Old Mar 16, 2012, 08:54 PM
jkarpy is offline
Find More Posts by jkarpy
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Originally Posted by newTOpro View Post
Hi all,
Maiden flight of my SSX yesterday was wonderful! I don't have pics as of yet. For one, I was by myself, and two, I'm not very proud of my covering job. My first time at it and it didn't quite come out as planned. But that can be changed as I'm sure a crash will be future so when repairs are needed, I can update the covering.
She flew OK but I needed a lot of up elevator to fly level, even though she is balanced about 1" behind the wing spar. DO you gents think I should let her be a bit tail heavy with the COG for level flight or is there something else maybe going on? Other than that, I have throws dialed down on the ailerons and elevator as I'm a beginner. I still have full rudder throws in play. She was nice and docile and very comfortable to fly, other than needing up elevator as I said.
Were is your CG set? Check your angle of attack.
jkarpy is offline Find More Posts by jkarpy
Old Apr 05, 2012, 01:05 PM
Petrie is offline
Find More Posts by Petrie
United States, AR, Lockesburg
Joined Feb 2012
CG Problem
Having a problem balancing my SSX. I am way off on the measured balance points. I only get a balance on spar with 7 1/8 from the motor mount to front of wing and 9 from trailing edge to front of tail mount. Only running a 1300 mAh battery a light radio gear. Any ideals on what I can check?
Petrie is offline Find More Posts by Petrie
Old Apr 05, 2012, 01:53 PM
eMoon is offline
Find More Posts by eMoon
I meant to do that
eMoon's Avatar
United States, NY, Albany
Joined Sep 2011
I wound up placing my x-gear directly behind the motor, then battery (a 1300mAh) and as much electronics as I could as far forward as I could. I'm still tail heavy but it flies ok with a bit trim.
I'm not practiced enough yet for inverted flight but I'm not sure my balance is good enough for that yet either.
eMoon is offline Find More Posts by eMoon
Old Apr 05, 2012, 02:33 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
I like my CG 3/4" - 1" back from the spar. CG is never on the spar. I recommend adding weight rather than shortening the tail by moving the wing back. Shortening the tail makes the plane pitch sensitive. What covering did you use?
Old Apr 05, 2012, 02:55 PM
Petrie is offline
Joined Feb 2012
I can do it at balancing to 1 inch behind spar. I was looking at the PDF on page 107, Dec 5. It shows the CG behind the spar. problem is Im not a custom to being able to move the wing and tail to adjust the cg. Moving the fulcrum and weight adds a lot of variables for thr seesaw. I have it all wrong. Im going to move the wing back to 5.75 from front of motor mount and start over and shoot for .75 behind spar.
21st century on the covering. Only used Monocote on all my glow planes, much harder to work with the 21st century. Try something different next time.
Thanks for the help.
Old Apr 05, 2012, 05:14 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
I like the Oralite. Sold in the US as Ultracote Lite and Ultracote park lite.
James
Old Apr 14, 2012, 08:37 PM
ScaleBrad is offline
Find More Posts by ScaleBrad
115 inches of 'hog
ScaleBrad's Avatar
United States, FL, Orlando
Joined Aug 2004
21st Century Painted Fabric covering? If so, that's about the heaviest covering around..
ScaleBrad is offline Find More Posts by ScaleBrad
Old Apr 14, 2012, 09:59 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Hey Brad. Good to hear from you. 21st also makes a lite covering.
James
Old Apr 24, 2012, 10:21 PM
Petrie is offline
Joined Feb 2012
Got time tonight to finish the SSX. Good weather tomorrow WE FLY!
Old Jun 04, 2012, 02:11 PM
planesilver is offline
Find More Posts by planesilver
planesilver's Avatar
United States, ID, CDA
Joined Dec 2010
Just bought me a SSX ....the Foam SS was the first plane I flew when I started flying (I have some great videos..) I've had many trainers over the last 3 yrs. and still fly most of them....I wanted a plane to get into building ,so the SSX seems like the choice since I've flown the foamy before
planesilver is offline Find More Posts by planesilver
Old Jun 04, 2012, 03:24 PM
pwhavens is offline
Find More Posts by pwhavens
pwhavens's Avatar
Pacific Northwest US
Joined Nov 2008
SSX Float Plane
SSX with Hobbyzone Super Cub floats, rudder tail gear, two X gear, 250watt motor and 1800mah Lipo. 1/4 inch (about 1.5 degrees) positive incidence added to wing. The setup puts the step just about at the center of gravity. Taxis, takes off and lands easily. Some down trim needed in level flight. Squats a bit with reduced throttle.
pwhavens is offline Find More Posts by pwhavens
Old Jun 04, 2012, 04:55 PM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Nice work, thanks for posting.
James
Old Jun 04, 2012, 06:39 PM
Joined Dec 2010
Looks like the floats were a easy mount with two X-gear LG...Did you shorten any of the rear gear?
Old Jun 04, 2012, 06:58 PM
pwhavens is offline
pwhavens's Avatar
Joined Nov 2008
I used the stock carbon struts as supplied. Only changed the wing incidence as suggested by several forum pundits elsewhere. I had to ream out one of the two smaller holes that run parallel to the wheel axle hole in the X gear to hold the float cross brace. I bent (offset) the cross brace slightly between the X gear (outside) and float so that both the axle screw and cross brace would fit into the slots provided on the float. Coincidentally, the axle screw fits into the float slot. I did not screw these in all the way thinking I'll switch them out with shorter fasteners of the same diameter and thread (I was in a hurry to get out to the lake).
Old Jun 08, 2012, 03:21 PM
Joined Dec 2010
Recieved my SSX yesterday ....James Thanks , for the email about my zip code,finger studder on the keyboard or I need new glasses....Can't wait to build it....It may be awhile I have a eflite super cub build and a rebuild going on a tower hobbies P-51 right now ...when I get to it I'll post pictures..
This is just plane addictive.....I need a support group this one isn't helping....
Build Log Quick build Slow Stick mattyfly4fun Foamies (Scratchbuilt) 14 Feb 17, 2013 11:12 PM
Discussion Will this Slow Stick build "work"? chapped Beginner Training Area (Aircraft-Electric) 36 Mar 08, 2010 06:29 PM
Discussion Help me with a brushless Slow Stick build chapped Beginner Training Area (Aircraft-Electric) 10 Jan 13, 2010 11:27 AM
Sold Millenium X-gear Carbon Fiber Landing gear for Slow Stick Scirocco14 Aircraft - General - Miscellaneous (FS/W) 2 Jan 11, 2010 10:38 PM
