Old Feb 21, 2007, 08:54 PM
edf nut is offline
Find More Posts by edf nut
edf nut's Avatar
USA, SC, Greenville
Joined Sep 2005
Build Log
Byron F-86 edf build
Here is my byron f-86 that I picked up almost new in the box.
About the only thing that had been done when I got it was the formers were glued in with carbon fiber, and the inner gear doors for the main's were done.
I would like to thank Bob (bruff) for helping me out with some questions that I had in the beginning of this project
I will be going with the hacker / cc 85hv set up on 10s or 11s.
I am still trying to decide on a paint scheme , but have decided on doing a natural aluminum finish with bvm metal coat 2.
I dont get to work on it as much as I would like to, so I will add updates and pics when I can.
I will work on posting the pics that I have so far tonight , but here are a few for starters.
I threw in my alfa f-86 for a size comparison
Travis
edf nut is offline Find More Posts by edf nut
Old Feb 21, 2007, 09:00 PM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Keep going! I got the same airplane to convert also. Are you going to glass the foam parts?
Bob
bruff is online now Find More Posts by bruff
Old Feb 21, 2007, 09:08 PM
edf nut is offline
edf nut's Avatar
USA, SC, Greenville
Joined Sep 2005
Yeah.....we have a huge role of 3/4 oz and was going to use that.
Old Feb 21, 2007, 09:14 PM
bruff is online now
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
I was going to glass to. okay to post picutes of my build in this thread also?
Bob
Old Feb 21, 2007, 09:25 PM
edf nut is offline
edf nut's Avatar
USA, SC, Greenville
Joined Sep 2005
Here are some pics of the retracts and gear doors.
They are rom-air and have put some robart struts on them.
The offset strut hasnt made it here yet, but should be here tomorrow.
I made a brass sleve and soldered some ball links to it for the main gear doors as you see in the pics.
I completely re-done the way byron had designed the location for the front air cylinder. They had it going from top to bottom and stuck out like a sore thumb when you looked through th intake........not for me.
Old Feb 21, 2007, 09:26 PM
edf nut is offline
edf nut's Avatar
USA, SC, Greenville
Joined Sep 2005
Oh yeah....more the better
Old Feb 21, 2007, 09:31 PM
edf nut is offline
edf nut's Avatar
USA, SC, Greenville
Joined Sep 2005
more pics
Old Feb 21, 2007, 09:41 PM
edf nut is offline
edf nut's Avatar
USA, SC, Greenville
Joined Sep 2005
few more
also...something I have changed is the horizonal stab. Stock form from the kit.....it was straight, like a F-86 H. I made a jig to bend the tubes to match the angle like a F model (dihedreal).
Old Feb 22, 2007, 07:10 PM
edf nut is offline
edf nut's Avatar
USA, SC, Greenville
Joined Sep 2005
So Bob, have you started on yours at all, or is it new in the box?
Travis
Old Feb 22, 2007, 07:23 PM
bruff is online now
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Mine is built, needs final retract install and control surfaces hinged. I'm going with servos located at the control surface. I'm not using Byrons linkage. I'm glassing all the foam. I'm going with a Fury paint scheme.
Bob
Old Feb 22, 2007, 07:56 PM
edf nut is offline
edf nut's Avatar
USA, SC, Greenville
Joined Sep 2005
Sweet,
Another thing about the Fury is that the horz stab was straight so at least you didnt have to go changing that
The weight on mine with it all assembled so far with the main retracts and wheels is 4 1/2 lbs.- What ya think?
I think Im going to take out the servo trays he put in and try to get out all the epoxy and carbon he added to it and re do all of it.........
Travis
Old Feb 22, 2007, 08:07 PM
bruff is online now
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
I'm going to try to use the servo tray under the canopy for my batteries mount.
bob
Old Mar 01, 2007, 09:34 PM
Sean Sweeney is offline
Find More Posts by Sean Sweeney
Sean Sweeney's Avatar
Kissimmee, FL
Joined Mar 2001
edf nut,
I picked up a Byron F-86 to convert to EDF about two months ago. Mine had last been flown with a Jett 90 in the nose turning a prop. I just got a NIB Byron fan, and I am planning on picking up the adapter this weekend at Florida Jets. As My plane had a fire wall added and no tail pipe ducting would you be willing to post some pictures thru the nose showing the front bulkhead and nose retract mount? Also the tail pipe former? I have rebuilt the entire nose to fill in all the holes for the glow motor, and reatached the "cowling" that had been cut off from the nose, so now I need to work on the internals. My plane also has the rudder and elevator servos mounted on the top of the fuselage behind the fan (under a hatch). Is this where Byron mounted them? Thank you in advance for any help you can give! Your work is very nice and I look forward to watching your progress.
Sean
Sean Sweeney is offline Find More Posts by Sean Sweeney
Old Mar 01, 2007, 11:12 PM
edf nut is offline
edf nut's Avatar
USA, SC, Greenville
Joined Sep 2005
Sean,
Sounds like quite a project,
I will try to help you out any way I can. All my hobby stuff is at my dad's house and will be up there this weekend. I will take some pics for you of the plane and some of the plans. The stock location for the servos is under the canopy.
If you could post some pics of your jet we could get a better idea of things and figure out the best way of getting it the way you want it.
Travis
Old Mar 01, 2007, 11:17 PM
bruff is online now
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Also let me know what I can do to help.
Bob
Kyosho F-86 EDF convertion bruff Electric Ducted Fan Jet Talk 25 Jan 02, 2008 01:48 PM
Ripmax F-16 EDF build Richard Cox Electric Ducted Fan Jet Talk 20 Nov 16, 2004 12:05 AM
Used Byron F-86 - Fuse,wings, & tail only RTflyboy Aircraft - Fuel - Airplanes (FS/W) 0 Aug 11, 2004 02:47 PM
FT F-86 EDF for ECO 8 or any E-heli gns30 Aircraft - Electric - Airplanes (FS/W) 1 Sep 23, 2002 10:48 PM
New F-86 EDF 50 FanTasticModels Electric Ducted Fan Jet Talk 6 May 26, 2002 06:39 PM
