Espritmodel.com Heli Air
Old Feb 21, 2007, 01:34 PM
Will work for Heli's
asinla's Avatar
Los Angeles
Joined May 2006
What would make my heli hover lopsided??
I have a strange problem!
I recently replaced all the electronics on a Walker 22E (please don't run away!) with separates. Everything went fine..got it dialed in then yesterday when I flew it appears that the heli hovers lopsided to the right.
When I hover at eye level the blades ore really leaning right as is the whole heli!
I took the head apart and checked the main shaft, checked the tracking, flybar is straight, the frame is good, no flexing, checked the linkage lengths...all good.
I am really stumped!!
Any ideas?? I can shoot some vid if it is going to help.
Thanks in advance.
asinla is offline Find More Posts by asinla
Old Feb 21, 2007, 01:37 PM
Mom says I'm special...
beafraid8's Avatar
Aurora, CO
Joined Apr 2003
It's normal, don't worry about it. It's off-setting the thrust the tail is putting out to stop the heli from torque-ing around.
beafraid8 is offline Find More Posts by beafraid8
Old Feb 21, 2007, 01:53 PM
asinla's Avatar
Los Angeles
Joined May 2006
Hmmmm...it never did that before I switched to seperates though. It looks really strange and I think it is not optimal for the power system Sounds like the heli is straining all the time and my flight times are down.
I also have to give constant right rudder even at full right rudder trim so the tail thrust is clearly not enough.
Thanks beafraid!
asinla
Old Feb 21, 2007, 02:14 PM
That whirly guy
Bothersome's Avatar
Vivian, LA
Joined Jan 2007
Too much pitch are on the main blades. You need to take out some of the pitch so that the head speed will come up some. Basically you're creating too much drag. The more drag on the main blades the more the tail has to put out to offset the torque. This causes the heli to lean more to the right to offset the tail push.
Bothersome is offline Find More Posts by Bothersome
Old Feb 21, 2007, 04:06 PM
asinla's Avatar
Los Angeles
Joined May 2006
GREAT!!!!
Thanks Bothersome.
I'll try that now.
asinla
Old Feb 21, 2007, 04:35 PM
beafraid8's Avatar
Aurora, CO
Joined Apr 2003
Your gyro will be able to compensate better too (the right-rudder bit), because you'll maintain a more constant headspeed.
Old Feb 21, 2007, 04:40 PM
asinla's Avatar
Los Angeles
Joined May 2006
WOOHOOOOOO!!
Success!! Thanks so much guys! I reduced the pitch and fooled around with the pitch curves in the tx. No more leaning to the right and WAY better gyro behavior.
I had the best flight so far with seperates.
I LOVE HELI"S!!!!!! LOL!!!
Thanks again.
asinla
Old Feb 21, 2007, 04:45 PM
beafraid8's Avatar
Aurora, CO
Joined Apr 2003
Do you have a pitch gauge? If not, get one...you're better off leaving your pitch curves fairly standard as you go from heli to heli, and adjusting everything mechanically perfect to avoid weird mixing interactions.
Old Feb 21, 2007, 05:27 PM
asinla's Avatar
Los Angeles
Joined May 2006
Yes...good idea. I have everything except that.
Will get one next week for my birthday.
Thanks for the good advice!
What would make a great lighting system? jswayze Electric Plane Talk 26 Sep 07, 2005 09:17 PM
What would cause my chain to brake? and where to buy a new one. ^jynx^ Motorcycles 10 Sep 07, 2005 05:23 PM
What would make a good slow-flyer type plane /w 4 extra nes-537 servos & r700receiver smokeit Electric Plane Talk 4 Sep 07, 2004 08:58 AM
Question What would be a nice heli? Flyingwing Micro Helis 4 Mar 15, 2004 03:25 AM
