Old May 11, 2007, 05:02 AM
EP heli freak! is offline
Find More Posts by EP heli freak!
Joined Jul 2002
When are the 1107/1.5s going to be in stock?
EP heli freak! is offline Find More Posts by EP heli freak!
Old Jul 15, 2007, 09:41 PM
rcboosted is offline
Find More Posts by rcboosted
Joined Sep 2006
So I want to use 3S and aiming for 3200rpm. What pinion would I need on a 1107H/1.5Y? From the discussion that went on, I will need a 10T, am I right? I also only have cc35, and don't wish to go up to cc45. Would the cc35 be enough for this? I suppose I could drop the HS to 3100rpm since they don't bog as much.
rcboosted is offline Find More Posts by rcboosted
Old Jul 15, 2007, 09:59 PM
driftinsequence is offline
Find More Posts by driftinsequence
Joined Apr 2006
use an 11t. best results are from the 11t and a good 2100mah 25c battery. use strong blades like vblades to for best results.
the cc35 is okay. caution should be taken so i would recommend first by starting with a 10t.
driftinsequence is offline Find More Posts by driftinsequence
Old Jul 15, 2007, 10:39 PM
Joined Sep 2006
Thanks, I will give that a try. But that'll be a while, since they are out til early August.
Old Jul 30, 2007, 02:33 PM
Bahamadude is offline
Find More Posts by Bahamadude
United States, KS, Ingalls
Joined Feb 2004
Waht the longest flight time you can get by just fly around no 3D with that same setup from the fist page (1) ?
Bahamadude is offline Find More Posts by Bahamadude
Old Jul 30, 2007, 07:23 PM
TrumpetRhapsody is offline
Find More Posts by TrumpetRhapsody
TrumpetRhapsody's Avatar
Arkansas
Joined May 2007
Sup guys, I just finished reading through this thread and have a question or two.
I'm trying to plan my future purchases so I don't waste money now. Currently, I have 2 3S lipos and 1 4S lipo. My original goal was to use the same pinion, and swap between 3S for sport and 4S for 3D. I've come to realize this was dumb, so I'm abandoning that idea. So, now I need to pick whether to continue with the 3S route, or go down the 4S road. My flight style is about 50/50 between FF and 3D. (will probably sway more towards 3D the better I get at it though)
So, the question:
Should I buy more 4S lipos now and get the 1107H/2Y down the road, or get more 3S lipos now and get the 1107H/1.5Y down the road. How do the flight times and power compare between the two setups? I've read the descriptions on Neu's website, but I'd like some testimony from users.
TrumpetRhapsody is offline Find More Posts by TrumpetRhapsody
Old Sep 26, 2007, 07:21 AM
Trex974 is offline
Find More Posts by Trex974
Joined Oct 2006
I re-read all this post and I can't have an info for my question so please, could you tell me the amp draw with
- the 2Y in 3S and a 13T
- the 2Y in 4S and a 11T
I have a hyperion 30A esc with a medusa 3.5A BEC, I wonder if it's enough. And it's very difficult to buy this motor !?! Have you got email addresses to give me ? Thanks.
Trex974 is offline Find More Posts by Trex974
Old Sep 26, 2007, 10:38 AM
JFGrn is offline
Find More Posts by JFGrn
Head...Paper...Now!
JFGrn's Avatar
Valley Village, California, United States
Joined Mar 2002
I don't have the numbers for you, but with this motor setup the way you want it. I wouldn't run anything under a 45 amp ESC.
John
JFGrn is offline Find More Posts by JFGrn
Old Sep 26, 2007, 10:44 AM
Trex974 is offline
Joined Oct 2006
waow, ok so I'm far from what I expected. So I think I'll have to use my hyperion 50A, hoping his BEC will be ok. Thanks
Old Mar 01, 2008, 09:02 PM
Stembridge is offline
Find More Posts by Stembridge
Bunch of KOOKS!
Stembridge's Avatar
Long Beach
Joined Jun 2002
1107 1.5Y
Been liking this motor for a long time. Atleast 150-200 flights on this motor. The other day in the middle of flight I lost almost all power and heard a weird noise. When I looked, it seemed the pinion was loose. Well it turns out the shaft is now free spinning in the motor, there is no cogging left??? It just kind of squeeks. Never been crashed. So it basically quit on me. Anyone heard of this happening ever?
Stembridge is offline Find More Posts by Stembridge
Old Mar 01, 2008, 11:19 PM
dieselracer is offline
Find More Posts by dieselracer
dieselracer's Avatar
Vista, CA
Joined Nov 2006
Originally Posted by Stembridge
1107 1.5Y
That happened to me. I sent mine to new. They repaired it for 25 bucks. and it took a little over a month for me to get it back.
dieselracer is offline Find More Posts by dieselracer
Old Mar 02, 2008, 08:11 PM
Bunch of KOOKS!
Stembridge's Avatar
Long Beach
Joined Jun 2002
A month? Might aswell just buy a different motor. Sucks that a 130$ motor would do that.
Old Mar 02, 2008, 08:41 PM
Vista, CA
Joined Nov 2006
Yeah i ended up buying a scorpion for a back up, untill i got it back. Then i ended up keeping the scorpion instead.
Old May 15, 2008, 12:40 PM
beafraid8 is offline
Find More Posts by beafraid8
Mom says I'm special...
beafraid8's Avatar
Aurora, CO
Joined Apr 2003
I sent mine in for repair after a nasty crash last fall and had it back in my hand within 10 days.
Sounds like you need another heli or an XL motor on the shelf to hold you over!
Easily over 100 flights and still lovin' it!
beafraid8 is offline Find More Posts by beafraid8
Old May 15, 2008, 10:46 PM
Vista, CA
Joined Nov 2006
There is no need for a back up. the Scorpion was better.
Sold neu 1107/1.5y/3.2mm motor for sale!!! driftinsequence Aircraft - Electric - Helis (FS/W) 4 Aug 21, 2007 08:25 PM
For Sale Neu 1107H/1.5Y/2.3 trade for 1107H/2Y Ted U Aircraft - Electric - Helis (FS/W) 0 Apr 24, 2007 09:15 AM
Wanted Jeti Spin 44 and Neu 1107H/1.5y/3.2mm Keith43221 Aircraft - Electric - Power Systems (FS/W) 0 Mar 29, 2007 03:50 PM
Wanted Neu 1110/1.5y 3.2mm ChrisAttebery Aircraft - Electric - Power Systems (FS/W) 0 Nov 07, 2006 09:03 AM
Sold F/S Neu Ork 1912-1.5y with Raptor Mount epc2 Aircraft - Electric - Power Systems (FS/W) 1 Mar 29, 2006 10:43 AM
