Old Feb 20, 2007, 10:13 AM
SGTalon is offline
Find More Posts by SGTalon
SG Talon... Super Genius.
Lenox, Michigan
Joined Nov 2005
How big can you make a Brushless motor??? or... Can we fly real planes with these?
I have been toying around with an idea for a while now.
Just how big can you make a DC Brushless motor? With Lithium Polymer Batteries you can get trememndous amounts of power with very low weight. The question is.... can it be translated into full size aircraft?
10 years ago you could barely get an electric plane off the ground. Now you can build a plane with a $25 brushless motor that has 2 pounds of thrust. So why isn't anyone exploring this for full size aircraft? I have been searching but no luck.
So could you build a motor that makes 200 pounds of thrust? Put in a big LiPo and fly a plane like an ultralight? Think of the potential with using LiPo batteries in the wings instead of fuel tanks.
Anyhow. Just thought i would throw it out there. It seems the people on RCGroups are way more interested in serious advancements in electric motor tech than most other places.
SGTalon is offline Find More Posts by SGTalon
Old Feb 20, 2007, 10:38 AM
madsci_guy is online now
Find More Posts by madsci_guy
Figure Nine Champ
madsci_guy's Avatar
North Texas
Joined Nov 2002
As big as you want. Some synchronous motors are 6 feet in diameter.
Yes, but internal combustion still gives the most power for the weight.
1. Cost. Lipoly costs $10/oz.
2. Internal combustion engines still produce the most power for the weight.
3. Duration. Your 2 lb thrust plane carries no cargo and only flies for 30 minutes max. That's not feasible for a full size aircraft, that need a 30 minute reserve to fly IFR.
4. Full size planes need FAA certification. Hard to do with innovative designs. Just ask Burt Rutan.
The measurement number that we would use to compare gas vs. batteries is joules (watts times seconds)
Gasoline has 1.3xE8 joules per gallon (6 lbs). For a two hour flight, that would work out to 18055 watts as available power.
For your basic 3S Lipo that would mean a 1626 amp hour (Ah) battery. at 3.2 oz/Ah that means 325 lbs of battery or so. Boy! I didn't realize the numbers were THAT bad.
So if I use gasoline, it's six lbs vs 328 lbs for an equivalent lipo battery. Unless I've slipped a cog somewhere. As we all know, light planes fly much better than heavy. I think the difference is so great, you would never see a full sized Lipo powered plane. Of course the engine weight vs. motor weight would also have to be factored in, but it's hard to see how one could make up the difference in weight.
Edit: Oops! You'd need two batteries, not just one. So that's 650 lbs of battery for a two hour flight if you wanted to match the gasoline performance.
madsci_guy is online now Find More Posts by madsci_guy
Old Feb 20, 2007, 10:51 AM
SGTalon is offline
Lenox, Michigan
Joined Nov 2005
But what about the efficiency of the motors? Electric Motors can have up to what 95% efficiency? IC engines are maybe 30%? Sure the energy you get from gas is so many joules but how does that translate into thrust/time
I saw an article on the internet somewhere. Some College kids in Japan built a nice big pedal powered type airplane and powered it with AA alkaline batteries. It flew for like 500 feet or something. A LiPo has way more energy than an alkaline. They were also using a standard off the shelf brushed motor.
I also found this.... http://www.kitplanes.com/magazine/engines/176-1.phtml
They want to use a fuel cell to power it.
I am just speculating here but an Ultralight would not have all the issues that you are talking about. They can only weigh 254 pounds dry. They have none of the restrictions that regular FAA approved aircraft require. And they regularly fly with 20-50 hp motors.
I am not saying "hey all these gas people are nuts" i am just wondering what CAN be done. They have electric cars breaking speed records all over. Heck you can buy an electric car that does 0-60 in 4 sec and has a 200-300 mile range for $100,000 for prototypes on its way to $20,000 for production models. http://www.commutercars.com/
Like I said i am just wondering if it something that can be done. 30 minutes in a silent ultralight would be great!
