Old May 22, 2001, 09:30 PM
Ontario Int, California, United States
Joined Feb 2001
Global's Focke Wulf FW-190 ARF electrified??
Hello there! Is there anybody flew this ARF from global-electric version? It's going to be on sale "in-store" at Hobbypeople starting friday for $59.99!!! It's regulary $99.99-it can be gas or electric-using the 7.2 400 geared motor-can go from 3 to 4 channel. I inspected it and the ailerons are already installed!! I just don't know how it flies. Wattage Hawk will be on sale too for guess what-$39.00 bucks!!! With that kind of price-I'll build me a squadron-just kidding!!
tnsfrk is offline Find More Posts by tnsfrk
Old May 22, 2001, 09:50 PM
Texas
Joined Aug 1999
Moved to Open...
dave_lilley is offline Find More Posts by dave_lilley
Old May 22, 2001, 10:18 PM
Zebulon, NC
Joined Aug 2000
Ive been thinking about the same plane.
Steve H. is offline Find More Posts by Steve H.
Old May 22, 2001, 10:33 PM
Joined Feb 2001
I've never flown or own a low wing plane before but I guess if I start with the 7.2 geared 400, it'll fly slow enough to practice on-the manufacturer tried using 450 turbo from Multiflex and it does all kinds of aerobatics!! But that's for later!
Old May 23, 2001, 01:16 AM
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Well for that kind of money I will get one. I have heard good things about it but I think it needs more than a speed 400 geared, the plane is pretty big, I am considering using my 7 turn Cermark Colbalt on an APC 7x5. I will see how it flys,
Joe
[This message has been edited by JOE ELSTON (edited 05-23-2001).]
Joe Elston is offline Find More Posts by Joe Elston
Old May 23, 2001, 03:25 AM
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
A friend of mine had one of those converted to E-power. He tried many motor battery combos and the thing never really flew well. The best it flew was on a buggy motor direct drive and an 8X6 prop. Even then it was very squirrely on take off and it landed like a brick. The airframe is built for gas after all. Another problem it has are those tiny tips. It tip stalls like a mother if you try to slow it down. After the thing crash several times he said screw it and bought a bigger ARF warbird, a Model Tech ME-109 for 40 sized gas. It flies great on 12 cells. Much more fun than struggling with the FW-190. Check it out at: http://www.rcezine.com/March2001/electrics.html
Troy is offline Find More Posts by Troy
Old May 23, 2001, 07:41 PM
Joined Feb 2001
Boy am I glad there is E-zone to connect to you guys! Thanks much Troy for the info. It's just too tempting-there's not much to assemble on this one-and it's not that big at 35" wingspan, 22-26 oz. weight-it's not much heavier than my ferias using the standard 380 geared motor and it flies great!! Anybody else have the same experience as Troy's friend before I change my mind???
Old May 23, 2001, 07:54 PM
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
It was after I emailed Troy that he told me not to get one. So once the Zone and company save the day.
Joe
Old May 24, 2001, 12:48 AM
Zebulon, NC
Joined Aug 2000
Hey tnsfrk, did you get my Email?
Old May 24, 2001, 08:57 AM
kevin's Avatar
ohio
Joined Aug 1999
a friend of mine has this plane with a turbo 450 and 8x800ar cells. i have flown it. it neads a hard launch, once up to speed it flies ok. it has the nastiest stalls i have ever seen! and i used to fly a cap 21 (snap 21)
kevin is offline Find More Posts by kevin
Old May 24, 2001, 11:39 AM
Texas
Joined Aug 1999
http://www.ezonemag.com/articles/200...w190/fw190.htm
Old May 24, 2001, 11:55 AM
Super Senior Member
Albuquerque, NM
Joined Feb 2000
Same thing my friend experienced. It did require quite a hard bungee launch, and landed fairly quickly. He increased the area if the horizontal to get better stability. He hasnt flown it in quite some time though.
Greg
Slope Nut is offline Find More Posts by Slope Nut
Old May 24, 2001, 01:51 PM
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
When I first saw the FW-190 at the store, I was turned off by that horrible wing design.
I guess I am spoiled by my own FW-190A .
Some time ago I saw a guy at my field slam the Global FW-190 into the ground almost right after takeoff, he was using a car motor & some astronomic wing loading.
Herb is offline Find More Posts by Herb
Latest blog entry: BAe Hawk 90mm EDF
Old May 25, 2001, 12:00 AM
Texas
Joined Aug 1999
http://www.ezonemag.com/disc/Forum1/HTML/002779.html
Old May 25, 2001, 01:14 AM
Joined Feb 2001
Thanks guys for the input, that's my cue to stay away from this plane!! I think you should do the same CUE! No wonder they're lowering the price on this plane! AND THE SEARCH CONTINUES.......
FS: Global Focke Wulf FW-190 ARF aau007 Aircraft - Electric - Airplanes (FS/W) 5 Mar 27, 2005 04:32 PM
Global's Focke Wulf FW-190 ARF - electric conversion. sontiveros Scale Electric Planes 8 Sep 03, 2002 07:47 PM
Hobby Lobby's Focke Wulf FW-190 RookieOne Electric Plane Talk 2 Mar 11, 2002 03:14 AM
Global Focke Wulf FW-190 ARF (09-15) martin johnson Electric Plane Talk 3 Feb 24, 2002 06:56 PM
Global's Focke Wulf FW-190 ARF electrified?? tnsfrk Foamies (Kits) 1 May 22, 2001 09:50 PM
