Sizam,
I'm using 8-call 600 mAh NiMh packs from www.balsapr.com and have the same issue. I needed 3/4 oz of lead on the nose to get and acceptabe c.g. with my Zero. If I had to do it again, the weight would be better spent on heavier batteries. Carl |
zagi!!
i use the8 cell n-500r 500 mah nicad packs from Trick rc (www.trickrc.com)
when the motor is wanting to, it flies great..... no cog issues here i am back at 52mm and like the aerobatic capability with slightly heavier tail. need new motor right now though Belgy |
| Thread Tools | |
| What motors are you using in your T-Rex | jetspud | Mini Helis | 17 | Jul 22, 2005 12:11 AM |
| What engines are you using in your TT nitro conversions. | wicked_n_raw | Motorcycles | 4 | May 14, 2004 04:58 AM |
| What Battery are You Using in Your Tiger Moth? | Dogsbd | Parkflyers | 10 | Jun 17, 2003 09:43 PM |
| What batteries are you using in your Cutie | Clu | Electric Plane Talk | 6 | Nov 20, 2001 08:17 AM |
| What cells are you using in your Sokols? | Jensst | High Performance | 10 | Jul 13, 2001 08:43 AM |
