Old Feb 16, 2007, 03:30 PM
The L is offline
Find More Posts by The L
Joined Sep 2006
How does the Spektrum bind plug work? I lost mine.
I've lost my Spektrum DX6 bind plug.
I have two AR6000 receivers that I need to bind.
Can anyone tell me how the bind plug works so I can make another? Is it just a wire connecting the - pin to the signal pin on the BAT port? That's what I gathered it was from pictures... but I'd like to be sure.
Thanks in advance.
The L is offline Find More Posts by The L
Old Feb 16, 2007, 03:33 PM
Comatose is offline
Find More Posts by Comatose
Dimension Engineering
Akron, Ohio
Joined Jan 2002
yes
Comatose is offline Find More Posts by Comatose
Old Feb 16, 2007, 03:40 PM
JohnC is offline
Find More Posts by JohnC
Senior Moments...I forgot
JohnC's Avatar
New Hyde Park, NY
Joined Mar 2001
It connects the negative pin to the Signal pin in the bat port. You can get a new bind plug with a new receiver at least the AR 6100 has the bind plug in the package.
Most guys keep the bind plug in the transmitter battery compartment.
John F. Clarke
AMA 9473
JohnC is offline Find More Posts by JohnC
Old Feb 16, 2007, 04:02 PM
Ron Williams is offline
Find More Posts by Ron Williams
slow but inefficient
Ron Williams's Avatar
Riverhead NY USA
Joined Dec 2000
Got a paper clip?
Ron Williams is offline Find More Posts by Ron Williams
Old Feb 16, 2007, 04:13 PM
jupiter1 is offline
Find More Posts by jupiter1
Lost in space
Jupiter FL.
Joined Sep 2006
An old servo lead would be safer. Just twist the negative and signal wires together .
jupiter1 is offline Find More Posts by jupiter1
Old Feb 16, 2007, 04:41 PM
Danal Estes is offline
Find More Posts by Danal Estes
Flys with Thumbs
Danal Estes's Avatar
Frisco, TX, USA
Joined Sep 2001
Or servo extension. Cut off the end you won't be using, trim back the center wire, twist the outer two wires together.
Danal Estes is offline Find More Posts by Danal Estes
Old Feb 16, 2007, 05:45 PM
The L is offline
Joined Sep 2006
Done. Thanks everyone.
Old May 09, 2008, 03:04 PM
arnie dean is offline
Find More Posts by arnie dean
Joined May 2008
ok what is a bind plug
arnie dean is offline Find More Posts by arnie dean
Old May 09, 2008, 03:42 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
http://spektrumrc.com/Content/PDF/dx6manual-english.pdf
See page 24.
Bill
ebill3 is offline Find More Posts by ebill3
Old Sep 08, 2013, 10:33 AM
flysohigh is offline
Find More Posts by flysohigh
flysohigh's Avatar
Miami Fl
Joined Feb 2011
Can the bind port be used to power led lights?
flysohigh is offline Find More Posts by flysohigh
Old Sep 08, 2013, 10:44 AM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
You can also just turn a regular servo plug around... No need to cut anything.
1320fastback is offline Find More Posts by 1320fastback
Old Sep 08, 2013, 10:50 AM
flysohigh's Avatar
Miami Fl
Joined Feb 2011
Is this a reply to my post?
Old Sep 08, 2013, 01:46 PM
USA, CA, Oceanside
Joined Jul 2008
No, the OP.
Old Sep 08, 2013, 06:11 PM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
This thread is 6 yrs old and yes you can use the bind socket for lights.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
How does fixed pitch cyclic work? slowpoke Electric Heli Talk 6 Mar 30, 2007 07:24 PM
Confused.............How does a V-Tail system work Kenny-WR Electric Sailplanes 7 Jul 03, 2002 02:37 PM
How Does A Real Jet Egine Work? RUDOLF Life, The Universe, and Politics 4 Jun 27, 2002 06:06 AM
How does motor timing actually work? Peter W Power Systems 5 Dec 30, 2001 12:21 PM
How does a tandem fan setup work? rcaviator Electric Ducted Fan Jet Talk 1 Dec 07, 2001 09:35 AM