Old Feb 20, 2007, 11:43 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
The shape of things to come?
http://www.grc.nasa.gov/WWW/RT/2003/...20emerson.html
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Feb 20, 2007, 01:27 PM
Figure Nine Champ
madsci_guy's Avatar
North Texas
Joined Nov 2002
Aeronautics goes by the numbers. It has ever since the Wright brothers. Untill you can get energy density per pound comparable to gasoline, I don't see battery powered flight except as a novelty or hobby. Sure, you "can" make a battery powered plane, but it wouldn't be practical. And the price would be prohibitive.
Old Feb 20, 2007, 03:51 PM
DavidB. is offline
Find More Posts by DavidB.
X-Era Motors
DavidB.'s Avatar
Newport, NC
Joined Jan 2002
Energy density actually has to get to "only" 1/3 to 1/4 that of gasoline. Electrics are WAY more efficient.
DavidB. is offline Find More Posts by DavidB.
Old Feb 20, 2007, 04:53 PM
FairlyFaded is offline
Find More Posts by FairlyFaded
Registered Snoozer
FairlyFaded's Avatar
Palo alto CA
Fancy that, im doing just what your saying as we speak!
http://www.rcgroups.com/forums/showthread.php?t=645386
The technology is so here-right now. You can get 18650s cheep! (<2$a cell)
use 4 large chinese brushless motors geared together and you have 120lbs of thrust from a 25lbs set up that cost less then a grand.
FairlyFaded is offline Find More Posts by FairlyFaded
Old Feb 20, 2007, 05:09 PM
Figure Nine Champ
madsci_guy's Avatar
North Texas
Joined Nov 2002
Power efficiency is NOT all you look at. In aircraft one must factor in weight. 6 to 650 is a 100:1 fuel energy/pound ratio, that you must overcome. I would certainly put "only" in quotes, as you are a long way from even coming close. Your advanced small turbine (cruise missile type) is 46% efficient. That means you must get to 2:1, in order to compete, merely on similar theoretical performance. That's a 24 lb battery comparing to 12 pounds of fuel, for our two hour trip. And that's a 50 times improvement in current energy density of your battery. As we say in the engineering world, "That's rather aggressive engineering". And of course I used LiPoly in plastic weight numbers. Run the 1.5 thousand amps through the battery that you need to run to fly, and you are talking a LOT of heat that requires cooling, which of course eats up your weight budget. Putting the batteries in series to reduce the amps the motor uses still means the same heating, because the watts consumed by the motor must be the same to drive the prop the same.
And a battery that was 50 times more energy dense per weight than a Lipoly looks more like a bomb than a battery. Just compare Lipo to NiMh flammability and see what I mean.
Oh, and there's another problem. NdFeB magnets lose their magnetism at 100 degrees C, some even lower, like the high MGO (35+) number magnets, that you would have to use for your theoretical high efficiency motor. You climb out for 1/2 hour at full power in summer and probably your magnets will go south, causing your motor to overheat severely, making a great fire complete with very toxic fumes from the NdFeB magnets.
Old Feb 20, 2007, 05:35 PM
Aio_1 is offline
Find More Posts by Aio_1
Aio_1's Avatar
Ireland, Kildare, Leixlip
Joined May 2002
On the subject of temperature. Lipos don't like low temperatures very much. That could be a problem at normal full size altitudes if you're spreading the cells out in say the wing. Although on second thoughts you could heat them a little without too much difficulty but it will cut into your overall efficiency.
By the way there is an electric paramotor harness being developed. Looks to be pretty practical. It may even be on sale already. I can't remember where I saw it. I suspect someone on RCGroups supplied me a link.
Aidan
Aio_1 is offline Find More Posts by Aio_1
Old Feb 20, 2007, 08:09 PM
gouang is offline
Find More Posts by gouang
Fly fast and turn left!!
