If I try to balance it 1" behind the center spar, it's much better but still a little tail heavy. As far as my setup goes, the battery (1320 mAh 3s FlightPower EVO lite) is directly under the motor. I'm running the BL-2212/13 from your site, using your motor mount. I have two big ugly (standard-size) servos on the elevator and rudder. I will probably replace these with HS-55's today, as it is probably contributing to it being tail-heavy. Other than that, I'm clueless until I weigh my tail section. |
I removed the standard-size servos from the elevator and rudder mount. It now balances about 1/2-3/4" back from the center spar. They weighed 1.5 oz. each (!!), and were 3" back from the center spar. I think this was my problem. I'm going to mount the HS-55's today which weigh virtually nothing (0.28 oz. each).
Quick question, I would like to order the X-Fuse but I need to know if the mounting brackets for the servo are identical to the GWS mount. i.e. if I rig up the control linkages today, will I have to redo them with the X-Fuse arrives? |
James |
James |
James |
James |
United Kingdom, England, Bromyard
Joined Mar 2008
| Thread Tools | |
| Build Log Quick build Slow Stick | mattyfly4fun | Foamies (Scratchbuilt) | 14 | Feb 17, 2013 11:12 PM |
| Discussion Will this Slow Stick build "work"? | chapped | Beginner Training Area (Aircraft-Electric) | 36 | Mar 08, 2010 06:29 PM |
| Discussion Help me with a brushless Slow Stick build | chapped | Beginner Training Area (Aircraft-Electric) | 10 | Jan 13, 2010 11:27 AM |
| Sold Millenium X-gear Carbon Fiber Landing gear for Slow Stick | Scirocco14 | Aircraft - Electric - Miscellaneous (FS/W) | 2 | Jan 11, 2010 10:38 PM |
