Old Feb 19, 2007, 08:33 AM
allans is offline
Find More Posts by allans
Westchester County NY
Joined Dec 2006
Question
Servo Size for 120 sized plane?
I have an Ultra Stick 120 Lite with O.S. 120 2 stroke on it. What size servos should I use? The current JR 537 analog ( 5 of them) have nylon gears and do not there position under load. These servos are the ones shown in the illustrations in the assembly manual. I also think I get flutter in the elevator control surface which has lead to elevator failure .They are rated at 40 ozs. I think this may be to low.
I have never seen another 120 sized plane with such small and low powered analog servos.
Ideas , thoughts , suggestions - PLEASE.
allans is offline Find More Posts by allans
Old Feb 19, 2007, 10:09 AM
mtwister is offline
Find More Posts by mtwister
Salem, Or.
Joined Jul 2006
JR ds821 digital's $27 each and they're rated pretty high in torque and are fast. I have 20 of them in planes up to 27% and they all work perfectly.
mtwister is offline Find More Posts by mtwister
Old Feb 19, 2007, 10:55 AM
BlazerB52 is offline
Find More Posts by BlazerB52
BlazerB52's Avatar
Fenton,MO USA
Joined Aug 2005
I use this calc to decide on what size I need for a plane.
Put in control surface size and max. speed you think you will be going.
http://www.coloradogliders.com/servo...calculator.htm
BlazerB52 is offline Find More Posts by BlazerB52
Old Feb 19, 2007, 11:01 AM
allans is offline
Joined Dec 2006
Thank you, for the reply. I have some of those. The look pretty strong . Are you sure they have enough power? It seems all of the 120 sized planes that are either fun fly or aerobatic have more powerful ( over 100 ozs). I think the 821 is around 70 ozs, I am not sure.
I am really curious why Horizon Hobby would show the low end JR servos in there assembly manual , if they were not adequate?
I think for long term use servos with nylon gears are not a good bet.
Old Feb 19, 2007, 11:10 AM
allans is offline
Joined Dec 2006
Thank you for the calculator. Its looks great. When it refers to the chord of the control surface I assuming that means both the fixed and movable part of the elevator. And the length is the measurement perpendicular to the fuse ( the long way down the elevator).
Yes ? to both ?
Old Feb 19, 2007, 12:11 PM
BlazerB52's Avatar
Fenton,MO USA
Joined Aug 2005
The cord on the control surface would be its width .
And then length is longest dimension.
If you have a control surface that is tapered. Lets say 1 1/2" at one end and 1" at the other. I put in the largest measurment which would
be the 1 1/2" figure to be safe. You only are calculating the surface area dimensions that moves.
Old Feb 19, 2007, 01:25 PM
allans is offline
Joined Dec 2006
Thank you very much . The calculator has given me an excellent idea of what I need. I know it might have some error in it but this looks like a very good stating point.
Old Feb 22, 2007, 06:17 PM
mtwister is offline
Salem, Or.
Joined Jul 2006
There are a ton of us flying the 821's on planes uo to 13 pounds with excellent results.
Old Feb 22, 2007, 07:11 PM
allans is offline
Joined Dec 2006
Thank you for the response. I have installed a bunch of 821 ( both JR and Spectrum - which look, curiously, very much alike) in my plane. My bad experience is with the 537 which is woefully too weak and improperly geared ( nylon) to do the job. I learned this the hard way .
Now I ask you , what servo is used in the illustrations in the assembly manual for the Ultra Stick 120 ? The analog , 40 oz torque , nylon geared 537.
Horizon distributes both Hanger 9 Aircraft and JR radios. Surprise , surprise.
The assembly manual show the 120 sized engine as the bottom end of the recommended engines. There are even illustrations of these larger engines in the final pages of the manual.
By the way, to there credit , Horizon replaced the Ultra Stick with no questions asked once I mailed the crash airframe back to them . Didn't say boo.
The new Ultra Stick flies beautifully . The new digital servos are big improvement over analog servos. Like the handling of radial tires over bias ply.
Question Servo size for an Alula Skycruiser Hand Launch 9 May 10, 2007 03:30 PM
Recommended servo size for a GP Spectra EP glider? Villious Electric Sailplanes 6 Feb 25, 2004 08:14 PM
Servo size for Sig LT-25 newguy Electric Plane Talk 8 Feb 04, 2003 04:37 AM
Aluminum Servo mounts for 120 degree mixing on ECO-8! Jon h Electric Heli Talk 5 Jan 14, 2002 08:19 PM
servo placement for 120 swash on eco gregh Electric Heli Talk 19 Dec 17, 2001 07:44 AM
