Go Back   RC Groups > Aircraft - Electric - Airplanes > Indoor and Micro Models
Old Feb 19, 2007, 11:00 AM   #1
Ralph B's Avatar
Solar Micro Mite
I recently obtained a pair of high output solar cells from Spectrolab for a micro solar model. The cells are the same size as those I used on the Sol-Mite however these new cells are rated at nearly double the efficiency (31%). I decided that the light weight version of the Micro Mite that I had been flying indoors would be a good subject for a solar conversion. With the solar cells the weight of the Micro Mite was going to be increased to 9.5 grams. I was not sure if the 4MM drive would handle that much weight so I tested the model on a 20 MAH Full River cell with enough ballast to bring it up to 9.5 grams. I replaced the Microinvent 3222 prop with the Carbon Butterfly prop which has a little more blade area and pitch. The test was a huge success so I went ahead with the conversion. First flights were made yesterday. This "quarter scale" Sol-Mite has a much better power to weight ratio than the large one. It can fly in less than the perfect conditions that the larger model required. Specifications as follows:
Wing span: 8 inches
Flying weight: 9.5 grams
Equipment: Plantraco .38 gram, 3 channel receiver with a pair of Nick Leichty's remote actuators on rudder and elevator.
Drive: Didel MK04-10 motor with 7.1 to 1 ratio watch gears.
Prop: Carbon Butterfly
Ralph B
  • Name: P2180016.JPG
  • Name: P2180029.JPG
  • Name: P2180023.JPG
  • Name: P2180045.JPG
  • Name: P2180012.JPG
  • Name: P2180038.JPG
Ralph B is offline Find More Posts by Ralph B   Reply With Quote
Old Feb 19, 2007, 11:09 AM   #2
Printed Tissue Fanatic
Gordon Johnson's Avatar
Ralph,
Wow that's great. You just keep making progress on the solar powered plane front.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson   Reply With Quote
Old Feb 19, 2007, 11:39 AM   #3
build to fly, not to crash
micro_builder's Avatar
Send a message via Yahoo to micro_builder
nice work, Ralph. i honestly didnt think i'd see something like this for a while yet. its good to see solar cells are getting that much better - 31% is quite a step up. amazing that the 4mm can haul around nearly 10 grams of weight. whats the weight of a single solar cell?
very cool
nick
micro_builder is offline Find More Posts by micro_builder   Reply With Quote
Old Feb 19, 2007, 12:13 PM   #4
Ralph B's Avatar
The cells weigh 1.9 grams each. I was really suprised that the 4MM drive was able to fly it. I expected to have to struggle to get enough thrust but the 7.1 ratio with the Carbon Butterfly prop flies it with authority. The flights yesterday were short because the wind kept tipping the wing up so the exposure to the sun was interupted which caused the receiver to "brown out". The sun here is lower at this time of year so I expect it will do much better with a better exposure angle.
Ralph
Old Feb 19, 2007, 12:24 PM   #5
iter's Avatar
Send a message via ICQ to iter Send a message via AIM to iter Send a message via Yahoo to iter
Very very impressive!
Re the receiver browning out. Plantracos take a loooong time to boot--usually enough time for a model to land before control can be reestablished after a momentary disconnect. Perhaps you could try a different RX, maybe one of Nick's, or one with YAPP? I wonder also how much a capacitor would weigh that could smooth out these "wing-tipping eclipses."
Ari.
iter is offline Find More Posts by iter   Reply With Quote
Old Feb 19, 2007, 12:42 PM   #6
Ralph B's Avatar
Ari:
You are exactly right. If necessary I will replace the receiver with one of Nick's. The sun at it's highest point yesterday was still somewhat low. The real exciting news for me is that in spite of the sun angle yesterday that it flew at all. I'm sure when we start getting the exposure angles that are typical here that there won't be any more brown outs. The larger Sol-Mite would not have been able to fly at all yesderday.
Ralph
Old Feb 19, 2007, 02:42 PM   #7
Sonic1's Avatar
Ari.
Maybe one of these super capacitors might work....
Sonic1 is offline Find More Posts by Sonic1   Reply With Quote
Old Feb 19, 2007, 03:04 PM   #8
superb!..
