Build Pics and Bulid instructions
You will need
* 100cm x 60cm x .3cm foam board * 3 x 40cm x .3cm carbon fiber rods or similar * Hot glue gun and glue * Motor mount and some balsa or ply * a sharp hobby knife, pen and ruler * radio gear , 2x Servos and mixer * some creativity Building The Wing 1. Cut a piece of 3mm foam to 100cm by 40cm (make sure it’s square) 2 Find the center line and mark out the pattern with a pen (you won’t see this as it’s all covered up) 3. Turn the foam up-side-down and mark the center line and fold lines on it. Run some clear packing tape down the fold lines to help the folding process, don’t forget to mark your CG 4 Turn the foam back over and cut out the red hashed section on the plan. 5. Glue in your carbon rods and motor mount. 6. Score the fold lines with a pen, then do another two scores about 3mm apart on either side of the fold line. 7. Run a bead of hot glue down the score Line and then using a ruler fold the foam and hold it down evenly at the leading edge - look closely at the picture. Allow it to create a natural airfoil. Do the same on the other side and then glue them down on the trading edge making sure the airfoil is symmetrical. 8. Make Two cuts where the 2 green dotted lines are. 9. Cut out the black hashed sections on the plans (the fin slots only need to go through the top layer) and cut out the elevens and hinge with some packing tape 10. Cut out your fins and glue then in. You will need to glue two together to make a 6mm fin or if you have 6mm foam use that (you can make them any shape you like ). Building Fuselage Install your gear and build your fuse. Look at the build pics for ideas on this as I don’t have plans for the fuse, you can be as creative as you like. Just make sure you preserve some if not all of the symmetrical airfoil. Don’t forget the air intakes. My Power set up Mega 3000kv in runner on a 5x5 inch prop 1300mha 20c lipo with a 25amp esc Wing span 78cm or 30inch Total weight 450g or 14oz Total static thrust 720g or 25oz Power to weight ratio 1.6 to 1 ... zooom! Launching the bird CG: In the Plans I have the CG set at 19.5cm. this is conservative, I have my CG at 20cm as my calculations say that's the optimum, but 19.5cm is better for a maiden. the stingray is verry sensitive at 20.5cm it will become almost uncontrollable. Since there is no feathering on the wing you may need to trim the elevons up 10%, hold it at a 30% angle apply about 40% power and give a light toss.
JelleB, the stryker is a parkzone, hight speed RTF trainer
http://www.modelflight.com.au/hobbyz...27_stryker.htm # Wing Span: 37 in (950mm) # Overall Length: 27 in (700mm) # Flying Weight: 21 oz (580g) # Motor Size: 480 Power Direct Drive I never had the RTF so can't tell you how it flys I just got the body parts and put my own gear in it Yes the balsa and motorstick are crude, but the stick on the bottom gives me something to hold on to when launching, good point though, I could put it in side and then make nice hand grip.... yes I think I will do that next time I rebuild it |
