Old Feb 16, 2007, 03:14 PM
ToxicToast is offline
Find More Posts by ToxicToast
Phlathead
ToxicToast's Avatar
Roseville, CA
Joined Aug 2006
Video
YAP EuroFighter 2000 - Re maiden 4-22-2007
Here is a broadband 3min video of the 'Re-Maiden' of the YAP Eurofighter. The first flight back in Feb was beautiful until I misjudged an approach and snagged a power line. Luckily it was an easy rebuild so I decided to add paint and pretty it up.
It flew absolutely beautiful and fast. Canards were toggled on and off at various times. Landed very hot and you can see something pop off the plane (it was only a piece of lead in the intake!) at the end.
Custom GBx Double 6T 22AWG, 20C 2100 3S, Spektrum, 30A ESC. AUW 18.1oz, 512g. Depron sealed with WBPU and talc mix.
*** EDIT UPDATE ***
I've re-edited and recompressed the video. It now uses WM9 *.mwv compression and should be compatible with a broader range of configurations.
Sorry it took so long to get this fixed but I'm glad you stopped by to check it out.
ToxicToast is offline Find More Posts by ToxicToast
Old Feb 16, 2007, 10:55 PM
tailslide5_0 is offline
Find More Posts by tailslide5_0
Hangar queen hoarder
tailslide5_0's Avatar
Denver, CO
Joined Jul 2006
Looks good to me. I had an X-31 with canards, and I ran the canards off the rudder channel so I could move them alone, and programed to slave off of elevons w/ flip of switch (like yours is). I found their effect to be rather insignificant during flight.
tailslide5_0 is offline Find More Posts by tailslide5_0
Old Feb 20, 2007, 01:30 PM
RCDad is offline
Find More Posts by RCDad
Bay Area
Joined Feb 2004
Yes, your canards are moving correctly with your elevons. A quick check is to watch the leading edge. LE goes up, the nose goes up.
tailslide, I set up my canards on my Eurofighter the same way you did. However, for extreme manuvers moving canards offer tighter turns and loops (more like flips). Also, a ducted fan plane will fly differently than a rear prop driven plane. Toxic Toast's plane will be able to fly much slower and better utilize the benefits of moving canards at an extreme level of flight.
Toxic Toast, is this your own design? Will it remain a profile or will it be skinned with a full fuse? Good luck with the build!
Here is my Eurofighter,
Kevin.
RCDad is offline Find More Posts by RCDad
Old Apr 25, 2007, 08:22 AM
EineHund is offline
Find More Posts by EineHund
Joined Aug 2006
Looks really great man! Also his first self made motor. =) Well done brother.
EineHund is offline Find More Posts by EineHund
Old May 14, 2007, 06:47 AM
streff is offline
Find More Posts by streff
Southport Merseyside UK
Joined Jan 2006
I cannot view video with any of my video players does anyone know required codec and where to obtain from?
streff is offline Find More Posts by streff
Old Nov 04, 2007, 11:51 PM
Andrew u.k. is offline
Find More Posts by Andrew u.k.
Andrew u.k.'s Avatar
Berkshire U.K.
Joined Oct 2006
I can't either.
Andrew u.k. is offline Find More Posts by Andrew u.k.
Old Nov 05, 2007, 02:10 PM
Phlathead
ToxicToast's Avatar
Roseville, CA
Joined Aug 2006
Hey Andrew, I've updated the videos linked above. Re-edited and recompressed. Check it out!
Build Log YAP (Yet Another Profile) - EuroFighter 2000 - New Video! ToxicToast Foamies (Scratchbuilt) 96 Feb 14, 2010 10:12 PM
Video T-Rex 450SE 4-15-2007 Neu 1107h 1.5y Motor Maiden beafraid8 Electric Heli Talk 4 May 02, 2007 06:01 PM
Switchback re-maiden wild success!! pivotal Parkflyers 16 Feb 08, 2003 09:25 AM
Difference between 22/20/4 and 22/20/4H ToXS Electric Heli Talk 1 Jan 17, 2002 12:29 AM
Eurofighter 2000 / offshore KAMarks Electric Ducted Fan Jet Talk 12 Jan 09, 2002 03:35 PM
