thread and have a question or two:
Beveling the trailing edge stock: The instructions mention a jig but cannot find it with the other parts. Are both surfaces beveled to match the rib trailing edges?
I have some Ultrcote transparent, will this be too heavy or should I opt for the Lite version? Also the covering from Airborne models mentioned a couple pages back....has anybody used it yet?
So far everything is going together fine. One comment: The laser cutting seems to have scorched the surfaces of some of the wing parts as it appears the laser was running at a higher power level than needed. Too much brown ash on the rib edges and other balsa parts. Although it's easy to sand off, it does require some extra time. The instructions call for basswood spars but balsa was in the kit.
Need some servo recomendations. I have HS-55 and HS-81 to use but if others will work better let me know. Considering HS 56HB or HS-65HB.
Power will be a Himaxx 2025-4200/ gearbox and PQ 3S1500 Lipo. I'm not sure how these batteries are after a couple years inactivity, but I'll test them before using.
All in all a very nice kit, really like the X fuse and landing gear.
BTW I bought this one at Toledo last week.
cheers.
jollyroger is offline Find More Posts by jollyroger
Old Apr 12, 2009, 03:22 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
cheers.
I hope this helps,
The Jig is on the same sheet as the ailerons and trailing edge.
Yes, the bevel does continue the angle of the rib. The bevel will end at the notch for the rib.
Regular ultracote is OK
I will look into the burn issue.
HS-55 servos are OK if you use two for the ailerons.
I have used a similar motor setup geared 7.6:1 with a 12-6 SF prop.
Thank you for purchasing the SSX,
James
Build Log Quick build Slow Stick mattyfly4fun Foamies (Scratchbuilt) 14 Feb 17, 2013 11:12 PM
Discussion Will this Slow Stick build "work"? chapped Beginner Training Area (Aircraft-Electric) 36 Mar 08, 2010 06:29 PM
Discussion Help me with a brushless Slow Stick build chapped Beginner Training Area (Aircraft-Electric) 10 Jan 13, 2010 11:27 AM
Sold Millenium X-gear Carbon Fiber Landing gear for Slow Stick Scirocco14 Aircraft - General - Miscellaneous (FS/W) 2 Jan 11, 2010 10:38 PM
