Old Jun 16, 2012, 08:28 PM
planesilver is offline
Find More Posts by planesilver
planesilver's Avatar
United States, ID, CDA
Joined Dec 2010
I have a question for anyone about the sheeting on the bottom with the hole ..it is smaller than the sheeting on top (not as wide) and there's a sheet with 9 pieces with no number or explanation what are they about ?
planesilver is offline Find More Posts by planesilver
Old Jun 16, 2012, 08:58 PM
Joined Dec 2010
Well ,all my questions have been answered ...Thank You James ,I know it's been said before me," Great customer service "..I 'm going to get the Bipe as soon as I get this one in the air....
Old Jun 18, 2012, 04:49 PM
Joined Dec 2010
Any recomendations for servo's ? I was about to order hi-tec hs-82mg's !!but they seem heavy ...what's a good quality drop in for ailerons on this bird..
Old Jun 18, 2012, 05:04 PM
jkarpy is offline
Find More Posts by jkarpy
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Hi-tec HS-65s are perfect
jkarpy is offline Find More Posts by jkarpy
Old Jun 19, 2012, 10:58 AM
Bill0 is online now
Find More Posts by Bill0
Bill0's Avatar
United States, CA, Oceanside
Joined Aug 2010
I take it cheap 9 gm servos are not the way to go???
Bill0 is online now Find More Posts by Bill0
Old Jun 19, 2012, 11:11 AM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
No you you can use the cheep servos. I like the Power HD 1900A.
Old Jun 19, 2012, 11:33 AM
Joined Dec 2010
Has anyone built a EDF SSX yet ? I 'd love to see some picture's !!
Old Jun 19, 2012, 11:57 AM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Been thinking about designing one kind of Warthog inspired.
Old Jun 19, 2012, 01:06 PM
Bill0 is online now
Bill0's Avatar
Joined Aug 2010
Been flying both on simulator. If they fly half as good in the real world as thy do on the computer, I'm getting ready to pull the trigger.
Old Jun 19, 2012, 04:29 PM
Joined Dec 2010
Well after I finish this one ,then a Bipe and a flat sport wing I'll play with that myself I built the trainer wing on this one I'm waiting for the covering to arrive, I'll keep this one simple for now as this is my first covering job... Oh, what size EDF's ( Gotta have two ) and yank and bank with two soild rudder's,elevon mix ,do you think....I tend to get ahead of myself...
Old Jun 27, 2012, 11:19 PM
BGR is offline
BGR
Find More Posts by BGR
BGR
Foam Junkie
Joined Dec 2003
What is the best way to secure the Millenium brushless motor onto the SS with the aluminum stick?
I want to be able to replace it if it gets broken.
BGR is offline Find More Posts by BGR
Old Jun 29, 2012, 06:28 PM
Joined Dec 2010
Any 10 mm stick mount will be good as long as it works with the motor,and easy to replace, the Millenium mount will work with many motors...with a aluminum stick a aluminum mount would look nice ...Headsup rc has 10 mm aluminum mounts...If I get the bug to build another soon I was thinking aluminum stick and chrome covering...sort of "Spirit of Stick" it would be shinny
Old Jun 29, 2012, 10:21 PM
BGR is offline
BGR
BGR
Foam Junkie
Joined Dec 2003
I just have the Millenium motor mount which comes with a self tapping screw to fasten it to the stick. I am wondering if a bit of hot glue around the back of the square hole after it is mounted and fastened with the screw would be something removable yet a little extra hold.
Old Jun 29, 2012, 11:43 PM
Joined Dec 2010
Fit some balsa or even a short piece of harder wood if you feel a need for it ...I just drilled a horizontal hole put a screw ,washer,nut and some locktite and it's easy enough to change out...With the alum. fuze ,they tend to bend easy with a nose-over ...and I've split glass one's also on gws SS,with a drill...so ya pay's your money and ya take your chance
Old Jul 04, 2012, 11:23 PM
Joined Dec 2010
Well ,I maidened the SSX today and everyone loved it .....rolled out and took off very nice ,turned and started to gain altitude to trim it and 30 seconds into the flight the cheap 2.4 Rx lost contact with the Tx and down it came in a spiral of death ... Thanks to my superior building skill's and Millenium's Great design damage was minor just a prop and the motor mount...I'll post a video in the next day or so..
Build Log Quick build Slow Stick mattyfly4fun Foamies (Scratchbuilt) 14 Feb 17, 2013 11:12 PM
Discussion Will this Slow Stick build "work"? chapped Beginner Training Area (Aircraft-Electric) 36 Mar 08, 2010 06:29 PM
Discussion Help me with a brushless Slow Stick build chapped Beginner Training Area (Aircraft-Electric) 10 Jan 13, 2010 11:27 AM
Sold Millenium X-gear Carbon Fiber Landing gear for Slow Stick Scirocco14 Aircraft - General - Miscellaneous (FS/W) 2 Jan 11, 2010 10:38 PM
