Old Feb 18, 2007, 07:35 AM
United States, NC, Dobson
Joined Jan 2007
Hoped-up Blade CP Pro
I'm building a blade CP Pro version with microheli CNC head, CNC frame, and twin tail motor, with E-flite 20 AMP ESC and Eflite 370 Brushless motor, also the E-flite Head-n-Hold Gyro. With carbon fiber main, and tail blades. I'm installing a berg 7 rx also.
I have the E-flite 11.1v 800mah 3-cell li-po. Will this battery be enough power for this heli.
Also if not and I need a more powerful battery with more mah's.
And will my Standard li-po charger charge it.
RCHSF is offline Find More Posts by RCHSF
Old Feb 18, 2007, 08:29 AM
Joined Nov 2006
Darkhorse has a nice page that helps compute power req's
see http://dhrc.rchomepage.com/calc.htm
As for the charger, I would get a better charger then the one that came with the Blade kit. I dont think it really is all that good at balancing. Based on its design it looks like it just charges until 1 cell hits 4.2v and then stops.
If you do gets a new charger, check the charging leads PRIOR to plugging any Lipo into the charger. Some chargers are expecting the charging leads to be reversed from what the EFlite charger uses (never cross the streams )
jjsohio is offline Find More Posts by jjsohio
cincinnati oh
Joined Feb 2007
It will work. But to make it shine, I would use the 1320mah.
fxstse is offline Find More Posts by fxstse
Old Feb 18, 2007, 09:19 AM
Joined Jan 2007
What is a good li-po charger. And will the 1320mah hurt any of my eletrics, not to much power is it. Just want to be on the safe side. Thanks
Old Feb 18, 2007, 11:31 AM
Joined Jan 2007
1320 will be heavier, 800 is good i think or tp910's, get the dd tail, it's way better than stock.
chopperdudes is offline Find More Posts by chopperdudes
Old Feb 18, 2007, 12:03 PM
Idle up!
PLATINUM's Avatar
USA, VT
Joined Nov 2004
Outback,
The only way it could hurt your electrics is if you went past 11.1v (ie 4 cell lipo)
from 800-1320mah is gonna be good if they are 12-20c rated. Think of it this way.
mah is the ammount of time a battery will last. But you have to counter this time with the weight you add to the heli. More weight is less time, more mah is more time. Somewhere along the way the weight will defeat the time more than help it, and weight can make your electrics work harder to achieve the same/like results.
PLATINUM is offline Find More Posts by PLATINUM
Old Feb 18, 2007, 12:18 PM
ndb8fxe's Avatar
Joined Nov 2006
How much will that whole package cost?
ndb8fxe is offline Find More Posts by ndb8fxe
Old Feb 18, 2007, 02:37 PM
Joined Jan 2007
So far I got a G tied up in it. I only need charger,balancer/ and one more battery. And then it set's on the shelf till I can fly the P out of the stock one.
P.S with some left over parts, it all adds up.
Yippee! E-Flite Blade CP Pro WarbirdLover Micro Helis 3 Jan 13, 2011 10:58 PM
Discussion blade cp pro?! megaglow_Z Micro Helis 39 Nov 02, 2008 05:37 PM
Discussion Blade CP Pro problem - collective pitch doesn't keep up with throttle input John Webb Micro Helis 4 May 13, 2007 12:47 PM
Help! Setting up New Blade CP Pro with Berg7 RCHSF Micro Helis 48 Mar 05, 2007 10:33 AM
Alert Two Thumbs UP! (Blade CP) selfo Micro Helis 6 Nov 18, 2005 01:10 PM
