Sullivan's Streamer S754 Smoke/Diesel & S752 Glow Fuel Electric Pumps Mini-Review
Rich Noon provides a quick look at these 2 handy new tools from Sullivan!
Sullivan's Streamer Electric Pumps
Dimensions:3 5/8" X 1 1/4" x 1"
Capacity:33 oz/min
Voltage:6-12V
Compatibility:As stated
(NEITHER are for gasoline)
Colors:red = diesel/smoke
yellow = glow
Switch Functionality:Fill - Off - Empty
Retail Price
S752 Glow:
S754 Smoke:
$16.95
$17.95
Approx. Street Price
S752 Glow:
S754 Smoke:
$14.79
$16.49
Manufacturer: Sullivan Products
Available Online, Tower Hobbies:Glow & Smoke
A fuel pump is a fuel pump right? That is, until, miles from home, the fuel pump decides to give up the ghost. Iíve spent more than a few frustrating moments trying to figure out how to get fuel in and out of a plane after a pump started leaking, or just quit unexpectedly.
Now on the market are the Sullivan Streamer electric pumps that should last for years, and are reasonable enough in price to keep a spare in the flight box!
Features of both:
  • Rugged, Reversible Gear Pump Design
  • High Flow Rates
  • 6-12 volt operation
  • Ultrasonically welded pump head
  • Direct drive pump
  • Three position Switch -- Fill-Off-Empty
  • Pre-installed alligator clips
  • Capacity 33 oz. Per minute @ 12V
  • Replacement parts are available
  • Strain relief to protect the cord/circuit board inside
Meet the Sullivan S752 Glow Fuel Pump
Sullivan S754 Smoke Oil Pump
Now here's an item I had needed for a long time! I've spent a lot of time cranking pump handles and using squeeze bulb type pumps to get smoke oil in and out of planes, and all the while wished for an electric smoke oil pump to make the job easier. I found too, that this pump would be great for the pilots that using diesel fuel powered engines!
Bench Test
In the middle of February in the Midwest, with nothing but cold and snow outside, cabin fever was quickly setting in. So I decided to bench test the fuel pump. I "borrowed" the wife's good measuring cup and got to it. More than 2 hours later, the pump continued to run flawlessly, through numerous on/off/reverse tests, etc.
The Sullivan pumps worked flawlessly. They were priced right, and from the quality of construction, should last for years. The smoke oil pump was something anyone who uses smoke oil or diesel fuel should have in their flight box.
You can have a beautiful day at the field, wonderful airplane, the finest radio, the best engine made and still be dead in the water at the field if your fuel pump fails. Trust me, I know...
Plusses:
  • Small size
  • Durability
  • Simple design
  • Bright coloration, easy to spot, hard to confuse which pump is which
  • Quick filling rate
Minuses:
  • Smoke pump didn't have switch protectors
There are no posts
For Sale Electric Glow fuel pump Steve H. Aircraft - General - Miscellaneous (FS/W) 2 Jul 13, 2007 09:46 PM
Article Hangar 9's Pulse XT Glow or Electric ARF Design w/ Evo 46NT Glow rc2xs Fuel Plane Talk 2 Nov 26, 2006 07:53 AM
Sold Sullivan Streamer 12 volt glow fuel pump rino Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jan 28, 2006 06:32 AM
FS: Cox TD .051 w/extras, Sullivan smoke pump, onboard Glow driver Dukester Aircraft - Fuel - Airplanes (FS/W) 11 May 04, 2005 10:59 PM
Death of Glow & Electric : New Fuel Cells IncredibleITGuy Batteries and Chargers 10 Jul 04, 2003 10:43 PM
