Old Jan 01, 2012, 07:20 PM
pwhavens is offline
Find More Posts by pwhavens
pwhavens's Avatar
Pacific Northwest US
Joined Nov 2008
Originally Posted by jkarpy View Post
Looks great!
I recommend moving the wing forward until inverted flight requires no elevator input. This will also improve pitch sensitivity. Rite now you are too short coupled. CG can be as much as 1" aft-spar.
James
OK, I moved the wing forward about 1/2 inch. Now, it inverts & stays level trimmed. In normal flight when I throttle off, it noses up until it slows then noses down. A friend says I need down thrust (engine pointed downward). What do you think?
P
pwhavens is offline Find More Posts by pwhavens
Old Jan 01, 2012, 08:49 PM
jcfetterly is offline
Find More Posts by jcfetterly
Unemployed, Homeless, Happy
Joined Apr 2006
Thanks Quando, but the picture doesn't show the wrinkled wing tips as they really are.
jcfetterly is offline Find More Posts by jcfetterly
Old Jan 15, 2012, 03:49 PM
Dana Pt Dave is offline
Find More Posts by Dana Pt Dave
Driven by Passion!
Joined Feb 2009
Final Build and Maiden Flight
James,
Thanks for building one of the best kits I have ever put together! The work you did made my work so much easier. Attached are a couple of pics of my finished SSX. It's built with lights to fly at night.
motor: 2217/7 250 watt
Prop: 10x4.7
ESC: 30 amp
Battery: 1300mah 3 cell
AUW: 22oz
Maiden flight part 1, pilot error, forgot to check control surface movement minor damage, broke motor mount, lost front wing saddle (P11).
Maiden flight part 2, happened last night at dusk. Once trimmed, she flew very nice. super soft landings. Had to add a lot of up trim. I think my P11 balsa replacement has the wing incidence off. James, I need a replacement for P11 or the right measurements to cut a new one.
I am looking forward to many night flights with my SSX.
Dana Pt Dave is offline Find More Posts by Dana Pt Dave
Old Jan 16, 2012, 07:45 PM
DaDesign is offline
Find More Posts by DaDesign
ɹǝsn pǝɹǝʇsıƃǝɹ - inverted!
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
Nice job on your SSX. I like the color scheme and the built in lights.
DaDesign is offline Find More Posts by DaDesign
Old Feb 11, 2012, 10:32 AM
PittSpecial is offline
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
Translucent Yellow Covering
Oh James
Do you know where O where I can get the Translucent Yellow Covering?
My 3+ year old Slow Stick-X really needs a re-cover job.
Let me know where and I bring the CASH!!
Regards,
Carlos
PittSpecial is offline Find More Posts by PittSpecial
Old Feb 11, 2012, 11:08 AM
jkarpy is offline
Find More Posts by jkarpy
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Originally Posted by PittSpecial View Post
Oh James
Regards,
Carlos
If you want to recover your SSX, I would do it with the new Ultracote park lite or ultracote lite. Ultracote lite would be the tranlucent yellow.
I am e-mailing you my new address.
jkarpy is offline Find More Posts by jkarpy
Old Feb 17, 2012, 09:01 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
James,am I gonna see you in Perry?
Manta1 is offline Find More Posts by Manta1
Old Feb 18, 2012, 01:04 AM
ckreef is offline
Find More Posts by ckreef
ckreef's Avatar
Danville, GA
Joined Aug 2010
I talked to James a few weeks back and yes they will be at Perry this year. They are going to be at their original booth location NOT the location they had last year.
ckreef is offline Find More Posts by ckreef
Old Feb 20, 2012, 11:36 AM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
No, I just moved. Regrettably, I decided to skip Perry and SEFF this year. Just not enough time to get my shop put back together and prepare for the two events. I am going to shoot for the fall events.
James
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Had to cancel. Sorry guys!
Old Feb 20, 2012, 09:58 PM
ckreef is offline
ckreef's Avatar
Danville, GA
Joined Aug 2010
Really sorry to hear that. Was hoping to bounce some ideas off you at the swap. Will call at some time and bounce those ideas as I have a few things I want to do with your planes.
Old Feb 25, 2012, 08:38 AM
DaDesign is offline
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
James
If you're not going then I may not go as well.
Old Feb 26, 2012, 09:00 AM
jkarpy is offline
jkarpy's Avatar
USA, FL, Orlando
Joined Aug 2006
Thanks but don't miss-out on the fun because of me.
Old Feb 26, 2012, 12:03 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
James
We had to skip Perry this year as well. Plan to be at SEFF though.
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Mar 14, 2012, 02:55 PM
eMoon is offline
Find More Posts by eMoon
I meant to do that
eMoon's Avatar
United States, NY, Albany
Joined Sep 2011
Hi all,
Maiden flight of my SSX yesterday was wonderful! I don't have pics as of yet. For one, I was by myself, and two, I'm not very proud of my covering job. My first time at it and it didn't quite come out as planned. But that can be changed as I'm sure a crash will be future so when repairs are needed, I can update the covering.
She flew OK but I needed a lot of up elevator to fly level, even though she is balanced about 1" behind the wing spar. DO you gents think I should let her be a bit tail heavy with the COG for level flight or is there something else maybe going on? Other than that, I have throws dialed down on the ailerons and elevator as I'm a beginner. I still have full rudder throws in play. She was nice and docile and very comfortable to fly, other than needing up elevator as I said.
eMoon is offline Find More Posts by eMoon
Build Log Quick build Slow Stick mattyfly4fun Foamies (Scratchbuilt) 14 Feb 18, 2013 12:12 AM
Discussion Will this Slow Stick build "work"? chapped Beginner Training Area (Aircraft-Electric) 36 Mar 08, 2010 07:29 PM
Discussion Help me with a brushless Slow Stick build chapped Beginner Training Area (Aircraft-Electric) 10 Jan 13, 2010 12:27 PM
Sold Millenium X-gear Carbon Fiber Landing gear for Slow Stick Scirocco14 Aircraft - General - Miscellaneous (FS/W) 2 Jan 11, 2010 11:38 PM
