24' glider spar....
hello everyone!
Im building a massive foam wing (24') and i need some advice on the spar. Im doing a D box structure as you can see, i plan on having two spars. one being the back of the D which will be most of the strength and another a foot or so behind the first one. The ribs are each 4' long. The entire thing is made out of white eps foam. The wing needs to beable to hold around 140 lbs ish. Most of the load will hopefully be on the spar/dbox. I did put the spar a little far forwards but hey theres no going back now! My mats are- 4yards of 1' 4ish oz uni directional carbon, and 4yards of 4oz glass. My original plan was to put a few layers of the uni directional stuff on the top and bottome of the 1 1/2" foam spar with glass underneath and above going a few inches over the edges of the spar, but i dont think this will be stronge enough.... I am now thinking of using some very nice light wood i have seen at the hardware store. It is 1 1/2" wide by around 1/4". It feels veryyy light and very rigid. Im not sure what kind of wood it is but i think it would make a great spar "cap". So now im thinking i will do one layer of glass, then the wood spar, then ontop of the wood 1,2 maby 3 layers if the unidir. carbon, then another layer of glass all over that. I think that would make for an increadibly strong and light spar. what do you guys think? thanks! michael
Joined Nov 2004
I think the opposite, I feel you will have more strength than you can imagine with two thin spar caps of spruce. Just think, a 16' 2X4 supported only at the ends can easily hold a 140lb person even on the 4" side. Sure it will bend, but it won't break. 2X4's are made of poor wood.
If you use spruce, and have spar caps of 1.5" X 3/4" dimension epoxied to the foam and wrapped as is with thick carbon tow (or similar), it will support 140lbs with ease. When you load a wing with 140lbs, the center area of the wing supports the majority of the load, the tips do less than their share of work. Therefore, if your spar can hold 100 lbs while spanning only 16 feet, you will be all set. Here is another option: Skip all this complicated and time comsuming spar work, make a simple spruce cap spar wrapped with cheap flat strand cord, and add two 1/16" stainless cable flying wires below the wing.......similar to a hang glider. Very strong, cheap, quick, and probably 20 lbs lighter. Here is an ancient photo of an early hang-glider, but it is a great shot of the flying wires I'm talking about. (The assistant is holding one of them). Note, the hang-glider's span is about 24', and the "spar" (3" alumimum tube) is very weak compared to even the simplest spruce spar for your wing. http://open-site.org/newsletter/batb...anggliding.jpg Good luck |
So is this going to be for some kind of "Red Bull" human flying thing?
Latest blog entry: May 2013 US F3B Team Practice contest
I also think you are going about this all the wrong way...
You should have titled the thread something obscure like "here goes nothing II" The photos are way too clear. We can clearly see that you are quite the crafstman. Your posts don't have near enough spelling mistakes. Because of the above, you are missing out on free parts/advice from highly frustrated posters. Of course, you also have a lot less chaff (except this post) in this thread... http://www.rcgroups.com/forums/showthread.php?t=372482 Good luck with your project... Ryan |
lol the "olds" are at work.... I have this week off from school. Iv been building planes for 10years all over the house so they have gotten used to it : D. Im not to sure what a red bull human flying thing is, maby one of thouse events were people jump off a dock and try to fly? If so no thats not what it is : D It occured to me a few weeks ago that electric human flight is not only doable but also could be doen quite cheaply. I have found a nice sourse of li-ion 18650 cells (2.2ah). At only 1.75$ a cell i can put together a 1.6kwh pack for only 325ish$$$'s. With the price of chinese brushless stuff at its alltime low i can put together a very efective motor system for another cupple hundred. With that set up i could have bursts of 120lbs of thrust at 30mph pitch speed from a 25lb set up.
Yes it is true that this should be in the electric forums, but i think if i put it there theyd say to make it out of one huge piece of depron.... O.o Also another thing that spured on my building of this plane is the fact that airplanes are really veryyy simple. I have found that i can make a plane from scratch in 2 hours and it works, all you really need is a decent SG/wing loading and some resonable control surfaces. Ill try and get over to the local ACE to get the spar cap wood so i can start building the spar, ill post pictures if you like, hahah who am i kidding who WOULDNT want to see pictures : D. Anyone have any ideas for a trailing edge? thanks guys! michael p.s. dont get to thinking "oh this guys young and foolish itll never work", cuz back a many years ago when i went to get a "fire bird" as my first rc plane the guy behind the counter said i was too young, boy was he wrong. Iv built alot of nice things like my composite dl50 and my cnc cutter so dont prejuduce me, not that anyone has been : D |