Bruxelles/Uccle
Joined Dec 2001
http://www.lange-flugzeugbau.de/htm/...news/news.html
http://www.lange-flugzeugbau.de/htm/...ropulsion.html
Full size Electric glider is already flying.
gouang is offline Find More Posts by gouang
Old Feb 20, 2007, 09:10 PM
DavidB. is offline
X-Era Motors
DavidB.'s Avatar
Newport, NC
Joined Jan 2002
Please backup that number, it looks like it's about double the actual figures I've seen.
There are planes flying now with lithium cells, this is not really that big an issue.
I have no idea where you're headed with this response..what is your point?
Every power source is dangerous if misused or designed incorrectly, theres no getting around it.
We're assuming the system is designed correctly here, correct?! It sounds like you're digging at the bottom of the ditch to find a response. I must ask, do you have some sort of stock in the oil companies? I mean common, NdFeB and toxic fumes, where do you find this stuff.....
Old Feb 20, 2007, 10:15 PM
Aethertek is offline
Find More Posts by Aethertek
Creations Aberration
Aethertek's Avatar
United States, OR, Newport
Joined Jan 2004
Small gas engine/turbine(better) turns alternator / alternator supplies electric power.
Not battery powered per se, but energy density of gas with propulsive efficiency of electric motor.
Just a thought...
Aethertek is offline Find More Posts by Aethertek
Old Feb 21, 2007, 12:55 AM
Registered Snoozer
Palo alto CA
200 li-ion 18650 cells: 1.6kwh, burst of 7kw: 20lbs <400$
1 brushless motor: http://www.himodel.com/electric/176K...e_A7050_6.html
6.6kw: 180$ 3lbs
cheap chinese ESC: 100$ <1lb
total wieght 24 lbs, max hp 8.75. total cost 680$ plus 150 for a charger...
find me a reasonable gas engine that wieghs much less then 24lbs...
madsci are you ever wrong.... i think people like you are the reason electric vehicles never can get of the ground. (sorry to be such a sinik but comon...)
Old Feb 21, 2007, 01:05 AM
coffeegeek is offline
Find More Posts by coffeegeek
coffeegeek's Avatar
Italy, Umbria, Perugia
Joined Sep 2006
It's easy. We just need to utilize the same technology used in regenerative braking in electric vehicles.
All you'd have to do is massive climbs to store energy, then massive dives to spin the prop to generate electricity to charge the batteries!
Or even easier, just mount a wind generator somewhere on the fuselage at least 4 times bigger than your prop, and it will charge itself as you fly!!
I should work for NASA!
PS, I'm also trying to take out a patent for a Prosthetic Head made out of cork for people who've accidentally been decapitated by the prop on their 1:1 scale RC plane, when they plug the HUGE deans connector in, THEN realize their throttle stick was WOT!!
coffeegeek is offline Find More Posts by coffeegeek
Old Feb 21, 2007, 02:54 AM
Aio_1 is offline
Aio_1's Avatar
Joined May 2002
Just a thought...
You're still using a turbine or piston engine to generate the power so you've already go the loses associated with that and then you're adding the losses of an electric system. I don't see any sense in hybrid drives in aircraft. A car spends it's time accelerating and decelerating, climbing and decending hills, resting at traffic lights etc... the benefit is that you can run the engine at a more constant and efficient rpm and smooth the peaks and troughs in power usage using the cells. Full size planes on the other hand spend their time cruising at pretty constant power levels. I don't see how you gain anything by using a hybrid. Even if take-off were electrically assisted to reduce engine size requirements the weight and volume of associated cells and systems would undoubtedly make this pointless.
Aidan
How long does a Lipoly Battery last, how many cycle can you make? lazy-b Batteries and Chargers 22 Nov 11, 2006 12:46 PM
Discussion How many cycle can you make on a brandnew Lipoly battery? lazy-b Batteries and Chargers 4 Sep 11, 2006 10:56 AM
Discussion how quiet can you make a nitro heli chris higdon Fuel Heli Talk 5 Aug 18, 2006 11:07 AM
Can you make a brushed astro brushless? Joel K. Scholz DIY Electronics 4 Mar 21, 2005 03:59 PM
How thick can you make a wing? Dubcat Flying Wings 7 Jun 16, 2004 11:43 AM