Foamaster :) is offline Find More Posts by Foamaster :)   Reply With Quote
Old Feb 19, 2007, 03:43 PM   #9
Realtired User
mharms's Avatar
Wow Ralph, that's incredible!
Funny, yesterday, a guy was asking me about using solar cells on model planes. I explained to him how it required lots of wing area and how the cells were heavy, etc... So here you go and do this.
Very, very cool.
I assume the cells are very expensive?
Mark
mharms is offline Find More Posts by mharms   Reply With Quote
Old Feb 19, 2007, 03:58 PM   #10
Ralph B's Avatar
Mark:
The cells are not cheap, however, since I was only needing two cells they offered to send me a couple of samples. I do have some history with them (Sol-Mite) and I think they were interested in what I wanted to do. I really don't know what the cells would have cost but I did have to pay for FEDEX overnight shipping which came to $53.
Ralph
Old Feb 19, 2007, 04:10 PM   #11
Site Sponsor
Plantraco's Avatar
Fantastic Solar Model Ralph! That's a major advancement I'd say!
Maybe we could send you a receiver without the bootup sequence software. Instant -reboot would indeed be better to cope with brownouts. I think for an outdoor model our 900Mhz would have more advantages for that model.
Just like Spirit and Opportunity on Mars, maybe your model can be "Solar Groovy" when the sun is higher up in the sky.
That capacitor idea may work - it just depends on those brownouts.
At 9.5 grams with 4mm drive, it seems like you only have at most 5 grams of thrust. Will the model climb out OK at this weight? (ie: it seems like your propulsion is incredible - maybe it's better at speed or what?).
Plantraco is offline Find More Posts by Plantraco   Reply With Quote
Old Feb 19, 2007, 04:38 PM   #12
Ralph B's Avatar
Bud:
I'm sure the brown out issue will be forgotten latter in the year when the sun angle gets better here. If not I will contact you about a "solar" version of the receiver. I never had a problem with the larger Sol-Mite (with a JMP Rx.) but it could not fly with the sun where it was yesterday. The micro has a much better power to weight ratio and can fly in less ideal conditions.
I have no way to measure the thrust other than flying. I have found that the Mk4-10 likes a lot of reduction. My scratch built Butterfly using the same watch gears and the 3222 prop does nearly 20 minutes at 6 grams. The solar Mite has a very good climb angle and while I thought thrust would be marginal it flies with authority. With higher sun I should see a bit better thrust even though it does not need it.
Ralph
Old Feb 20, 2007, 01:20 AM   #13
Site Sponsor
Plantraco's Avatar
Originally Posted by Ralph B
Bud:
Ralph
Man, that makes me happy to hear that.
So, in theory, you could keep your model aloft for hours and hours on a clear sunny day in summer. It's completely amazing! What a breakthrough!
Old Feb 20, 2007, 04:41 AM   #14
TheyreComingToTakeMeAway!
derk's Avatar
or at least until the motor brushes give out
very awsome model Ralph
makes me wonder what those single phase brushless motors could do for solar powered models?
derk is offline Find More Posts by derk   Reply With Quote
Old Feb 20, 2007, 07:56 AM   #15
Baydon, England
Power required
Ralph,
Congratulations. That is a super achievement.
A little reference about power required to fly:
I have a lightened 'X' Twin (17.6g) which climbs steadily on the minimum power setting, such that I have to switch off to get it down. I have measured the minimum static thrust as 6 grams. This shows that it is possible to fly with the static thrust being only approx. 1/3 the total weight of the model. So in Ralph's model, 3 to 4 grams of thrust could be enough.
John
John Lafford is offline Find More Posts by John Lafford   Reply With Quote
Discussion Aero Ace 6.4g 6" wingspan Micro Mite TheBender Indoor and Micro Models 11 May 20, 2007 09:25 PM
Video Indoor Micro Mite Ralph B Airplanes - Electric Videos 2 Dec 06, 2006 09:27 PM
Micro Mite to test 60 Mah cell Ralph B Indoor and Micro Models 34 Jun 15, 2004 08:50 AM
Congratulations SimpleM!
